cweakland
(Chris)
April 26, 2019, 11:28am
2298
I am trying to load the following image in an iframe but it does not work:
position: [1, 0],
type: TYPES.IFRAME,
width: 3,
height: 3,
refresh: 10000,
url: 'http://sirocco.accuweather.com/nx_mosaic_640x480_public/sir/inmasirva_.gif'
Can you share with me the code you are using to display a internet hosted gif image?
david1
(David)
April 27, 2019, 4:38am
2299
i have a sensor that sends over my beer level as an integeter
is there a way to add an icon?
do i need to import pictures from the material design page somewhere? https://materialdesignicons.com/cdn/1.0.62/
position: [0, 1],
type: TYPES.SENSOR,
title: 'Tap1',
icon: 'mdi-beer',
unit: '%', // override default entity unit
state: false, // hidding state
filter: function (value) { // optional
var num = parseFloat(value);
return num && !isNaN(num) ? num.toFixed(1) : value;
david1
(David)
April 27, 2019, 4:50am
2300
how did you get the spotify picture to display what is playing?
You need to add the following line inside the items
bgSuffix: '@attributes.entity_picture'
Then it will look like the following:
title: 'Media',
width: 2,
height: 3.4,
items: [
position: [0, 0],
height: 3,
width: 3,
type: TYPES.MEDIA_PLAYER,
hideSource: false,
hideMuteButton: false,
state: false,
subtitle: '@attributes.media_title',
Thank you!. Just answered this here
Best!
Hey, I’m trying to pass the light value in RGB but with no luck. Any ideas?
customStyles: {'backgroundColor' : 'rgb(' + '&light.living.attributes.rgb_color' + ')'}
Thanks!
david1
(David)
April 27, 2019, 11:51pm
2305
how do you get a entity to show a picture? someone above had lights
Well, this works:
customStyles: function (item, entity) {
return { 'backgroundColor' : this.states['light.living'].state === 'on' ?
'rgb(255,255,255)' : 'rgb(255,0,0'};
But what I need is to change the background based on the actual light RGB colors, then, this does not work:
'rgb(&light.living.attributes.rgb_color)' : 'rgb(255,0,0'};
I guess is because the attributes are coming in a different format. I know that variable brings the colores, I have debugged, but for some reason it seems I need to turn the string in numbers. I’m not sure why it does not work.
I guess I know why. The colors comes in an array and I need to parser them into a string. I will do the trick with some JS and I will keep it posted here.
Done.
var rgb = entity.attributes.rgb_color.toString();
return {
'backgroundColor' : this.states['light.living'].state === 'on' ? 'rgb('+ rgb + ')' : '#7a4e7f'
david1
(David)
April 28, 2019, 4:34am
2311
so how i do you replace the background with a picture?
david1
(David)
April 28, 2019, 4:48am
2312
where did you get the frame?
resoai
(Alexey)
April 29, 2019, 9:56am
2313
I glued together UPVC angle trim pieces with superglue, filled in the gaps with the very same glue and painted it. I’d never do that again.
cweakland
(Chris)
April 29, 2019, 6:03pm
2314
I figured out my issue, I am accessing Tileboard over HTTPS and the java script will not load mixed content, simply changing the destination URL to httpS resolved the problem.
tman75
(Troy )
April 30, 2019, 1:56pm
2315
Tweaks to weather list.
Hi. I looked through main.less and main.css but I can’t figure out how to change somethings. Could someone point me into the right direction? Not sure if I need to modify one of those files or custom.css.
Trying to do the following.
Have the weather list display high temp first, then low temp (currently it is low then high)
Have division be a / rather than a -
Have high be red, and low be blue.
Have temp be rounded to nearest whole number…not 10th of decimal.
Thanks.
apop
April 30, 2019, 2:26pm
2316
If you haven’t already, take a look at the example in https://github.com/resoai/TileBoard/blob/master/TILE_EXAMPLES.md .
Specifically, this is the portion you’ll want to look at to reverse the high and low, make the separator a /, and round the temp:
var forecast = "&sensor.dark_sky_overnight_low_temperature_" + id + ".state - ";
forecast += "&sensor.dark_sky_daytime_high_temperature_" + id + ".state";
forecast += "&sensor.dark_sky_daytime_high_temperature_" + id + ".attributes.unit_of_measurement";
As currently configured, index.html would likely have to be modified to handle changing the high/low colors independently.
gsksim
April 30, 2019, 5:54pm
2317
are you trying to build an enclosure for wall mount?
resoai
(Alexey)
April 30, 2019, 7:09pm
2318
I’m not trying, I’ve already done it
