U-Bolt Pro Z-Wave best lock so far but still a failure
Here is a post I recently placed on U-Tec’s, the parent company of Ultraloq the producer of U-Bolt Pro, Wishlist:
The Ultraloq U-Bolt Pro Z-Wave (including type 2 security) interviews and integrates with Z-Wave JS to MQTT on Home Assistant better than the three prior locks I’ve tried. U-tec needs to transfer the functionality of the cell phone app to devices and entities that Home Assistant can read and write.
Home Assistant currently lists nothing at all (devices or entities) for automations, and Z-Wave JS to MQTT, although stating that sending a “lock or unlock” communication to the lock was successful, the lock does nothing and never responds to Z-Wave JS to MQTT integration. Z-Wave JS to MQTT only knows whether the U-Bolt Pro is locked or unlocked (manually or with the cell phone app). However, you can’t set it or read it in Home Assistant for an automation. Also, there’s no data in Z-Wave JS to MQTT regarding the “open or closed” door sensor, and therefore there can be no automations in Home Assistant regarding a very important “state” of a front door.
I can say the same thing about Shelly’s cell phone app although Shelly does a much better job of integration with Home Assistant for automations (albeit less security needed). U-Tec, you could make a giant leap forward.
Mine does report locked/unlocked well, which never worked correctly on the Yale model I had… overall, an improvement but it could always be better.
I just got this lock and I cannot even get the basic lock and unlock to work in home assistant. This is what I see in zwave2mqtt
and this is what I see in home assistant:
I tried excluding it and including again with no luck. This is the zwave stick that i’m using. Any ideas how to solve this problem so at least i can get to lock and unlock the door from home assistant?
I don’t use the MQTT Zwave add-on, but with just the Zwave JS Add-on and mine works just fine… I have the same lock.
Your lock is included without security. Locks don’t work in that case. You’ll have to re-include it. Make sure you have security keys installed in the Z-Wave configuration.
What can you do with this lock via HA?
Can you see open/close state?
Can you lock/unlock?
I have 2 of the old Pro version with wi-fi bridges (I love the hardware, I’ve been using them for 2 years) and thinking to replace them with the z-wave version just to get some control via HA.
I just purchased one with a Z-Wave USB stick (Aoetec Z-stick 7 Plus) and I’m honestly dissapointed.
You’re able to control the device, by lock and unlock.
You’re able to see the state of the device connection to Z-Wave, and some battery info, although I’ve seen reports that this never updates so we’ll see about that.
Finally, there is a “Current status of the door” which is always Unknown, there is no state for it.
Overall, very disappointing
Thanks, @nowjon! I figured it was very rudimentary.
I guess the current status of the door is that extra open/close sensor they include with the lock
It’s very green, like all the multiple requests that were made for them to have an open API.
The hardware itself has been very stable for me in the past 2 years… it’s the software piece that I’m disappointed at.
What is so disappointing about it? It locks and unlocks, so it’s doing its job isn’t it? Are you expecting other features?
Don’t forget to check for Notifications.
Have you tried a re-interview?
Yes I have, with 2 different locks without change.
And yes, I would expect that door status with the included door sensor would be shared, but also, if the lock fails to lock I’d appreciate it showing unlocked instead of locked luring me into a false sense of security.
I went to Dev Tools > Event > and pasted zwave_js_notification, but this doesn’t show anything when listening. Either through sending the command through HA or the app.
I’d look at the “+4 entities not shown” in your screen shot and enable these and restart HA. Then look at those entities, one of them may have the info you need.
sensor.back_door_deadbolt_indicator_value
sensor.back_door_deadbolt_node_identify_on_off_cycle_count
sensor.back_door_deadbolt_node_identify_on_off_period_duration
sensor.back_door_deadbolt_node_identify_on_off_period_on_time
The above are teh disabled entities I enabled, and after a reboot of the server they all show 0
Manually unlocked the lock and still showed Locked in HA
Hit Unlock, it stayed unlocked
After a few seconds it auto-locked and updated in HA
Verified there was no change to any of the sensors.
Manually unlocked the lock, opened the door
Shut the door, auto-locked
Verified still no change in any of the sensors.
