Hope this is the right spot. Trying to update but not able to. Anyone else seen this? I just updated home assistant and zwave js without issue. Tried a reboot but no luck, same error
Logger: homeassistant.components.websocket_api.http.connection
Source: components/hassio/update.py:169
Integration: Home Assistant WebSocket API (documentation, issues)
First occurred: 12:14:57 AM (4 occurrences)
Last logged: 12:22:59 AM
[2778655832] Error updating ESPHome: Can't install ghcr.io/esphome/esphome-hassio:2023.2.4: 404 Client Error for http+docker://localhost/v1.42/images/ghcr.io/esphome/esphome-hassio:2023.2.4/json: Not Found ("No such image: ghcr.io/esphome/esphome-hassio:2023.2.4")
[2722685616] Error updating ESPHome: Can't install ghcr.io/esphome/esphome-hassio:2023.2.4: 404 Client Error for http+docker://localhost/v1.42/images/ghcr.io/esphome/esphome-hassio:2023.2.4/json: Not Found ("No such image: ghcr.io/esphome/esphome-hassio:2023.2.4")
File "/usr/src/homeassistant/homeassistant/components/hassio/update.py", line 167, in async_install
await async_update_addon(self.hass, slug=self._addon_slug, backup=backup)
File "/usr/src/homeassistant/homeassistant/components/hassio/handler.py", line 51, in _wrapper
raise HassioAPIError(data["message"])
homeassistant.components.hassio.handler.HassioAPIError: Can't install ghcr.io/esphome/esphome-hassio:2023.2.4: 404 Client Error for http+docker://localhost/v1.42/images/ghcr.io/esphome/esphome-hassio:2023.2.4/json: Not Found ("No such image: ghcr.io/esphome/esphome-hassio:2023.2.4")
File "/usr/src/homeassistant/homeassistant/components/websocket_api/commands.py", line 200, in handle_call_service
await hass.services.async_call(
File "/usr/src/homeassistant/homeassistant/core.py", line 1787, in async_call
task.result()
File "/usr/src/homeassistant/homeassistant/core.py", line 1824, in _execute_service
await cast(Callable[[ServiceCall], Awaitable[None]], handler.job.target)(
File "/usr/src/homeassistant/homeassistant/helpers/entity_component.py", line 213, in handle_service
await service.entity_service_call(
File "/usr/src/homeassistant/homeassistant/helpers/service.py", line 680, in entity_service_call
future.result() # pop exception if have
File "/usr/src/homeassistant/homeassistant/helpers/entity.py", line 968, in async_request_call
await coro
File "/usr/src/homeassistant/homeassistant/helpers/service.py", line 720, in _handle_entity_call
await result
File "/usr/src/homeassistant/homeassistant/components/update/__init__.py", line 154, in async_install
await entity.async_install_with_progress(version, backup)
File "/usr/src/homeassistant/homeassistant/components/update/__init__.py", line 413, in async_install_with_progress
await self.async_install(version, backup)
File "/usr/src/homeassistant/homeassistant/components/hassio/update.py", line 169, in async_install
raise HomeAssistantError(f"Error updating {self.title}: {err}") from err
homeassistant.exceptions.HomeAssistantError: Error updating ESPHome: Can't install ghcr.io/esphome/esphome-hassio:2023.2.4: 404 Client Error for http+docker://localhost/v1.42/images/ghcr.io/esphome/esphome-hassio:2023.2.4/json: Not Found ("No such image: ghcr.io/esphome/esphome-hassio:2023.2.4")
