Hi. As the PR been submitted as yet? Not sure how to access the host files to update. Running on VM supervised from the download page on ha website.
Cheers
Cheers
@frank451 another user (b4dpxl) has just had their request approved https://github.com/home-assistant/core/pull/42314
The changes are essentially the exact same as mine so thereās no point in me submitting.
Iām fairly new to HA, I am thinking of picking a couple of these up, however want to check how I would integrate. From reading do I add the custom_broadlink into the custom_components folder, then add a few lines as above to the configuration.yaml?
I got slightly lost working out how to add the second one, what do I need to do to get second working? Sorry for all the questions!
do we know how long these PR approvals take to get in to the beta builds typically?
I really need the BG1 support, but I canāt find the host files in my VirtualBox HASSIO instance of HA, much like @frank451.
I canāt find anything like /usr/src/homeassistant/homeassistant/components in any of the files systems I can findā¦
Access the files system via VB.
Shouldnāt be long now. Looks like itās just been merged into the dev branch https://github.com/home-assistant/core/tree/dev/homeassistant/components/broadlink
EDIT: RESOLVED
Heya, I know this isnāt actually your PR that got added, but felt this thread was updated and giving me some useful pointers so farā¦ so figured Iād updated here.
Attempted to add a device, having upgraded to the dev branch on my homeassistant. Wondering if anyone has any top tips on āunlockingā the device.
Iāve attempted to add the device using a multitude of different Broadlink apps, none of which workā¦ well, the original really old app configures the wifi correctly, but device is unknown.
the latest IHC software, you have to specify which device youāre trying to add, and none of them work for me.
The BG app itself clearly doesnāt have an unlock feature, or well I cant find it if it does!
You just need to do the reset socket/partial reconfigure and that will sort it. As youāve already got it paired with the Broadlink app you may as well do a firmware update before you reset it.
on the money.
That worked perfectly, now have two sets of sockets configured perfectly.
Thanks for all you did to make this happen also @PBZ.
is support for the BG plugs now in the standard release, Iām quite new to HA and am struggling to get them to work. Any tips or instructions?
There seem to be a number of solutions to the BG libraries, and Iām rather confused!
I think itās coming in the next release
Thanks!
Any idea of an ETA? Should I keep on battling, or just wait.
1st week in December I believe. So Iād wait.
Great, Nest thermostat is interesting too, would be good to get that integrated.
I was running the dev branch in Docker before it was merged. Now it is merged, Iāve switched to running the latest Home Assistant OS (with Supervisor) in Virtual Box.
The sockets work most of the time but then I randomly get āUnavailableā for all of the sockets (I have 6 2-gang sockets). They work from the Broadlink app but not in HA.
Any advice for debugging this (Iām fairly new to HA and have no idea about custom logging or how to tell what is related to what).
Seems related to the thread but happy to start a new one if thatās preferred. Iād like to get as much info as possible before opening a GitHub issue.
Has this feature been added to teh new release? I could not see anything in the release notes.
Paul
Yes, its all working now. I have been waiting for this and the latest update allowed me to add them.
Has anyone got the BG Smart Plug working? I added a line to test it in the init.py file for broadlink integration:
0x51e2: (sp2, "AHC/U-01", "BG Electrical"),
Integration config flow found the device and added, but only asking for the name, with no device or entities added. I have put in a request for the device type to be added, but has anyone had any luck editing the local files for a temporary fix for any unsupported broadlink devices?
My BG Smart Plug worked straight away.
I deleted the plug from the BG app so it went back into pairing mode.
I just did āadd integrationā, select ābroadlinkā and then typed in the IP address of the plug at the exact same time as I added it in the BG app.
Weird. Must be a slightly different version. I bought this one a couple of years ago, and the particular hex isnāt supported. Is your plug newer?
