Please run update docker, looks like fixed in new version.
I had the same problem after updating my supervisor.
My solution:
Stop supervisor and apparmor services:
systemctl stop hassio-supervisor.service
systemctl stop hassio-apparmor.service
Then delete the hassio_supervisor docker container. I used portainor for this, which provides a nice user interface.
After deleting the hassio_supervisor container I ran the already above mentioned curl script:
curl -sL https://raw.githubusercontent.com/home-assistant/supervised-installer/master/installer.sh | bash -s
Cheers
My system broke after updating to 2021.10. this worked for me as well.
Could someone please tell the the docker command I can type at the VirtualBox console to delete the hassio_supervisor container (instead of installing Portainer)?
EDIT: I was able to type the below command at the VirtualBox console to get the docker container ID for hassio_supervisor:
docker container list -a
hassio_supervisor 47ee9035baa8 ghcr.io/home-assistant/am64-hassio-observer.......
With my very limited knowledge, I was able to piece together from different forum posts the below sequence of commands. I would appreciate it if someone could please tell the the correct way to do this.
docker container rm 47ee9035baa8
Hello I have the same problem. I think supervisor updated 2 days ago and now its broken, cant start the container. I am on Home Assistant Core 2022.6.7, dont know which supervisor version. Can anybody tell me how to fix it? thank you so much!! i am scared
I had created this thread before I found the current one: Lost connection to supervisor container - supervisor keeps crashing
I think the link in the last command has changed as I was getting a 404 error. I didn’t do anything more with it and checked back an hour later and supervisor was running.
Thanks for the help.
