This worked on one machine but not on another.
I have a Pi3 running Volumio with HA supervised installed on top. Worked fine for years, now everything unhealthy.
Tried with creating jobs.json directly and via CLI, but the supervisor still reports unhealthy…
The jobs.json file was updated by the cli command and now looks like this:
[19:27:34] INFO: Starting local supervisor watchdog...,
20-12-16 19:27:38 INFO (MainThread) [__main__] Initializing Supervisor setup,
20-12-16 19:27:39 INFO (MainThread) [supervisor.bootstrap] Initializing Supervisor Sentry,
20-12-16 19:27:39 INFO (MainThread) [supervisor.bootstrap] Seting up coresys for machine: raspberrypi3,
20-12-16 19:27:39 INFO (SyncWorker_0) [supervisor.docker.supervisor] Attaching to Supervisor homeassistant/armv7-hassio-supervisor with version 2020.12.7,
20-12-16 19:27:39 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state CoreState.INITIALIZE,
20-12-16 19:27:39 WARNING (MainThread) [supervisor.resolution.evaluations.docker_configuration] Docker storage driver devicemapper is not supported!,
20-12-16 19:27:39 WARNING (MainThread) [supervisor.resolution.evaluations.docker_configuration] Docker logging driver json-file is not supported!,
20-12-16 19:27:39 WARNING (MainThread) [supervisor.resolution.evaluations.base] The configuration of Docker is not supported (more-info: https://www.home-assistant.io/more-info/unsupported/docker_configuration),
20-12-16 19:27:39 WARNING (MainThread) [supervisor.resolution.evaluations.base] Docker version '18.06.3-ce' is not supported by the Supervisor! (more-info: https://www.home-assistant.io/more-info/unsupported/docker_version),
20-12-16 19:27:39 WARNING (MainThread) [supervisor.resolution.evaluations.base] Found unsupported job conditions settings. (more-info: https://www.home-assistant.io/more-info/unsupported/job_conditions),
20-12-16 19:27:39 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation complete,
20-12-16 19:27:39 INFO (MainThread) [__main__] Setting up Supervisor,
20-12-16 19:27:39 INFO (MainThread) [supervisor.api] Starting API on 172.30.32.2,
20-12-16 19:27:40 ERROR (MainThread) [supervisor.dbus.network] Version '0.9.10.0' of NetworkManager is not supported!,
20-12-16 19:27:45 WARNING (MainThread) [supervisor.dbus.rauc] Host has no rauc support. OTA updates have been disabled.,
20-12-16 19:27:45 INFO (MainThread) [supervisor.host.info] Updating local host information,
20-12-16 19:27:45 INFO (MainThread) [supervisor.host.services] Updating service information,
20-12-16 19:27:46 INFO (MainThread) [supervisor.host.sound] Updating PulseAudio information,
20-12-16 19:27:46 INFO (MainThread) [supervisor.host] Host information reload completed,
20-12-16 19:27:46 INFO (MainThread) [supervisor.host.apparmor] Loading AppArmor Profiles: {'hassio-supervisor'},
20-12-16 19:27:46 INFO (MainThread) [supervisor.host.services] Reloading local service hassio-apparmor.service,
20-12-16 19:27:46 INFO (SyncWorker_0) [supervisor.docker.interface] Attaching to homeassistant/armhf-hassio-dns with version 2020.11.0,
20-12-16 19:27:46 INFO (MainThread) [supervisor.plugins.dns] Updated /etc/resolv.conf,
20-12-16 19:27:46 INFO (SyncWorker_0) [supervisor.docker.interface] Attaching to homeassistant/armhf-hassio-audio with version 17,
20-12-16 19:27:46 INFO (SyncWorker_0) [supervisor.docker.interface] Attaching to homeassistant/armhf-hassio-cli with version 2020.11.1,
20-12-16 19:27:46 INFO (SyncWorker_0) [supervisor.docker.interface] Attaching to homeassistant/armhf-hassio-observer with version 2020.10.1,
20-12-16 19:27:46 INFO (SyncWorker_0) [supervisor.docker.interface] Attaching to homeassistant/armhf-hassio-multicast with version 3,
20-12-16 19:27:46 INFO (MainThread) [supervisor.updater] Fetching update data from https://version.home-assistant.io/stable.json,
20-12-16 19:27:47 INFO (MainThread) [supervisor.homeassistant.secrets] Loaded 1 Home Assistant secrets,
