Tuya integration Broken 02/2024?
All my entities became suddenly unavailable in homeassistant, even if I reload them… is it only me…?
Same problem here.
2024-02-02 12:46:31.430 ERROR (Thread-3) [tuya_iot] error while get mqtt config
2024-02-02 12:46:31.434 ERROR (Thread-3) [root] Uncaught thread exception
File "/usr/local/lib/python3.11/threading.py", line 1045, in _bootstrap_inner
self.run()
File "/usr/local/lib/python3.11/site-packages/tuya_iot/openmq.py", line 161, in run
time.sleep(self.mq_config.expire_time - 60)
AttributeError: 'NoneType' object has no attribute 'expire_time'
Link to github issue
Thanks for sharing.
So I guess not on my side… let’s see how much time they take to fix it… I am assuming it’s a Tuya problem as I haven’t donde any ugprade nor change in my HAAS config. It just stopped.
Oh… I just had a look to this one in github: ℹ️ Tuya integration not working · Issue #80278 · home-assistant/core · GitHub
Looks like my Core IoT is expired. I just submitted a request for an extension.
I have an expiration date of 2023-07-26 and it worked well until yesterday.
I’m waiting patiently :wink:
Same here, my contract expired in september last year. It stopped working earlier today. Renewed for another 6mo, lets see what they say.
I do have local tuya integration, but im lazy to change all my automations :slight_smile:
I also have enough Zigbee devices to replace all the tuya ones. I just have to get my ass in gear.
My expiration date was on 2022 and as you, worked until today… I guess they enforced something today.
I am waiting for the approval.
How good is local Tuya? I never tested.
LocalTuya works fine, it is pain though to get the devices into the integration.
Bunch of stuff i did not understand that i just clicked myself through.
Same problem here. Everything worked fine until today. Although the Core IoT service had expired 2 years ago. Let’s see if extending it solves anything.
Where are you guys seeing your expiration date/time and renewing? I went into cloud - development, and I see my project code, and creation date: 2021-12-28 16:34:04, but I’m not seeing a way to renew the project. So I’m assuming the contract is something else, and located somewhere else. When I did get logged in just now, it asked me to accept an agreement…so is that all it is?
Ah, somehow I clicked into a section in Core IOT cloud that had my expiration as 2023-04-17 00:05:24, and said it was suspended and actively alerting or whatever.
So I did an extend trial. It seems like you can only request 6 months max for the extension.
Beyond that it looks like the trial edition actually costs ongoing fees for messages and API calls. Am I reading that correctly? $3.71/million API calls, and $1.46/million messages? If this trial account is going to start causing me to get billings, I’m just going to trash all my Tuya stuff. Or is there a Tuya direct integration option that will work?
Same problem here… all entries are gone… tried to reconnect… with the same result. No devices.
Guys this was my solution:
I think this Could be the cause.
https://www.reddit.com/r/homeassistant/s/c2lxg4SEG4
Setting up their new custom integration worked.
thanks, worked
Thanks for the tip today on the new integration. I was able to add the smartlife integration via HACS. I had to set up smartlife on my phone first, since I had been using the Tuya app, and then have to remove my devices from Tuya and Add them to Smartlife, but once I did that the integration was straightforward and everything seems to work fine.
Hi Tim where did you had to remove your devices from Tuya? in your phone app or homeassistant app or in Tuya website?
Idem here, I spent hours trying to fix it, finally uninstall it and reinstall, enter the cloud, nothing … I got bored and I switched to the app smartlife… much simpler, I do not have to have an account in tuya cloud. See How to Install Smart Life Integration (Beta)-Tuya IoT Development Platform-Tuya Developer
It is perfectly explained here: ℹ️ Tuya integration not working · Issue #80278 · home-assistant/core · GitHub
unlink and link.
You didn’t need to move them. It’s works with either app:
I set this up using the Tuya Smart app for Android.
Well, the man himself confirmed that this integration is not ready for prime time:
Hey guys, I did the integration as it’s explained here… I can control the devices, but the automations I have are not working because the devices are still missing in the automations…
Do I have to go through each automation to adjust it again?!
This would take forever…
Or should I do something with the old tuya integration?
How this thing is going with you guys?
