Helo, thanks @Baosong_Shan for component, I got some issue after set the config which you describe here. API Test pass correct - I got json data with my details.
My configuration:
climate:
- platform: netatmo
home: Mój dom
rooms:
- Salon
netatmo:
api_key: xxx
secret_key: xxx
username: xxx
password: xxx
All python script files are in correct folders.
This is the error from logs:
2019-01-28 18:29:29 ERROR (MainThread) [homeassistant.components.climate] Error while setting up platform netatmo
File “/home-assistant/homeassistant/helpers/entity_platform.py”, line 128, in _async_setup_platform
SLOW_SETUP_MAX_WAIT, loop=hass.loop)
File “/usr/lib/python3.5/asyncio/tasks.py”, line 400, in wait_for
return fut.result()
File “/usr/lib/python3.5/asyncio/futures.py”, line 293, in result
raise self._exception
File “/usr/lib/python3.5/concurrent/futures/thread.py”, line 55, in run
File “/root/.homeassistant/custom_components/climate/netatmo.py”, line 74, in setup_platform
for home_conf in config.get(CONF_HOMES):
TypeError: ‘NoneType’ object is not iterable
return fut.result()
hi there,
i have followed procedure to configure netatmo2 climate and seems that is not working, here my log:
ImportError: cannot import name 'STATE_HEAT' from 'homeassistant.components.climate' (/usr/local/lib/python3.7/site-packages/homeassistant/components/climate/__init__.py)
2019-03-15 18:44:52 ERROR (SyncWorker_7) [homeassistant.loader] Unable to find platform netatmo2. Search path was limited to path of component: custom_components
2019-03-15 18:44:52 WARNING (SyncWorker_7) [homeassistant.helpers.config_validation] Your configuration contains extra keys that the platform does not support.
Please remove [name].
A question from a total newbie:
Does one have to bye the starter kit with bridge, for starters ? https://shop.netatmo.com/dkk_dk/starter-pack.html
I will only use radiator valves, as of our building has district heating
As far as I’ve seen, yes, the valves only communicate with the bridge and you connect to the bridge, same as the thermostat only communicates with its (yet another) bridge and you connect to its bridge.
How would I go about getting the active schedule on the thermostat? That’d be helpful for automation, specifically lights and climate control, based on the selected schedule (say when the occupants do shift work and use a specific schedule).
I’d like to confirm that netatmo stopped working in 0.92
It seems liek after a restart only netatmo climate is affected.
This is what I get:
File "/usr/local/lib/python3.7/site-packages/homeassistant/helpers/entity_platform.py", line 126, in _async_setup_platform
File "/usr/local/lib/python3.7/asyncio/tasks.py", line 416, in wait_for
return fut.result()
File "/usr/local/lib/python3.7/site-packages/homeassistant/components/netatmo/climate.py", line 94, in setup_platform
for room_id in room_data.get_room_ids():
File "/usr/local/lib/python3.7/site-packages/homeassistant/components/netatmo/climate.py", line 342, in get_room_ids
if not self.setup():
File "/usr/local/lib/python3.7/site-packages/homeassistant/components/netatmo/climate.py", line 352, in setup
self.homedata = pyatmo.HomeData(self.auth)
File "/config/deps/lib/python3.7/site-packages/smart_home/Thermostat.py", line 30, in __init__
self.getAuthToken = authData.accessToken
AttributeError: 'NoneType' object has no attribute 'accessToken'