I think maybe if we could get a ESP32 setup to get the Bluetooth info similar to the Smartdry solution here: Clothes Dryer Automations - #130 by bryangerlach we’d be in great shape, just not familiar enough with it to do so myself
I did verify though, that my ESP32 with BLE Tracking does show the locks, so I guess it’s possibe?
[21:10:48][D][esp32_ble_tracker:792]: Found device AC:4D:16:31:8A:8E RSSI=-83
[21:10:48][D][esp32_ble_tracker:813]: Address Type: PUBLIC
[21:10:48][D][esp32_ble_tracker:815]: Name: ‘U-Bolt-ZWave’
[21:10:48][D][esp32_ble_tracker:817]: TX Power: 2
[21:11:03][D][esp32_ble_tracker:792]: Found device F0:5E:CD:C9:3C:77 RSSI=-85
[21:11:03][D][esp32_ble_tracker:813]: Address Type: PUBLIC
[21:11:03][D][esp32_ble_tracker:815]: Name: ‘U-Bolt-ZWave’
[21:11:03][D][esp32_ble_tracker:817]: TX Power: 2
Sorry that didn’t help, was worth a shot,
Z-Wave is spotty on the lock and the status sensor is always Unknown.
No, I’m expecting the reported features to work and work consistently. Pretty simple.
FYI: I was very frustrated about the Sensor Status… But for what it’s worth, however, if you add a simple “Entity” card pointing to the lock entity itself (not the sensor), it properly displays “Locked” versus “Unlocked” for me!
Did you ever get this fixed? Mines including to the network the same way with security set to “none” and nothing is working. I’ve sent an email to U-Tec thinking it was their issue because their app is reporting a security issue when pairing to my Aeotec Z-Stick Gen 5…saying to remove it from the hub because of a security error. It (The U-Tec app) never asks for the 5 digit code on the battery cover of the deadbolt as I was expecting during the inclusion. I do have the security keys installed and listed in the Z Wave JS add-on. Other than integrating with HA, I’m very pleased with this lock!
This lock continues to be a PITA. I love the hardware. But their software execution is terrible. I’ve got the hub (which is silly it’s a separate purchase), and connecting to the lock remotely is still terribly unreliable. I do not recommend this lock unless your family is never going to access it remotely (aside from the lock and unlock feature throw HA).
I still can’t get it to pair, with security. I’m wondering if I need zwave js & MQTT, or if my Aeotec hub is just too old, or if this has to run through smartthings, Alexa, or ring etc…obviously people in this thread @nowjon have gotten it to pair with security. My question is simply, how? If anyone knows, can you chime in and help a brother out? U-Tec support has gone off the radar.
I’m running into the same issue as you @trailheadmedia - I get security errors. I thought it might also fix it to switch over to zwavejs2mqtt (now just called Z-Wave JS UI, just in case that caused any confusion). Unfortunately, that made absolutely zero change other than telling me that there was no security configured which I assume is the issue. Excluding it and re-including it has not made any change.
Anyone else have suggestions? I am thinking about forgetting about the z-wave functionality all together and just getting a wifi bridge that it could connect to and try and add it that way to HA.
Anyone had luck with that or getting security to work?
I have had the u bolt pro zwave in place for almost 2 months. Hardware is excellent. the status of the door = unknown is because the built in sensor won’t work with steel doors. I use the zooz ZSE41 as a working door status sensor and it works great!! I have an automation that will lock the door 30s when it is detected closed (zse41). the automation also unlocks when detected open (to save the door frame from bolt damage). My issue is that occasionally the lock when manually unlocked does NOT report that to HA. which means it doesn’t lock again with the automation. it also means I look remotely at the lock and it shows locked when it isn’t. The zwave connection is secure S2 Access Control. I keep looking for a fix for this. my zwave stick is ZST10-700 with firmware: 7.17.2. Note: when the lock is in an unlocked state and HA says it is locked, the APP shows it as unlocked. In that ‘wrong’ state, a re-interview and HA gets the proper state of the lock.
UPDATE: reading the ULOC web site, one of the help items (reading between the lines) said low batteries may yield poor communications. Even though the battery said 100% it was the batteries shipped with the lock. I replaced them. I have NOT had the communications issue since (3 weeks). YEAH!!! great lock! (battery sensor is spaced)
