What this does
It allows you to toggle a scene on and off with a single input. Without this blueprint, there is no easy way to 'undo' a scene activation in home assistant. If you think that this should be the default behaviour in HomeAssistant then vote here
How it works
When triggered it saves the current state as a new scene scene.my_scene_store_previous_state before then activating the scene e.g scene.my_scene. When triggered again it simply activates scene.my_scene_store_previous_state. It alternates between the 2 by seeing which of scene.my_scene_store_previous_state & scene.my_scene was the last to be triggered.
Once the timeout has passed since scene.my_scene was activated it assumes a new session has started and will start by saving the state and activating scene.my_scene. Even if it was due to activate scene.my_scene_store_previous_state next.
After a restart the first activation will always be to implement scene.my_scene as the pre-scene state is lost at restart.
Of course if the state before you activate the scene is identical or similar to the scene then it will toggle between 2 identical states and you won't notice any difference.
Requirements
- At least one scene
- A second automation to trigger this one.
How to uses
- Click the link below to import the blueprint and create it with the desired settings.
- Run it by calling the service
Automation: Triggerfrom automations, UI buttons or the developer tools. - More advanced users can fire an event. The automation listens for a custom event
event: scene_toggle
event_data:
entity_id: scene.my_scene
Change log
2022-11-24 Version 1.0
Help wanted - I do not know how to do these things
- Allow the user to specify triggers and conditions within the blueprint - How to have user configurable triggers and conditions in blueprints?
- Create a helper within the blueprint to store the state and toggle Extend Blueprints to include Helpers, multiple Automations/Scripts and Lovelace - #21 by brianewman
- Allow the user to listen for events as a trigger. There doesn't seem to be an events input for blueprints
- It may be more elegant to check if the current device states match the scene and then decide whether to toggle on or off based on that. I am not sure on how to achieve this though.