20-12-16 19:27:47 INFO (SyncWorker_1) [supervisor.docker.interface] Attaching to homeassistant/raspberrypi3-homeassistant with version 0.118.4,
20-12-16 19:27:47 INFO (MainThread) [supervisor.hassos] No Home Assistant Operating System found,
20-12-16 19:27:48 INFO (MainThread) [supervisor.store.git] Loading add-on /data/addons/git/a0d7b954 repository,
20-12-16 19:27:48 INFO (MainThread) [supervisor.store.git] Loading add-on /data/addons/core repository,
20-12-16 19:27:48 INFO (MainThread) [supervisor.store.git] Loading add-on /data/addons/git/15ef4d2f repository,
20-12-16 19:27:48 INFO (MainThread) [supervisor.store.git] Loading add-on /data/addons/git/d4868bb1 repository,
20-12-16 19:27:54 INFO (MainThread) [supervisor.store] Loading add-ons from store: 70 all - 70 new - 0 remove,
20-12-16 19:27:54 INFO (MainThread) [supervisor.addons] Found 6 installed add-ons,
20-12-16 19:27:54 INFO (SyncWorker_3) [supervisor.docker.interface] Attaching to homeassistant/armv7-addon-check_config with version 3.6.0,
20-12-16 19:27:54 INFO (SyncWorker_1) [supervisor.docker.interface] Attaching to hassioaddons/log-viewer-armv7 with version 0.9.1,
20-12-16 19:27:54 INFO (SyncWorker_0) [supervisor.docker.interface] Attaching to hassioaddons/ide-armv7 with version 2.2.0,
20-12-16 19:27:54 INFO (SyncWorker_4) [supervisor.docker.interface] Attaching to hassioaddons/pi-hole-armv7 with version v3.0.2,
20-12-16 19:27:54 INFO (SyncWorker_5) [supervisor.docker.interface] Attaching to homeassistant/armv7-addon-rpc_shutdown with version 2.2,
20-12-16 19:27:54 INFO (MainThread) [supervisor.snapshots] Found 3 snapshot files,
20-12-16 19:27:54 INFO (MainThread) [supervisor.discovery] Loaded 0 messages,
20-12-16 19:27:54 INFO (MainThread) [supervisor.ingress] Loaded 0 ingress sessions,
20-12-16 19:27:54 INFO (MainThread) [supervisor.resolution.check] Starting system checks with state CoreState.SETUP,
20-12-16 19:27:54 INFO (MainThread) [supervisor.resolution.check] System checks complete,
20-12-16 19:27:54 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state CoreState.SETUP,
20-12-16 19:27:55 WARNING (MainThread) [supervisor.resolution.evaluations.base] NetworkManager is not correctly configured (more-info: https://www.home-assistant.io/more-info/unsupported/network_manager),
20-12-16 19:27:55 WARNING (MainThread) [supervisor.resolution.evaluations.base] Detected unsupported OS: Raspbian GNU/Linux 8 (jessie) (more-info: https://www.home-assistant.io/more-info/unsupported/os),
20-12-16 19:27:55 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation complete,
20-12-16 19:27:55 INFO (MainThread) [__main__] Running Supervisor,
20-12-16 19:27:55 WARNING (MainThread) [supervisor.core] System running in a unsupported environment!,
20-12-16 19:27:55 CRITICAL (MainThread) [supervisor.core] System running in a unhealthy state and need manual intervention!,
20-12-16 19:27:55 INFO (MainThread) [supervisor.addons] Phase 'AddonStartup.INITIALIZE' starting 0 add-ons,
20-12-16 19:27:55 INFO (MainThread) [supervisor.core] Supervisor reboot detected,
20-12-16 19:27:55 INFO (MainThread) [supervisor.misc.tasks] All core tasks are scheduled,
20-12-16 19:27:55 INFO (MainThread) [supervisor.misc.hwmon] Started Supervisor hardware monitor,
20-12-16 19:27:55 INFO (MainThread) [supervisor.core] Supervisor is up and running,
20-12-16 19:27:55 INFO (MainThread) [supervisor.host.info] Updating local host information,
20-12-16 19:27:55 INFO (MainThread) [supervisor.resolution.fixup] Starting system autofix at state CoreState.RUNNING,
20-12-16 19:27:55 INFO (MainThread) [supervisor.resolution.fixup] System autofix complete,
20-12-16 19:27:55 INFO (MainThread) [supervisor.host.services] Updating service information,
20-12-16 19:27:55 INFO (MainThread) [supervisor.host] Host information reload completed,
The only error in the supervisor log is about network manager:
Any ideas why the job condition is not working?
