Unable to upload Home Assistant Core or Addons due to "audio" plugin error
Hi all, looking for some help diagnosing an issue I am having running Home Assistant OS within a VM (VirtualBox) on Ubuntu Server.
I’ve got myself in a situation where I cannot update Home Assistant Core or any Addon’s due to the following error:
Logger: homeassistant.components.websocket_api.http.connection
Source: components/hassio/update.py:169
Integration: Home Assistant WebSocket API (documentation, issues)
First occurred: 12:03:17 (5 occurrences)
Last logged: 12:09:26
[140557936997472] Error updating Terminal & SSH: 'AddonManager.update' blocked from execution, was unable to update plugin(s) audio and all plugins must be up to date first
[140557936997472] Error updating File editor: 'AddonManager.update' blocked from execution, was unable to update plugin(s) audio and all plugins must be up to date first
  File "/usr/src/homeassistant/homeassistant/components/hassio/update.py", line 167, in async_install
    await async_update_addon(self.hass, slug=self._addon_slug, backup=backup)
  File "/usr/src/homeassistant/homeassistant/components/hassio/handler.py", line 45, in _wrapper
    raise HassioAPIError(data["message"])
homeassistant.components.hassio.handler.HassioAPIError: 'AddonManager.update' blocked from execution, was unable to update plugin(s) audio and all plugins must be up to date first
  File "/usr/src/homeassistant/homeassistant/components/websocket_api/commands.py", line 193, in handle_call_service
    await hass.services.async_call(
  File "/usr/src/homeassistant/homeassistant/core.py", line 1713, in async_call
    task.result()
  File "/usr/src/homeassistant/homeassistant/core.py", line 1750, in _execute_service
    await cast(Callable[[ServiceCall], Awaitable[None]], handler.job.target)(
  File "/usr/src/homeassistant/homeassistant/helpers/entity_component.py", line 204, in handle_service
    await service.entity_service_call(
  File "/usr/src/homeassistant/homeassistant/helpers/service.py", line 680, in entity_service_call
    future.result()  # pop exception if have
  File "/usr/src/homeassistant/homeassistant/helpers/entity.py", line 930, in async_request_call
    await coro
  File "/usr/src/homeassistant/homeassistant/helpers/service.py", line 717, in _handle_entity_call
    await result
  File "/usr/src/homeassistant/homeassistant/components/update/__init__.py", line 152, in async_install
    await entity.async_install_with_progress(version, backup)
  File "/usr/src/homeassistant/homeassistant/components/update/__init__.py", line 411, in async_install_with_progress
    await self.async_install(version, backup)
  File "/usr/src/homeassistant/homeassistant/components/hassio/update.py", line 169, in async_install
    raise HomeAssistantError(f"Error updating {self.title}: {err}") from err
homeassistant.exceptions.HomeAssistantError: Error updating Terminal & SSH: 'AddonManager.update' blocked from execution, was unable to update plugin(s) audio and all plugins must be up to date first
I always get the error 'AddonManager.update' blocked from execution, was unable to update plugin(s) audio and all plugins must be up to date first and cannot find a way around it. Any amount of Googleing didn’t help either.
Any assistance would be greatly appreciated, thank you!
having the same issue. using “audio update” simply leads to the error “Error: Audio update failed”
Now I have the same problem. Did you ever find a solution?
For anyone who is interested, this helped: Supervisor is unable to start because it can't download the Audio plugin docker image - #2 by nbalkovskyi1
Same (or similar) problem on my Raspberry Pi 4B 8 GB with HAOS. “banner” does not help, nor does rebooting. Totally stuck, at least I have a full backup so that I can start from scratch
Home Assistant observer
Supervisor: 	Connected
Supported: 	Processing...
Healthy: 	Processing...
s6-rc: info: service s6rc-oneshot-runner: starting
s6-rc: info: service s6rc-oneshot-runner successfully started
s6-rc: info: service fix-attrs: starting
s6-rc: info: service fix-attrs successfully started
s6-rc: info: service legacy-cont-init: starting
cont-init: info: running /etc/cont-init.d/udev.sh
[17:46:58] INFO: Using udev information from host
cont-init: info: /etc/cont-init.d/udev.sh exited 0
s6-rc: info: service legacy-cont-init successfully started
s6-rc: info: service legacy-services: starting
services-up: info: copying legacy longrun supervisor (no readiness notification)
services-up: info: copying legacy longrun watchdog (no readiness notification)
[17:46:58] INFO: Starting local supervisor watchdog...
s6-rc: info: service legacy-services successfully started
24-01-05 17:47:04 INFO (MainThread) [__main__] Initializing Supervisor setup
24-01-05 17:47:04 INFO (MainThread) [supervisor.utils.sentry] Initializing Supervisor Sentry
24-01-05 18:47:04 INFO (MainThread) [supervisor.bootstrap] Seting up coresys for machine: raspberrypi4-64
24-01-05 18:47:04 INFO (MainThread) [supervisor.docker.supervisor] Attaching to Supervisor ghcr.io/home-assistant/aarch64-hassio-supervisor with version 2023.12.0
24-01-05 18:47:04 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state initialize
24-01-05 18:47:04 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation complete
24-01-05 18:47:04 INFO (MainThread) [__main__] Setting up Supervisor
24-01-05 18:47:04 INFO (MainThread) [supervisor.api] Starting API on 172.30.32.2
24-01-05 18:47:04 INFO (MainThread) [supervisor.hardware.monitor] Started Supervisor hardware monitor
24-01-05 18:47:04 INFO (MainThread) [supervisor.dbus.manager] Connected to system D-Bus.
