It is clean and informative. Would you mind sharing your config file.
Of course not
The clock card is courtesy of Palm Springs Theme but it doesn’t always update on this view (which is the first one) although it does seem to on another test view. I posted the question but no one has replied.
#=== SYSTEM
title: System Information
icon: mdi:home-assistant
cards:
- type: vertical-stack
cards:
- type: custom:compact-custom-header
main_config: true
background: var(--primary-background-color)
active_tab_color: yellow
tab_indicator_color: yellow
notify_indicator_color: yellow
notify_text_color: black
menu: show
notifications: show
voice: clock
options: show
clock_format: 24
clock_date: true
date_locale: en-gb
exceptions:
- conditions:
user_agent: Mobile
config:
notifications: show
voice: hide
conditional_styles:
- entity: notifications
state: false
button:
notifications:
hide: true
- type: custom:clock-card
#=== System
- type: entities
title: System
show_header_toggle: false
entities:
- entity: sensor.installed_version
name: Hassio Installed Version
- entity: sensor.latest_available_version
name: Hassio Current Version
- type: divider
- entity: sensor.tasmota_current_version
name: Sonoff / Tasmota Current Version
icon: mdi:alpha-s-box-outline
- type: divider
- entity: sensor.last_boot_date_time
icon: mdi:calendar
- entity: sensor.rpi_uptime
icon: mdi:clock-start
- entity: sensor.ha_uptime
- type: custom:bar-card
title: Processor Use
entity: sensor.processor_use
height: 30px
animation: 'off'
indicator: 'off'
severity:
- value: 60
color: green
- value: 85
color: orange
- value: 100
color: red
title: CPU Temp
entity: sensor.cpu_temp
animation: 'off'
indicator: 'off'
height: 30px
severity:
- value: 60
color: green
- value: 70
color: orange
- value: 100
color: red
title: Memory Use
entity: sensor.memory_use_percent
height: 30px
animation: 'off'
indicator: 'off'
severity:
- value: 60
color: green
- value: 85
color: orange
- value: 100
color: red
title: Disk Use
entity: sensor.disk_use_percent
height: 30px
animation: 'off'
indicator: 'off'
severity:
- value: 60
color: green
- value: 85
color: orange
- value: 100
color: red
- type: divider
- entity: sensor.public_ip_address
icon: mdi:ip-network
#=== Have I Been Pwned and Component Counts
cards:
#=== Have I been pwned
- type: entities
title: Have I been pwned
entities:
- entity: sensor.breaches_xxx
name:[email protected]
icon: mdi:at
name: [email protected]
icon: mdi:at
icon: mdi:at
icon: mdi:at
#=== Component Counts
- type: glance
title: Component Count
columns: 4
entities:
- entity: sensor.count_automations
icon: mdi:autorenew
- entity: sensor.count_scripts
icon: mdi:script-text-outline
- entity: sensor.count_zones
icon: mdi:map-marker-radius
- entity: sensor.count_device_trackers
- entity: sensor.count_switches
icon: mdi:light-switch
- entity: sensor.count_sensors
icon: mdi:resistor
- entity: sensor.count_binary_sensors
icon: mdi:unfold-more-horizontal
- entity: sensor.count_input_booleans
icon: mdi:toggle-switch
- entity: sensor.count_input_numbers
icon: mdi:numeric
- entity: sensor.count_input_texts
icon: mdi:alphabetical
- entity: sensor.count_input_selects
icon: mdi:view-list
- entity: sensor.count_input_datetimes
name: Input Date Times
icon: mdi:calendar-clock
#=== Custom Component Updates
cards:
- type: custom:tracker-card
title:
trackers:
- sensor.custom_card_tracker
- sensor.custom_component_tracker
Thank you. Much appreciated.
Nice to know, the GPU is an on-chip graphics processing unit (GPU) according to Wikipedia so temps are always going to be pretty much the same.
I’m using glances and HA dockermon.
