You could use the following service, tahoma.set_cover_my_position
If you want a button in the service, you could create a script or automation.
@imick, vlebourl, tetienne & jgarec thanks a lot for you excellent work.
I have a doubt: Is there any possibility to override the state of a RollerShutter in order to set “closed” from 0 to 40% and “open” above 40% without changing the core code?
I know it’s strange but as I never completly roll it down… the state keeps open forever.
Thank you again!
Abrazos,
Rafa
PS: Happy groundhog day!
I am not sure if this is possible, perhaps with a template
from core. I can tell you where to make this code change, however it would be something you need to do after every update…
Thanks Mick. That’s just what I was trying to avoid, to change any core code.
I was wondering if there was any chance to set that value from de configuration.yaml but I see that implies a development you would have to do. Just for my freackness it’s not worth at all!!
Anyway I’ll try to make a fork too see it’s viability and then I’ll share with you.
Thanks again!
Rafa
Hi, I wanted to share my progress on getting authentication to work with my Connexoon RTS in Australia.
I’m interested to know if others are experiencing the same issue (and of course if this solution works for you).
Did you change the update interval to a very high interval? That could possibly be a fix…
No, I left it at the default 30 seconds. Is that the interval you’re referring to? I wouldn’t think more frequent than that would make a difference?
See https://github.com/iMicknl/ha-tahoma/issues/369. I am not sure if this is the actual problem, but if you only use RTS devices, you could easily set it to a day or a week.
Thanks for the link to the issue. I misinterpreted high interval to be very frequent - of course you’re talking about going the other way!
I’ll give it a go!
i have no idea why, but since yesterday suddenly the whole integration stopped working.
I removed it, added it again but it doesn’t find any rolluiken anymore. i don’t know where to start… this is the only error that i see
2021-04-30 08:21:42 ERROR (MainThread) [custom_components.tahoma] __init__() missing 1 required keyword-only argument: 'last_update_time'
File "/config/custom_components/tahoma/__init__.py", line 114, in async_setup_entry
places = await client.get_places()
File "/usr/local/lib/python3.8/site-packages/backoff/_async.py", line 133, in retry
ret = await target(*args, **kwargs)
File "/usr/local/lib/python3.8/site-packages/pyhoma/client.py", line 307, in get_places
places = Place(**humps.decamelize(response))
File "/usr/local/lib/python3.8/site-packages/pyhoma/models.py", line 515, in __init__
self.sub_places = [Place(**p) for p in sub_places] if sub_places else None
File "/usr/local/lib/python3.8/site-packages/pyhoma/models.py", line 515, in <listcomp>
TypeError: __init__() missing 1 required keyword-only argument: 'last_update_time'
Which version of the component have you installed? We fixed this last week.
HACS = 1.12.3
tahoma integration = 2.4.9 ← but im not sure, i see this when i click on “information” but i also already did a “reinstall”
The version 2.4.10 is the latest and fix your issue.
hmm, why doesn’t it show up then when i do an upgrade?
here it also says 2.4.9 as the latest.
We forgot to publish it It’s OK now.
ah:) rebooting now!
solved thanks!
Firstly thanks to all the devs for the great work on this. I have an issue with actions being logged in the logbook. This used to work but on an unrelated issue I recreated the database and now don’t see any actions for my blinds in the logbook, e.g. a call to open or close from the Lovelace card. I’ve created a new test system with only this integration, same result. My config YAML has the recorder and history lines included to trap everything (and also tried with just the default config YAML). Can’t think of anything else so hoping the experts can help! Many thanks.