24-01-05 18:47:04 INFO (MainThread) [supervisor.dbus.agent] Load dbus interface io.hass.os
24-01-05 18:47:04 INFO (MainThread) [supervisor.dbus.hostname] Load dbus interface org.freedesktop.hostname1
24-01-05 18:47:04 INFO (MainThread) [supervisor.dbus.logind] Load dbus interface org.freedesktop.login1
24-01-05 18:47:04 INFO (MainThread) [supervisor.dbus.network] Load dbus interface org.freedesktop.NetworkManager
24-01-05 18:47:04 INFO (MainThread) [supervisor.dbus.rauc] Load dbus interface de.pengutronix.rauc
24-01-05 18:47:04 INFO (MainThread) [supervisor.dbus.resolved] Load dbus interface org.freedesktop.resolve1
24-01-05 18:47:04 INFO (MainThread) [supervisor.dbus.systemd] Load dbus interface org.freedesktop.systemd1
24-01-05 18:47:04 INFO (MainThread) [supervisor.dbus.timedate] Load dbus interface org.freedesktop.timedate1
24-01-05 18:47:06 INFO (MainThread) [supervisor.host.services] Updating service information
24-01-05 18:47:06 INFO (MainThread) [supervisor.host.sound] Updating PulseAudio information
24-01-05 18:47:06 WARNING (SyncWorker_0) [supervisor.host.sound] Can't update PulseAudio data: Failed to connect to pulseaudio server
24-01-05 18:47:07 INFO (MainThread) [supervisor.host.network] Updating local network information
24-01-05 18:47:08 INFO (MainThread) [supervisor.host.apparmor] Loading AppArmor Profiles: {'hassio-supervisor'}
24-01-05 18:47:08 ERROR (MainThread) [supervisor.host.apparmor] Can't load profile hassio-supervisor: Can't load profile '/mnt/data/supervisor/apparmor/hassio-supervisor': exit status 1
24-01-05 18:47:08 INFO (MainThread) [supervisor.docker.monitor] Started docker events monitor
24-01-05 18:47:08 INFO (MainThread) [supervisor.updater] Fetching update data from https://version.home-assistant.io/stable.json
24-01-05 18:47:08 INFO (MainThread) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/aarch64-hassio-cli with version 2023.11.0
24-01-05 18:47:08 INFO (MainThread) [supervisor.plugins.cli] Starting CLI plugin
24-01-05 18:47:08 INFO (SyncWorker_0) [supervisor.docker.manager] Cleaning hassio_cli application
24-01-05 18:47:18 INFO (MainThread) [supervisor.docker.cli] Starting CLI ghcr.io/home-assistant/aarch64-hassio-cli with version 2023.11.0 - 172.30.32.5
24-01-05 18:47:18 INFO (MainThread) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/aarch64-hassio-dns with version 2023.06.2
24-01-05 18:47:18 INFO (MainThread) [supervisor.plugins.dns] Starting CoreDNS plugin
24-01-05 18:47:18 INFO (SyncWorker_0) [supervisor.docker.manager] Cleaning hassio_dns application
24-01-05 18:47:28 INFO (MainThread) [supervisor.docker.dns] Starting DNS ghcr.io/home-assistant/aarch64-hassio-dns with version 2023.06.2 - 172.30.32.3
24-01-05 18:47:28 INFO (MainThread) [supervisor.plugins.dns] Updated /etc/resolv.conf
24-01-05 18:47:28 INFO (MainThread) [supervisor.plugins.base] No audio plugin Docker image ghcr.io/home-assistant/aarch64-hassio-audio found.
24-01-05 18:47:28 INFO (MainThread) [supervisor.plugins.audio] Setup Audio plugin
24-01-05 18:47:28 INFO (MainThread) [supervisor.docker.interface] Downloading docker image ghcr.io/home-assistant/aarch64-hassio-audio with tag 2023.12.0.
24-01-05 18:47:29 ERROR (MainThread) [supervisor.docker.interface] Can't install ghcr.io/home-assistant/aarch64-hassio-audio:2023.12.0: 500 Server Error for http+docker://localhost/v1.43/images/ghcr.io/home-assistant/aarch64-hassio-audio:2023.12.0/json: Internal Server Error ("layer does not exist")
24-01-05 18:47:29 WARNING (MainThread) [supervisor.plugins.audio] Error on installing Audio plugin, retrying in 30sec
24-01-05 18:47:59 INFO (MainThread) [supervisor.docker.interface] Downloading docker image ghcr.io/home-assistant/aarch64-hassio-audio with tag 2023.12.0.
24-01-05 18:48:01 ERROR (MainThread) [supervisor.docker.interface] Can't install ghcr.io/home-assistant/aarch64-hassio-audio:2023.12.0: 500 Server Error for http+docker://localhost/v1.43/images/ghcr.io/home-assistant/aarch64-hassio-audio:2023.12.0/json: Internal Server Error ("layer does not exist")
and so on and so on
Has anyone found a fix to this load fail… ‘AddonManager.install’ blocked from execution, was unable to update plugin(s) audio and all plugins must be up to date first"
Having same problem has anyone found an answer yet. Please.
