System Monitoring - How does yours look?
    sensors:
      sensor_count:
        friendly_name: 'Number of Sensors'
        value_template: >
          {%- set domains = ['sensor'] -%}
          {%- for domain in domains -%}
            {%- for item in states[domain] -%}
              {% if loop.first %}
                {{loop.length}}
            {%- endfor -%}
          {%- endfor -%}
you know the rest :slight_smile:
Cheers Jim.
Nothing Fancy
Huh. It doesn’t work for the shell_command domain.
I only really run one shell_command and it is no longer showing up so I can’t test for you
It’s ok the sensors have served their purpose and been commented out for possible future use. I don’t really need these counts on a constant basis.
Getting there slowly!
How do you get the pi-hole and plex data? Also the docker card, does that show whether the container is running? Does clicking it restart the container? Can you share the card config for each of those cards. Nice setup BTW :smile:
The pi-hole and plex data are both from the official components, using the custom mini graph card. The plex user info below it is a template sensor (I haven’t got this to add a break between users though annoyingly). Pi-hole has a switch to disable it also. The docker card shows which containers are running and lets you stop/start them too.
I’ve popped my config on to pastebin for you, lemme know if I’ve missed anything. plex user sensor:- platform: template sensors: plex_users: - Pastebin.com
But I don’t :blush:.
What is the domain names for automations, scripts, scenes ?
Found it, but unfortunately I get this error when I create it:
Template sensor scenes_count has no entity ids configured to track nor were we able to extract the entities to track from the value template(s). This entity will only be able to be updated manually.
What am I missing?
Listing the entities defeats the purpose of this script. So you have to update it manually using this service: homeassistant.update_entity.
Call it from the dev tools services menu or from an automation.
      sensor_count:
        value_template: >
              {% if loop.first %}
                {{loop.length}}
            {%- endfor -%}
          {%- endfor -%}
      automation_count:
        friendly_name: 'Number of Automations'
        value_template: >
          {%- set domains = ['automation'] -%}
              {% if loop.first %}
                {{loop.length}}
            {%- endfor -%}
          {%- endfor -%}
      script_count:
        friendly_name: 'Number of Scripts'
        value_template: >
          {%- set domains = ['script'] -%}
              {% if loop.first %}
                {{loop.length}}
            {%- endfor -%}
          {%- endfor -%}
      switch_count:
        friendly_name: 'Number of Switches'
        value_template: >
          {%- set domains = ['switch'] -%}
              {% if loop.first %}
                {{loop.length}}
            {%- endfor -%}
          {%- endfor -%}
      binary_sensor_count:
        friendly_name: 'Number of Binary Sensors'
        value_template: >
          {%- set domains = ['binary_sensor'] -%}
              {% if loop.first %}
                {{loop.length}}
            {%- endfor -%}
          {%- endfor -%}
      lights_count:
        friendly_name: 'Number of Lights'
        value_template: >
          {%- set domains = ['light'] -%}
              {% if loop.first %}
                {{loop.length}}
            {%- endfor -%}
          {%- endfor -%}
      tracker_count:
        friendly_name: 'Number of Devices'
        value_template: >
          {%- set domains = ['device_tracker'] -%}
              {% if loop.first %}
                {{loop.length}}
            {%- endfor -%}
          {%- endfor -%}
      camera_count:
        value_template: >
          {%- set domains = ['camera'] -%}
              {% if loop.first %}
                {{loop.length}}
            {%- endfor -%}
          {%- endfor -%}
      fan_count:
        value_template: >
          {%- set domains = ['fan'] -%}
              {% if loop.first %}
                {{loop.length}}
            {%- endfor -%}
          {%- endfor -%}
      media_player_count:
        value_template: >
          {%- set domains = ['media_player'] -%}
              {% if loop.first %}
                {{loop.length}}
            {%- endfor -%}
          {%- endfor -%}
      plant_count:
        value_template: >
          {%- set domains = ['plant'] -%}
              {% if loop.first %}
                {{loop.length}}
            {%- endfor -%}
          {%- endfor -%}
Monitoring Spam
Looks great! can you share the configs?
Very clean overview
What theme do you use and please share you config.
How are you getting the info for your remaining space on the NAS drives?
Also I wouldn’t mind seeing your config for the washing machine status too
Impressive… Oh my… Amazing!
I need more of your config!
Can you share your vacuum card and what coffee machine are you using?
@Sjeff, @elRadix, @Yoinkz
you can find details for my latest lovelace here As I don’t want to hijack this thread.
@getsmokes I use snmp to pull info from my NAS Drives, some drives already supported in HA.
My Coffee Machine is a cheap Aldi Pod one for around $100AUD. I have installed ultrasonic sensors in the water and waste reservoirs and have a weight sensor telling me how pods I have left.
Hey @SeanM, I noticed your Zwave count is empty, I get that too. Sometimes it shows the correct number and sometimes it’s just blank. Do you get that too or did you manage to fix yours?
Here’s how I setup mine to count Zwave devices. (thanks to @klogg)
zwave_count:
  friendly_name: Zwave Devices
  entity_id: sensor.date
  value_template: >
    {%- set domains = ['zwave'] -%}
        {% if loop.first %}
          {{loop.length}}
      {%- endfor -%}
    {%- endfor -%}
