I made a custom quirk for this device specifically TZ3000_abrsvsou - TS004F
Supports : Mode Change from Hue / Temp Control and Normal Mode,
Single, Double and Toggle, Left Rotate, Right Rotate, Press and Rotate - Left Right. Detect Tripple Presses for Mode Change. Hope this helps someone ![:slight_smile: :slight_smile:](https://community.home-assistant.io/images/emoji/twitter/slight_smile.png?v=12)
"""Tuya TS004F devices."""
from __future__ import annotations
from zhaquirks.tuya.mcu import EnchantedDevice #old versions
#from zhaquirks.tuya import EnchantedDevice #2024.2 onward
from zigpy.profiles import zha
from zigpy.zcl.clusters.general import (
Basic,
Groups,
Identify,
LevelControl,
OnOff,
Ota,
PowerConfiguration,
Scenes,
Time,
from zigpy.zcl.clusters.lighting import Color
from zigpy.zcl.clusters.lightlink import LightLink
from zhaquirks.const import (
ALT_SHORT_PRESS,
BUTTON,
BUTTON_1,
BUTTON_2,
BUTTON_3,
BUTTON_4,
CLUSTER_ID,
COMMAND,
COMMAND_MOVE,
COMMAND_MOVE_SATURATION,
COMMAND_OFF,
COMMAND_ON,
COMMAND_STEP,
COMMAND_STOP,
COMMAND_STOP_MOVE_STEP,
COMMAND_TOGGLE,
DEVICE_TYPE,
DIM_DOWN,
DIM_UP,
DOUBLE_PRESS,
ENDPOINT_ID,
ENDPOINTS,
INPUT_CLUSTERS,
LEFT,
LONG_PRESS,
LONG_RELEASE,
MODEL,
MODELS_INFO,
OUTPUT_CLUSTERS,
PARAMS,
PROFILE_ID,
RIGHT,
ROTATED,
ROTATED_FAST,
ROTATED_SLOW,
SHORT_PRESS,
TURN_OFF,
TURN_ON,
ARGS,
from zhaquirks.tuya import (
TuyaNoBindPowerConfigurationCluster,
TuyaSmartRemoteOnOffCluster,
TuyaZBExternalSwitchTypeCluster,
#Some of the TZ3000_abrsvsou TS004F Customizations
ROTATED_PRESSED = "Press Rotate Knob HUE Mode Only"
COMMAND_STEP_COLOR_TEMP = "step_color_temp"
PRESSED = "pressed"
TOGGLE = "toggle"
ATTRIBUTE_UPDATED = "attribute_updated"
TRIPPLE_PRESSED = "Tripple Press"
TRIPPLE_PRESSED_NORMAL_MODE = "Tripple press to Normal Mode"
TRIPPLE_PRESSED_HUE_MODE = "Tripple press to HUE Mode"
ROTATED_HUE = "Rotate in HUE Mode"
ROTATED_NORMAL = "Rotate in Normal Mode"
DOUBLE_PRESS = "Double Click in Normal Mode"
LONG_PRESS = "Long Press in Normal Mode"
LONG_PRESS_HUE = "Long Press in HUE Mode"
BUTTON_1_HUE = "Button 1 in Hue Mode"
BUTTON_1_NORMAL = "Button 1 in Normal Mode"
class TuyaSmartRemote004FROK(EnchantedDevice):
"""Tuya Smart (rotating) Knob device."""
