I’m currently thinking about which method is better for reacting to button presses in automations. Recently, my Shelly input entities are created as type event. With MQTT I can only use a device trigger. Alternatively, I can a template trigger. Device triggers have the disadvantage that you can’t identify the device anymore based on the ID. So what’s the better method for Homassistant here?
alias: UI_Studio_Licht2
description: ""
triggers:
- trigger: state
entity_id: event.dg_st_i02_b01
attribute: event_type
to: single_push
actions:
- action: light.toggle
entity_id: light.dg_st_l03
data: {}
mode: single
NOTE
Didgeridrew’s example employing a State Trigger is superior, especially if you need the ability to detect consecutive, identical button events (like two consecutive single-press events). The version I posted will detect the first single-press but not another one until it first detects some other button-event. EDIT It has the same drawback as the second example you posted employing a Template Trigger.
Which trigger type you choose (Device, Template, State, MQTT) depends on what you consider to be easier to maintain.
Device Triggers have the following drawback: if the device ever fails, when you replace it, the replacement will be registered with a new unique device_id value. As a consequence, the automation’s Device Trigger will no longer work because it still refers to the old device’s device_id.
When you replace the device, you are likely to maintain the same entity names. So automations using triggers that refer to an entity by its entity_id are more likely to continue to work without modification.
If you have a large number of buttons (or many 4 gang switches) its easier to use MQTT “action” events - but the setup (code to process the events) for that is more significant, so it isn’t worth it for only one or two buttons.
Are you even using MQTT “Action” events - i.e. directly listening to the action topic. I haven’t seen any reference to that in your previous posts in this thread.
If we are talking about the the kind of trigger used in Didgeridrew’s example, where a State Trigger is monitoring a remote’s event entity (ostensibly created via Zigbee2MQTT version 2.0+) then the answer is yes.
If we are talking about an MQTT Trigger listening to the remote’s MQTT topic, like in your example, then no.
I didn’t explicitly indicate which trigger type I use until you quoted me and suggested MQTT “action” events require significant more “setup” therefore not worth it for one or two buttons. Had you not quoted my post, I wouldn’t have replied with my clarification.
My reply was the first indication (in this thread) that I use that type of trigger for all of my remotes, regardless of how many buttons they have. Originally, I used a State Trigger with a remote’s now-deprecated sensor entity. In my experience, it was a fairly simple transition to the event entity.
I need the ability to detect consecutive identical button events (like a double-press of on) and some of the triggers shown above are not fit for this purpose. Depending on the OP’s needs, it may influence which trigger they should consider using.
Okay let me be clear
If you have hardware that manages the different types of button press for you - hence generates distinct MQTT events for:
Single
Double
Hold
Then you have a choice of multiple methods for handling those events:
You can use the device_id style trigger (OP Version 1)
I haven’t used the OP’s “template” based approach, however it will assume it’s working for the OP.
You can directly listen to the action topic (my approach)
I quoted your response:
Because I agree with it.
Simply put if, you only have one button in your house, don’t spend time trying to develop a generic approach.
However if you want to handle 72 (my case) events with a single automation then it’s worth putting in the time to figure out a clean way of handling that - and I would recommend listening to the action topics.
For me developing an approach to do that was “more significant”, I feel it was worth it - since ongoing maintenance is near zero, for example:
Swapping out hardware doesn’t require any changes in HA - I just name the replacement device the same in Z2M.
Duplicating a switch (adding a new switch that functions the same as an existing switch) is a few lines in HA
I realize that others may feel my design is overkill - which is what I was trying to acknowledge by quoting you.
Thanks for the clarification. I agree it would take effort and planning to develop a single automation to detect 72 events but the payoff is one clean centralized event handler. More work up front but easier maintenance afterwards.
FWIW, earlier I mentioned some types of triggers are not fit for the purpose of detecting consecutive identical button-events (like two on events). For anyone interested the types of trigger that can detect them are:
Device
MQTT
State (listening to an event entity’s state)
The ones that cannot:
Template
State (listening to an event entity’s event_type attribute)