- platform: glances
host: localhost
version: 3
resources:
- 'disk_use'
- 'disk_use_percent'
- 'disk_free'
- 'cpu_temp'
- 'processor_load'
- 'memory_use'
- 'memory_use_percent'
- 'memory_free'
- 'docker_active'
- 'docker_cpu_use'
- 'docker_memory_use'
I found glances to be very useful to monitor which addons were dogging the system on Hassio. It’s also the only way I’ve found to get the CPU temp with Hassio on an RPi. I don’t run it all the time though because I found it tended it be a bit of a resource hog itself.
configuration file: https://github.com/Limych/HomeAssistantConfiguration/blob/master/lovelace/30_system_info_view.yaml
I stand corrected thanks @klogg. This works with no muss, no fuss.
- platform: command_line
name: RPi CPU Temperature
command: "cat /sys/class/thermal/thermal_zone0/temp"
value_template: "{{ value | multiply(0.001) | round(2) }}"
@ghvader
Allow me…
It is the toggle-lock-entity-row - GitHub - thomasloven/lovelace-toggle-lock-entity-row
Look at some of @thomasloven other cards, they are all excellent.
It’s a pleasure, I wish I could say it was my idea… I forget now who I got that from.
Can you share the sensors as well ?
Also, where do you save the Rpi and HA uptime?
#=== Sensors
#=== Latest Sonoff Tasmota firmware version
name: Tasmota Current Version
command: "curl -s https://github.com/arendst/Sonoff-Tasmota/releases/latest | cut -d'\"' -f2 | rev | cut -d'/' -f1 | rev"
scan_interval: 86400
#=== Installed hass.io version
- platform: version
source: local
#=== Latest Available HA Version
- platform: version
name: Latest Available Version
beta: false
image: raspberrypi3
source: hassio
#=== Raspberry Pi Power
- platform: rpi_power
text_state: True
#=== Last boot time, Disk, memory & CPU usage
- platform: systemmonitor
resources:
- type: last_boot
- type: disk_use_percent
arg: /
- type: memory_use_percent
- type: processor_use
#=== CPU Temperature
unit_of_measurement: "°C"
value_template: '{{ value | multiply(0.001) | round(0) }}'
#=== System Up Time
- platform: uptime
sensors:
#=== Home Assistant uptime
ha_uptime:
friendly_name: HA Uptime
value_template: >
{% if states('sensor.uptime') == '0.0' %}
Just restarted...
{% macro phrase(value, name) %}
{%- set value = value | int %}
{%- set end = 's' if value > 1 else '' %}
{{- '{} {}{}'.format(value, name, end) if value | int > 0 else '' }}
{%- endmacro %}
{% set weeks = (states('sensor.uptime') | int / 7) | int %}
{% set days = (states('sensor.uptime') | int) - (weeks * 7) %}
{% set hours = (states('sensor.uptime') | float - states('sensor.uptime') | int) * 24 %}
{% set minutes = (hours - hours | int) * 60 %}
{{ [ phrase(weeks, 'week'), phrase(days, 'day'), phrase(hours, 'hr'), phrase(minutes, 'min') ] | select('!=','') | list | join(', ') }}
#=== Raspberry Pi last boot date and time
last_boot_date_time:
friendly_name: Last Boot
value_template: >
{% set date = as_timestamp(states('sensor.last_boot')) | timestamp_custom('%d') %}
{% set date = '{:01}'.format(date | int) %}
{% if date in ('1', '21', '31') %}
{% set date = date ~ 'st' %}
{% elif date in ('2', '22') %}
{% set date = date ~ 'nd' %}
{% elif date in ('3', '23') %}
{% set date = date ~ 'rd' %}
{% set date = date ~ 'th' %}
{{ as_timestamp(states('sensor.last_boot')) | timestamp_custom('%H:%M on %a') }} {{ date }} {{ as_timestamp(states('sensor.last_boot')) | timestamp_custom('%b %Y') }}
#=== Raspberry Pi Up Time
rpi_uptime:
friendly_name: RPi Uptime
entity_id: sensor.time
value_template: >
{% set up_time = as_timestamp(now()) - as_timestamp(states('sensor.last_boot')) %}
{% set minutes = (up_time // 60) | int %}
{% set hours = (minutes // 60) %}
{% set days = (hours // 24) %}
{% set weeks = (days // 7) %}
{% set minutes = (minutes % 60) %}
{% set hours = (hours % 24) %}
{% set days = (days % 7) %}
{%- set value = value %}
{%- endmacro %}
{% set text = [ phrase(weeks, 'week'), phrase(days, 'day'), phrase(hours, 'hr'), phrase(minutes, 'min') ] | select('!=','') | list | join(', ') %}
{% set last_comma = text.rfind(',') %}
{% if last_comma != -1 %}
{% set text = text[:last_comma] + ' and' + text[last_comma + 1:] %}
{{ text }}
How did you do your component count? Thats a great idea
EDIT: A much better way, courtesy of @petro is further down this thread.
