Tracking Injections for Diabetic Cat
Kitty Shot Tracker
This project creates a sensor to track whether my wife or I (or anyone else) have given our diabetic cat his shot twice a day. We were constantly yelling across the house to check if the other person had given the shot because we were so worried about doubling up his dose. (Very dangerous). I realize this is a highly specific case use, but almost every project I’ve ever done of this nature has been born out of seeing someone else’s barely related or seemingly unrelated project and being inspired or enabled through their experience to create something that works for me. I hope this helps someone in that way. I have no programming experience, so I would not be surprised if programming best practices are not in play here, and for that I ask your forgiveness.
Home Assistant Helpers
I used HA’s helpers to set up three input_boolean entities. I created these in the UI by going to Configuration/Helpers and clicking the add button, then “Toggle.” I then added a name, in my case “Kitty Shot Husband”. I repeated this process twice more and named the input_boolean entities “Kitty Shot Wife” and “Kitty Shot Someone”. These entities will be used as input components in my final sensor.
configuration.yaml
There are two sections that have to be added to configuration.yaml for this tracker:
Template Sensors
There are a couple of things going on here. First of all, there is the kitty_shot template which is outputting text based on the state of the input_boolean entities that we created in the last step. I will create automations later that will not allow any of the input_boolean entities to be on at the same time, but this is the main component of the sensor.
# configuration.yaml
##########Kitty Shot Sensors##########
  sensors:
    kitty_shot:
        value_template: >
            {% if is_state('input_boolean.kitty_shot_husband', 'on') %}
                Husband gave kitty his shot.
            {% elif is_state('input_boolean.kitty_shot_wife', 'on') %}
                Wife gave kitty his shot.
            {% elif is_state('input_boolean.kitty_shot_someone', 'on') %}
                Someone gave kitty his shot.
            {% else %}
                Kitty needs his shot.
            {% endif %}
Next, this is a template sensor to be used as a component to check to see who gave the shot, and notify the other person that it has been given. I will get more into this later.
  sensors:
    kitty_shot_notify:
        value_template: >
                mobile_app_wife_iphone
                mobile_app_husband_iphone
            {% else %}
                Null
            {% endif %}
Actionable Notifications
This part of the project requires that you have set up actionable notifications. I had some trouble doing this when I first did it for another project, but it’s fairly well documented here: https://companion.home-assistant.io/docs/notifications/actionable-notifications/
ios:
  push:
    categories:
      - name: Kitty Shot
        identifier: 'kittyshot'
        actions:
          - identifier: 'WIFE_SHOT'
            title: 'Wife shot kitty.'
          - identifier: 'HUSBAND_SHOT'
            title: 'Husband shot kitty.'
          - identifier: 'REMIND_SHOT'
            title: 'Remind me in an hour.'
      - name: Someone Shot Kitty
        identifier: 'kittyshotsomeone'
        actions:
Automations
I created nine automations for this project, and I’ll do my best to explain them and the logic behind them:
Shot Needed Notifications
The first few automations send the actionable notification at prescribed times, which vary slightly between weekdays and weekends. (Don’t judge us wanting an extra hour of sleep on weekends!)
# automations.yaml
- alias: Kitty Shot Tracker - Push Notification - Weekdays
  description: ''
  - at: 07:30:00
    platform: time
  - at: '19:30:00'
    platform: time
  condition:
  - condition: time
    weekday:
    - mon
    - tue
    - wed
    - thu
    - fri
  - condition: state
    entity_id: sensor.kitty_shot
    state: Kitty needs his shot.
  - data:
        push:
          category: kittyshot
      message: Have you given kitty his shot?
      title: Time for kitty's shot!
    service: notify.mobile_app_husband_iphone
  - data:
        push:
          category: kittyshot
    service: notify.mobile_app_wife_iphone
- alias: Kitty Shot Tracker - Push Notification - Weekends
  description: ''
  - at: 08:30:00
    platform: time
  - at: '19:30:00'
    platform: time
  condition:
  - condition: time
    weekday:
    - sat
    - sun
  - condition: state
  - data:
        push:
          category: kittyshot
  - data:
        push:
          category: kittyshot
Other Automation Components
This next set is pulling triple duty. The automation is run if the boolean switch is turned on manually (through the card UI) or if the actionable notification is fired. These automations also prohibit any of the three switches from being on at the same time.
# automations.yaml
- alias: Kitty Shot Tracker - iOS Response - Wife
  description: ''
  - entity_id: input_boolean.kitty_shot_wife
    platform: state
    to: 'on'
  - event_data:
      actionName: WIFE_SHOT
    event_type: ios.notification_action_fired
    platform: event
  condition: []
  - data: {}
    entity_id: input_boolean.kitty_shot_husband
    service: input_boolean.turn_off
  - data: {}
    service: input_boolean.turn_on
  - data: {}
    entity_id: input_boolean.kitty_shot_someone
- alias: Kitty Shot Tracker - iOS Response - Husband
  description: ''
  - event_data:
      actionName: HUSBAND_SHOT
    platform: event
  - entity_id: input_boolean.kitty_shot_husband
    platform: state
    to: 'on'
  condition: []
  - data: {}
  - data: {}
  - data: {}
This automation sends the reminder notification again in one hour. This is useful if no one is home or available to give the shot at the moment, and we need to be reminded later. I decided not to do an arriving home trigger in case we were already home, but unable to get to it right that moment.
