TileBoard - New dashboard for Homeassistant
If you’re positive that it happens with config.js empty then I don’t know, but if it’s possible you’re mistaken there then this is an easy fix. It’s the fake climate tile in the default config file trying to update but not having a real climate element, if you search for ‘Heating’ in the sample config you’ll find the exact tile causing it.
Hi Marcok,
This looks great, great work and just what I have been looking for.
Is there anyway you could let me know how to get this working in Tileboard?
Kind regards
Hi all
I am using z’n Aqara switch to switch on/off 2 seperate lights in the kitchen.
Using 2 different automation scripts to be able to use this in TileBoard. I could not find another way.
Is it possible to have the status of the lights shown I the tile? See yellow marked tiles. Like the one marked with green.
Or even better: can this be done with 1 tile?
I just installed this on my rpi, but 2 things happen, or don’t that I expected. I don’t get asked for my password, and it can load the index, but then cannot find the css or app…js files.
address: http://192.168.86.xx:8123/local/tileboard/index.html/
GET http://192.168.86.xx:8123/local/tileboard/index.html/styles/styles-b3719938.css net::ERR_ABORTED 404 (Not Found)
192.168.86.xx/:31 GET http://192.168.86.xx:8123/local/tileboard/index.html/styles/custom.css net::ERR_ABORTED 404 (Not Found)
192.168.86.xx/:40 GET http://192.168.86.xx:8123/local/tileboard/index.html/scripts/app-ac55b6b9.js net::ERR_ABORTED 404 (Not Found)
favicon.png:1 GET http://192.168.86.xx:8123/local/tileboard/index.html/favicon.png 404 (Not Found)
Hey, is there a website/repo where to upload and download custom themes and personalisations for Tileboard?
You do not need an extra slash
should be ok
Quick question on the TILES.POPUP. By default it is only possible to display an icon in the center of the tile.
For some buttons (POPUP) I would like a state and/or value instead of an icon like TILES.SENSOR has.
Any ideas where to change this?
Hello benalla,
Based on the state of an entity, you can execute a script. I use TYPES.SWITCH for this
action: function(item, entity) {
	var action = 'binnenverlichting_turn_on'; //script lights on
	if(this.states['input_boolean.binnenverlichting'].state == 'on') { //condition check, if lights are on, change action to "lights out"
	action = 'binnenverlichting_turn_off'; //scripts lights off
	// call actual service in HA
	this.apiRequest({
	type: 'call_service',
	domain: 'script',
	service: action
For the layout, I personally use different icons and color of the tile;
icon: function() {
	if (this.states['input_boolean.binnenverlichting'].state == 'on') return 'mdi-lightbulb-on-outline';
	else return 'mdi-lightbulb-off-outline';
customStyles: function (item, entity) {
	if (this.states['input_boolean.binnenverlichting'].state == 'off') {
		return {'background-color': '#b33d3d'};
		else {
		return {'background-color': '#4e7f6a'}
Short Info: Home Assistant OS on Intel NUC - SSL via lets encrypt - dyn DNS - works great!
I have a wall mounted Amazon Fire HD10 Tablet with fully kiosk Browser and Tileboard.
I can access the tileboard url with my pc there are no problems but i can’t access this url with fully kiosk browser on my tablet.
Unfortunately, I have no more ideas what to try.
Hope you guys can help me out with some ideas
Thanks in advance :slight_smile:
what url are you using?
And please tell me you are not exposing your tileboard url to the internet
https://dyndns:8123/local/tileboard/index.html
When i use the internal ip i can’t access home assistant :slight_smile:
i don’t know how to fix that :frowning:
Ok, do NOT expose tileboard to the internet. When someone finds it, they will be abel to control your devices if you have set a token.
Instead, either set tileboard on a different server or use the Addon.
The addon uses port 80, but you can set a port (8090) so that you can browse to http://<ip_ha>:8090
Remove tileboard from you local.
Yes, i know thats not a good solution, but i only want to try out tileboard :slight_smile:
is there a addon for tileboard?
Which Addon do you mean?
The TileBoard Addon :slight_smile:
Add this to your config.yaml:
homeassistant:
  internal_url: "http://\<ipaddresHA>:8123"
  external_url: "https://dyndns"
That way you can access home assistant with your local IP adress on your local network
Ah ok nice thank you :slight_smile:
i moved the folder “tileboard” from “www” to “config”.
my problem now is when i configure the addon:
Config file not found. Setting up an example config.
configFolder: /config/tileboard/ in the addon.
:rofl:
only tileboard should be ok
when i take /config/tileboard/ as path he only opens an example from tileboard.
when i only write tileboard:
File “/etc/tileboard/symlink-config.py”, line 28, in
main(args[1], args[2])
File “/etc/tileboard/symlink-config.py”, line 20, in main
symlink(path.join(dirpath, filename), path.join(filename_dest_dir, filename))
FileExistsError: [Errno 17] File exists: ‘/config/tileboard/index.html’ → ‘/var/www/tileboard/./index.html’
now i’m confused :smiley:
With add-on tileboard directory must only contain config.js and custom.css.
thank you very much for you answer that solves the problem!! :slight_smile:
can you pls share your code?