Here --> System Monitoring - How does your look?
#=== Home Assistant Component counts
sensors:
#----- Count Automations
count_automations:
entity_id: sensor.date
value_template: >
{%- set domains = ['automation'] -%}
{%- for domain in domains -%}
{%- for item in states[domain] -%}
{% if loop.first %}
{{loop.length}}
{%- endfor -%}
{%- endfor -%}
#----- Count Scripts
count_scripts:
value_template: >
{%- set domains = ['script'] -%}
{% if loop.first %}
{{loop.length}}
{%- endfor -%}
{%- endfor -%}
#----- Count Device Trackers
count_device_trackers:
value_template: >
{%- set domains = ['device_tracker'] -%}
{% if loop.first %}
{{loop.length}}
{%- endfor -%}
{%- endfor -%}
#----- Count Binary Sensors
count_binary_sensors:
value_template: >
{%- set domains = ['binary_sensor'] -%}
{% if loop.first %}
{{loop.length}}
{%- endfor -%}
{%- endfor -%}
#----- Count Sensors
count_sensors:
value_template: >
{%- set domains = ['sensor'] -%}
{% if loop.first %}
{{loop.length}}
{%- endfor -%}
{%- endfor -%}
#----- Count Switches
count_switches:
value_template: >
{%- set domains = ['switch'] -%}
{% if loop.first %}
{{loop.length}}
{%- endfor -%}
{%- endfor -%}
#----- Count Zones
count_zones:
value_template: >
{%- set domains = ['zone'] -%}
{% if loop.first %}
{{loop.length}}
{%- endfor -%}
{%- endfor -%}
#----- Input Booleans
count_input_booleans:
value_template: >
{%- set domains = ['input_boolean'] -%}
{% if loop.first %}
{{loop.length}}
{%- endfor -%}
{%- endfor -%}
#----- Input Numbers
count_input_numbers:
value_template: >
{%- set domains = ['input_number'] -%}
{% if loop.first %}
{{loop.length}}
{%- endfor -%}
{%- endfor -%}
#----- Input Texts
count_input_texts:
value_template: >
{%- set domains = ['input_text'] -%}
{% if loop.first %}
{{loop.length}}
{%- endfor -%}
{%- endfor -%}
#----- Input Selects
count_input_selects:
value_template: >
{%- set domains = ['input_select'] -%}
{% if loop.first %}
{{loop.length}}
{%- endfor -%}
{%- endfor -%}
#----- Input Date Times
count_input_datetimes:
value_template: >
{%- set domains = ['input_datetime'] -%}
{% if loop.first %}
{{loop.length}}
{%- endfor -%}
{%- endfor -%}
Your memory usage if quite low compared to mine, are you using the free
command to get memory usage or some other way?
No, not as far as I know! I am running hassio on an RPi3 so even if I new Linux I wouldn’t be able to run any native commands.
Gives me this error:
Platform not found: sensor.rpi_power
you’ll have to install the component manually