signature = {
# "node_descriptor": "NodeDescriptor(byte1=2, byte2=64, mac_capability_flags=128, manufacturer_code=4098, maximum_buffer_size=82, maximum_incoming_transfer_size=82, server_mask=11264, maximum_outgoing_transfer_size=82, descriptor_capability_field=0, *allocate_address=True, *complex_descriptor_available=False, *is_alternate_pan_coordinator=False, *is_coordinator=False, *is_end_device=True, *is_full_function_device=False, *is_mains_powered=False, *is_receiver_on_when_idle=False, *is_router=False, *is_security_capable=False, *is_valid=True, *logical_type=<LogicalType.EndDevice: 2>, *user_descriptor_available=False)",
# SizePrefixedSimpleDescriptor(endpoint=1, profile=260, device_type=260, device_version=1, input_clusters=[0, 1, 3, 4, 6, 4096], output_clusters=[25, 10, 3, 4, 5, 6, 8, 4096])
MODELS_INFO: [
("_TZ3000_4fjiwweb", "TS004F"),
("_TZ3000_uri7ongn", "TS004F"),
("_TZ3000_ixla93vd", "TS004F"),
("_TZ3000_qja6nq5z", "TS004F"),
("_TZ3000_csflgqj2", "TS004F"),
("_TZ3000_abrsvsou", "TS004F"),
ENDPOINTS: {
1: {
PROFILE_ID: zha.PROFILE_ID,
DEVICE_TYPE: zha.DeviceType.DIMMER_SWITCH,
INPUT_CLUSTERS: [
Basic.cluster_id,
PowerConfiguration.cluster_id,
Identify.cluster_id,
Groups.cluster_id,
OnOff.cluster_id,
LightLink.cluster_id,
OUTPUT_CLUSTERS: [
Ota.cluster_id,
Time.cluster_id,
Groups.cluster_id,
Scenes.cluster_id,
OnOff.cluster_id,
LevelControl.cluster_id,
replacement = {
ENDPOINTS: {
1: {
DEVICE_TYPE: zha.DeviceType.NON_COLOR_CONTROLLER,
INPUT_CLUSTERS: [
Basic.cluster_id,
Groups.cluster_id, # Is needed for adding group then binding is not working.
OUTPUT_CLUSTERS: [
Ota.cluster_id,
Time.cluster_id,
Groups.cluster_id,
Scenes.cluster_id,
Color.cluster_id,
device_automation_triggers = {
#HUE MODE STUFF
(LONG_PRESS_HUE, BUTTON): {
COMMAND: COMMAND_MOVE_SATURATION,
ENDPOINT_ID: 1,
CLUSTER_ID: 768,
PARAMS: {"move_mode": 1},
(ROTATED_HUE, RIGHT): {
COMMAND: COMMAND_STEP,
ENDPOINT_ID: 1,
CLUSTER_ID: 8,
PARAMS: {"step_mode": 0},
(ROTATED_HUE, LEFT): {
ENDPOINT_ID: 1,
CLUSTER_ID: 8,
PARAMS: {"step_mode": 1},
(ROTATED_PRESSED, RIGHT): {
COMMAND: COMMAND_STEP_COLOR_TEMP,
ENDPOINT_ID: 1,
CLUSTER_ID: 768,
PARAMS: {"step_mode": 1, "color_temp_min_mireds": 153},
(ROTATED_PRESSED, LEFT): {
ENDPOINT_ID: 1,
CLUSTER_ID: 768,
PARAMS: {"step_mode": 3, "color_temp_min_mireds": 153},
(TOGGLE, BUTTON_1_HUE): {
COMMAND: TOGGLE,
ENDPOINT_ID: 1,
CLUSTER_ID: 6,
(TRIPPLE_PRESSED_NORMAL_MODE, BUTTON_1_HUE): {
COMMAND: ATTRIBUTE_UPDATED,
ENDPOINT_ID: 1,
CLUSTER_ID: 6,
ARGS: {"attribute_name": "switch_mode", "attribute_id": 32772, "value": 1},
(TRIPPLE_PRESSED_HUE_MODE, BUTTON_1): {
ENDPOINT_ID: 1,
CLUSTER_ID: 6,
ARGS: {"attribute_name": "switch_mode", "attribute_id": 32772, "value": 0},
(SHORT_PRESS, BUTTON_1_NORMAL): {ENDPOINT_ID: 1, COMMAND: SHORT_PRESS},
(LONG_PRESS, BUTTON_1_NORMAL): {ENDPOINT_ID: 1, COMMAND: LONG_PRESS},
(DOUBLE_PRESS, BUTTON_1_NORMAL): {ENDPOINT_ID: 1, COMMAND: DOUBLE_PRESS},
(ROTATED_NORMAL, RIGHT): {
COMMAND: RIGHT,
ENDPOINT_ID: 1,
CLUSTER_ID: 6,
(ROTATED_NORMAL, LEFT): {
COMMAND: LEFT,
ENDPOINT_ID: 1,
CLUSTER_ID: 6,
