Testing new integration - Brother Printer
I wrote integration for Brother Printers (laser and inkjet). Component is almost stable but it needs some testing with devices other than mine HL-L2340DW.
The beta testing stage has been completed.
Please remove integration and component’s files before update HA to version 0.104.
Hi - good news for you and for me of course :slight_smile: HL-L2350DW works like charm! Thank you for your work!
Cool! I’ve got a MFC9130CW and will try to test the integration this weekend and report back.
Works well
New version available: beta 02
Please remove integration before update the components!
I just installed it, and it works great! Absolutely flawless install with my MFC-9130CW! Thank you!
Now to figure out a good way to auto order toner…
Hi, I just send you a french translation for your component.
Thanks for your work :wink:
Thanks. Now I will try add component to official HA repository. You will have to add translated strings (via lokalise.co) once again when it will be merged.
I also add spanish version.
MFC-L2740DW - works OK, shows Status, Pages, Toner% and Drum%
Works! I had problems with toner levels in my own script.
Thank you!!!
Bart
It’s works well with my Brother HL-L2375DW.
2019-12-11-234653_501x290_scrot
No one tried this with an Inkjet yet?
I will be, probably at the weekend.
@Bieniu I know you specifically include Inkjets in your introduction so I assume there is no expectation that it won’t work?
Integration was tested with one inkjet printer model (don’t remember which one) and there were no problems.
Tested on HL-L2350DW works great! Thanks!
Works perfectly on HL-3170CDW. Great job :ok_hand:
That works awesome! Time to add it to HACS!
Verifying against data reported by the printer, looks close enough.
Via SNMP printer gives two values for every toner. One is rounded to 10% (WWW panel uses this value) and one rounded to 1% (integration use this value).
I’m trying to add this integration to main HA repository (not HACS).
New beta available: https://github.com/bieniu/ha-brother/releases/tag/beta-04
Please remove integration before update!
I added a MFC-J6720DW and it worked fine
