i have inside the config folder. i have a docker installation in my NAS
Must I do anything with the pytatmo library?
Thanks in advance
According to the above quoted message, your modules in the custom_components
are NOT loaded (still using the standard ones). I am using docker
and it works fine.
I have see that the folder custom must be custom_component and I have custom-component but now I have this error log:
Log Details (ERROR)
Sat Dec 29 2018 00:05:59 GMT+0100 (hora estándar de Europa central)
Error while setting up platform netatmo
File “/usr/src/app/homeassistant/helpers/entity_platform.py”, line 128, in _async_setup_platform
SLOW_SETUP_MAX_WAIT, loop=hass.loop)
File “/usr/local/lib/python3.6/asyncio/tasks.py”, line 358, in wait_for
return fut.result()
File “/usr/local/lib/python3.6/concurrent/futures/thread.py”, line 56, in run
File “/config/custom_components/climate/netatmo.py”, line 71, in setup_platform
for home in home_data.get_home_names():
File “/config/custom_components/climate/netatmo.py”, line 291, in get_home_names
self.setup()
File “/config/custom_components/climate/netatmo.py”, line 301, in setup
self.homedata = pyatmo.HomeData(self.auth)
AttributeError: module ‘pyatmo’ has no attribute ‘HomeData’
Can I delete the component folder?
Must I install any pytamo.py component?
Thanks in advance
I’m also using HA in synology nas docker.
You must do this:
then, in climate.yaml you must have this:
- platform: netatmo
of course, in configuration.yaml, also you must have netatmo config:
netatmo:
api_key: !secret netatmo_api_key
secret_key: !secret netatmo_secret_key
username: !secret netatmo_username
password: !secret netatmo_password
discovery: false
and this, works fineh with ha 84.2 in docker synology
Under config/deps/lib/python3.6/site-packages/
: there should be:
pyatmo.py
pyatmo-1.*.dist-info/
smart_home/
__pycache__/
Please try to remove all of them, and try to restart HA, to see if the correct one can be installed automatically.
Now it works like a charm!!!
Thank you for your help.
In my NAS Synology the only difference it is that I have python 2.7 folder not 3.6.
Can I install Python 3.6?
And I have another Vaillant thermostat that I want to integrate it.
As you can see in this post:
it uses the same pyatmo library but it doesn´t work.
Can you help me?
thanks in advance.
Thanks, now it works!!!
Have been waiting for this a long time. Installed and now i have control of 8 valves in 5 rooms, Thanks
hello the thermostat works perfectly, but I have a problem, when I restart the hassbian component is not loaded not showing me the thermostat, I need more reboots to make it work, I also tried to remove the file in the pycache folder but I always the same problem, how can I solve?
Do you have any errors in your log?
yes, this is the error
2019-01-06 11:31:07 ERROR (MainThread) [homeassistant.components.climate] Error while setting up platform netatmo
File “/srv/homeassistant/lib/python3.5/site-packages/homeassistant/helpers/entity_platform.py”, line 128, in _async_setup_platform
File “/usr/lib/python3.5/asyncio/tasks.py”, line 400, in wait_for
return fut.result()
File “/usr/lib/python3.5/asyncio/futures.py”, line 293, in result
raise self._exception
File “/usr/lib/python3.5/concurrent/futures/thread.py”, line 55, in run
File “/home/homeassistant/.homeassistant/custom_components/climate/netatmo.py”, line 74, in setup_platform
for room_id in room_data.get_room_ids():
File “/home/homeassistant/.homeassistant/custom_components/climate/netatmo.py”, line 327, in get_room_ids
if self.setup():
File “/home/homeassistant/.homeassistant/custom_components/climate/netatmo.py”, line 338, in setup
self.homestatus = pyatmo.HomeStatus(self.auth, home=self.home)
File “/srv/homeassistant/lib/python3.5/site-packages/smart_home/Thermostat.py”, line 120, in init
self.rawData = resp[‘body’][‘home’]
KeyError: ‘home’
I guess it was just communication issue with the HTTP request, but not very sure. You could try to replace /srv/homeassistant/lib/python3.5/site-packages/smart_home/Thermostat.py
by the following revision (I added retrying). Don’t forget to remove /srv/homeassistant/lib/python3.5/site-packages/smart_home/__pycache__
before restarting.
not work…after a restart the thermostat not in the frontend…
How can I solve this problem?
Without the log information, I cannot know what the problem is.
How should I extract the log information?
The log information regarding to this.
for me work and i already inserted in homekit by apple
You did it last time I think. The same way.
