Tapo P110M Energy Monitoring
Hi @TexTown ,
Might I ask how could you add the Tapo P110M to Home Assistant? Via Matter?
I tried to commission the Tapo to Home Assistant but the Matter Server Addon keep rebooting after giving an error ( Verify or Die…)
I use the same stuff like yours( HA 2024.6 and the Tapo P110M version 1.1.0 Build 231009 Rel. 155719).
Yes, I used HA (mobile app) to add the device. But that was long ago, many versions before the current version. It worked without issues
Can you share the logs when this is happening?
I tried to commission it again to get the log for you. Out of nowhere, it worked. The Matter Server Add-on version is 6.1.2, the Home Assistant Core version is: 2024.6.3
Hmm, I guess problem is at the Tapo itself. I haven’t updated anything.
Anyway, thanks for your attempt to help!
New firmware for the Tapo P110M is out, unfortunately it doesn’t mention any Matter or energy monitoring improvements in the release notes.
I’ve updated the device throug the Tapo app to version V1_1.2.3 Build 240617. Nothing changed in HA, still only the switch entity…
The Matter 1.3 Energy Management clusters are not yet supported in Home Assistant, so it could be just that.
You can check if the device exposes the Energy Management cluster by Browsing the device in the Matter Server add-on Web UI. Check the Endpoint 1. If there are only OnOff/Descriptor and a couple other non-energy measurement named clusters, then the firmware does not support the new Energy Management clusters.
Here’s a screenshot of the exposed clusters. One is called Custom/Unknown but nothing with Energy Measurement in its name.
I’ll keep an eye on PR’s for the Matter Add-on to find out if and when Energy management gets merged. Thank you!
If it helps to send more info about the device, let me know.
@TexTown Please let us know when it’s working properly. I want to buy a few of them also to replace the old HS110 model (which must be reset every once in a while because they got offline).
So looking at the new matter specifications, the two new respective clusters are 0x0090 for “Electrical Power Measurement” and 0x0091 for “Electrical Energy Measurement”, neither are available when seen in the Matter Web UI for a device updated to 1.2.3, even after re-interviewing.
Just a bump mail to add my voice to hoping the energy monitoring gets added. Here in AU there are very few legally certified smart plug (with monitoring) options, and none that operate locally AFAIK.
The tapo is from a known brand, has a 2-year warranty suggesting it might be better built than others that last only weeks or months, is RCM approved, is of a form factor that does not block adjacent plugs, has the manual button on top where it is accessible, and in matter form should be completely local.
I recently got a non-matter P110 to replace one of many failed Arlec units but I don’t like having to use the Tapo web service for them to work. Hence I’d prefer the P110M’s, but do not want to go buying a few until we know the power monitoring is going to work.
Am in same boat as you. That said, there seems to be a new Ikea smart plug with energy monitoring coming out in October. Don’t know much more than that though.
The power monitoring works locally via the TP-link integration. (It actually provides a lot more features over it’s proprietary API than Matter.)
But be assured, once the P110m get’s an update to improve their minimal Matter support, I probably personally implement that feature in HA. :slight_smile:.
Same issue in Japan, the only other plug I can use locally are the ones from SwitchBot. I got 6 of them reboot randomly before being stuck in a boot loop after 1 or 2 days. I am glad some of them are under warranty but 6 plugs failing?!
I bought the Tapo P110M to start to replace them. Matter configuration failed, factory reset and tried again and it work. As mentioned above, no update detected and no energy monitoring yet.
Started the Tapo app which detected the plug, Hone assistant detected the plug too as a Tapo one and I can use energy monitoring from there.
@SeraphicRav Thanks, I am looking for a replacement for my >4 failing switchbot plugs too. I read in your comment that you had to open? the app to properly use energy monitoring, does it mean that P110M energy monitoring works locally now? Or you need to keep the app open?
Hi, Hoping I can help you @trimethia .
2 options
Use Matter to pair everything in Apple Home (or another smart home platform), and then, using the pairing code in the smart home platform, add them to Home Assistant.
Though currently, it does not send any power monitoring, as TP-Link currently does not support this (though the matter standard does support it. It works for my Eve Smart Switch, but I don’t like them as too big and bulky)
  • Use the app to set up the smart switch, creating a TP account. Then, use this TP account to set up the component in HA, and you get power monitoring. You can then share back with your smart home platform (e.g., Apple HomeKit from Home Assistant). You don’t need to open the app again; just control from the HA or Smart Platform.
I hope that helps.
I currently have four of the new TP-link devices TP110M (all set up by Matter and the TP app; once they support Matter power monitoring, I will stop using the app). I only have three of the old Kasa TP smart switches, which will need to stay in the app as no matter support.
Thanks @mgguinne ! So currently the only option for getting energy consumption is via TP-link cloud integration, not locally ?
If so, I think I will wait until Tp-link enables local energy consumption via Matter locally (hoepfuly with a future firmware update?)
I have a Meross mini smart plug that’s supports matter and energy monitoring here in the UK so watching this thread with interest.
My 30 or so ZigBee plugs drop off occasionally even with 2 extra routers and a relatively clear channel so I’m really hoping matter solves this.
Matter seems to be moving but slower than ideal.
Yep, that’s correct, @trimethia; I would get them when they go on sale via amazon (I got mine for about $20 each). I am fairly sure the firmware upgrade will come. Though I know the rule of not buying something awaiting a feature to come IN THE FUTURE!!!
https://www.amazon.com.au/gp/product/B0CN2SWP7C
Setup a price watch via:
https://au.camelcamelcamel.com/product/B0CN2SWP7C
Here is a screen of mine
CleanShot 2024-09-04 at 08.26.16
Also as per this post above from @TexTown , the best place to know when this is released is to follow their firmware updates page.
mgguinne perfectly answered your question :smiley:
For all those commenting about asking for matter energy monitoring support, note that it’s not actually home assistant blocking this but tp-link, they need to update the firmware.
I would suggest chiming in on this forum post here: Tapo P110M update for Matter 1.3 - TP-Link Community
Tp-link have responded but haven’t been very committal. I’d suggest bumping the forum post!