# automations.yaml
- alias: Kitty Shot Tracker - iOS Response - Remind me in an hour
  description: ''
  - event_data:
      actionName: REMIND_SHOT
    platform: event
  condition: []
  - delay: 01:00:00
  - data: {}
    entity_id: automation.kitty_shot_tracker_push_notification_weekdays
    service: automation.trigger
I set up this automation to use with an Amazon Echo Button that we had lying around. If one of us gives the cat his shot while we don’t have our phone handy, we can just push the echo button which is linked to the input_boolean.kitty_shot_someone entity through an Alexa routine. Because it could be either of us (or a cat sitter), we settled on the terminology “Someone.” Both of us will be alerted if this button is pushed.
# automations.yaml
- alias: Kitty Shot Tracker - Notify that shot has been given by "SOMEONE"
  description: ''
  - entity_id: sensor.kitty_shot
    platform: state
    to: Someone gave kitty his shot.
  condition: []
  - data_template:
        push:
          category: kittyshotsomeone
      message: '{{ states(''sensor.kitty_shot'') }}'
      title: Kitty has been shot!
  - data_template:
        push:
Shot Given Notifications
This automation uses the kitty_shot_notify sensor I set up at the beginning in configuration.yaml to check and see who gave the cat his shot, and notify the other person so we don’t double up.
If one of us gives the shot, the other is notified.
Actionable Notification if button is pushed, with option to mark who gave the shot.
# automations.yaml
  description: ''
    platform: state
  condition: []
  - data_template:
    service_template: notify.{{ states.sensor.kitty_shot_notify.state }}
This automation prevents getting duplicate notifications once the shot has been given.
# automations.yaml
- alias: Kitty Shot Tracker - Automation Component
  description: Adds logic to not send notification if changing who gave shot.
  - entity_id: input_boolean.kitty_shot_someone
    platform: state
    to: 'on'
  condition:
  - condition: or
    conditions:
    - condition: state
      state: 'on'
    - condition: state
      state: 'on'
  - data: {}
  - data: {}
  - data: {}
Reset Tracker
Finally, this automation resets the tracker twice a day, so when it’s time to give the shot again, everything is registered as off.
# automations.yaml
- alias: Kitty Shot Tracker - Reset Tracker
  description: ''
  - at: 06:00:00
    platform: time
  - at: '17:30:00'
    platform: time
  condition: []
  - data: {}
  - data: {}
  - data: {}
Custom Card for Lovelace UI
I combined everything into a custom picture elements card. I had originally used an entity card with three button cards combined into stacks, but found I preferred the look of everything unified together, so I came up with this:
elements:
  - entity: sensor.kitty_shot
    style:
      bottom: 58%
      color: black
      font-size: 24px
      left: 3.2%
      transform: initial
    type: state-label
  - entity: input_boolean.kitty_shot_wife
    state_image:
      'off': 'https://i.imgur.com/9x0ylYQ.png'
      'on': 'https://i.imgur.com/9x0ylYQ.png'
    style:
      left: 91%
      top: 25.5%
      width: 18.2%
    tap_action:
      action: none
    type: image
    state_image:
      'off': 'https://i.imgur.com/rCs0LIt.png'
      'on': 'https://i.imgur.com/rCs0LIt.png'
    style:
      left: 17%
      top: 73.5%
      width: 31.2%
    tap_action:
      action: call-service
      service_data:
    type: image
    icon: 'mdi:needle'
    style:
      left: 13%
      top: 57%
      transform: 'scale(2.8,2.8)'
    tap_action:
      service_data:
    type: state-icon
  - entity: input_boolean.kitty_shot_husband
    state_image:
      'off': 'https://i.imgur.com/pyYumG7.png'
      'on': 'https://i.imgur.com/pyYumG7.png'
    style:
      left: 50%
      top: 73.5%
      width: 31.2%
    tap_action:
      service_data:
    type: image
    icon: 'mdi:needle'
    style:
      left: 46%
      top: 57%
    tap_action:
      service_data:
    type: state-icon
  - entity: input_boolean.kitty_shot_someone
    state_image:
      'off': 'https://i.imgur.com/jqSdMHi.png'
      'on': 'https://i.imgur.com/jqSdMHi.png'
    style:
      left: 83%
      top: 73.5%
      width: 31.2%
    tap_action:
      service_data:
        entity_id:
          - input_boolean.kitty_shot_husband
          - input_boolean.kitty_shot_wife
          - input_boolean.kitty_shot_someone
    type: image
image: ‘https://i.imgur.com/2KH5oqQ.png'
type: picture-elements
CAT TAX:
This is a pretty great write-up, and it can be repurposed for many other cat-related activities such as has the cat litter been cleaned, and by who? Did someone feed the cat? Doubling up on dinner can lead to a very fat cat, and missing dinner entirely can lead to damaged furniture.
EDIT: I suppose you could use it for non-cat related things as well
Thanks! I hope it helps someone!
This would have saved me a lot of research and work last week when I was working out a way to keep track of litterbox-cleaning:
catlitter
There’s a xiaomi vibration / motion sensor on the litterbox door to keep track of “visits” and we have a reminders and alerts system similar to yours to make sure we keep it clean and the house doesn’t smell of cat.
What a great job you did. Thank you so much for the cats! Mine is diabetic too and I know how complicated it is to handle this issue.
I will definitely keep your work close to me.
Big cuddle to Tax :wink:
I love a sensor that tells me who shot the cat!
I recently did a somewhat similar project using a Wyze contact sensor with our HVAC filter. (Sensor for tracking when HVAC filter is due to be changed) I’d love to hear more about how you set this up. Are alerts just triggered on each use, or do you have a time aspect as well? How are you tracking the time of the visits/counting the number of visits on your card?
