Cool, I ordered a NodeMCUv2+ and NRF24L01 and they should arrive in a couple of weeks, for the price is at least worth a shoot
What MQTT functionality are you talking about? Sounds interesting.
So I just bought a v6 bridge to control my white LED panel via HA but no luck.
I had the same experience as you described, the node library did work for me and so did the Milight App but HA sadly failed on me.
Does somebody know how long it usually takes to fix this type of bugs (just a ballpark number)?
If it takes too long I might just use the node library for the time.
What version of HA are you running? 0.45 (released yesterday) should fix some connection bugs, otherwise a restart could also help for older versions.
How do you emulate the bridges on HASS?
platform: limitlessled
bridges:
host: 192.168.1.105
groups:
- number: 1
type: bridge-led
- number: 1
- number: 2
- number: 3
- number: 4
This is my normal config for my physical v6 hub, how do I add now the virtual created one from ESP??
I followed the instructions from this project by the brilliant Christoper Mullins to setup the emulated bridge on a NodeMcu with an attached NRF24L01 transceiver,
http://blog.christophermullins.com/2017/02/11/milight-wifi-gateway-emulator-on-an-esp8266/
Once you have the firmware running you can access the user interface for the emulated bridge by browsing to the IP of the NodeMcu. There you can create as many hubs as you wish. Each must have a unique ID and port number, pair your lights to each emulated hub by pressing the interface’s pair button within 3 seconds of powering on the light you wish to pair.
Once you have enough hubs/gateways/servers/whatever_you_call_them set up and all your lights paired to one or many groups of one or many servers you configure HASS like this:
light:
bridges:
- host: 192.168.0.11 # IP of my real MiLight iBox2 Bridge
groups:
- number: 1
type: rgbww
- number: 2
type: rgbww
- number: 2
type: rgbw
- number: 3
type: rgbw
- number: 4
type: rgbw
- host: 192.168.0.20 # IP of NodeMcu
version: 6
port: 8900 # port number I chose when I created first server
groups:
- number: 1
type: rgbw
version: 6
port: 8901 # port number I chose when I created the second server
groups:
- number: 1
type: rgbww
Notice that the NodeMcu servers have the same IP address but port numbers are different!
I pair one light to one group so I have total flexibility when creating automations and scenes.
oh thank you! just tested and it works like a champ
I was creating every v6 with port 8899 and every v5 with port 8900 so I was wondering how hass was gonna handle it.
at least now I can pair all my bulbs…
Need some help:
2017-06-05 19:59:29 ERROR (MainThread) [homeassistant.components.light] Error while setting up platform limitlessled
File “/srv/homeassistant/lib/python3.4/site-packages/homeassistant/helpers/entity_component.py”, line 160, in _async_setup_platform
SLOW_SETUP_MAX_WAIT, loop=self.hass.loop)
File “/usr/lib/python3.4/asyncio/tasks.py”, line 372, in wait_for
return fut.result()
File “/usr/lib/python3.4/asyncio/futures.py”, line 277, in result
raise self._exception
File “/usr/lib/python3.4/concurrent/futures/thread.py”, line 54, in run
File “/srv/homeassistant/lib/python3.4/site-packages/homeassistant/components/light/limitlessled.py”, line 109, in setup_platform
version=bridge_conf.get(CONF_VERSION, DEFAULT_VERSION))
File “/home/homeassistant/.homeassistant/deps/limitlessled/bridge.py”, line 103, in init
self._init_connection()
File “/home/homeassistant/.homeassistant/deps/limitlessled/bridge.py”, line 248, in _init_connection
self._socket.recv_into(response)
ConnectionRefusedError: [Errno 111] Connection refused
2017-06-05 20:03:08 WARNING (MainThread) [aiohttp.websocket] Client protocols [‘undefined’] don’t overlap server-known ones ()
Bridge V5
light:
bridges:
- host: 192.168.1.8
groups:
- number: 1
- number: 2
type: rgbw
- number: 3
emulated_hue:
host_ip: 192.168.1.9
listen_port: 8300
after new raspberry install i got my limitless not to work with hassbian,with limitless remote control everything fine.
greets
Is the indentation correct?
This example configuration shows Name two spaces indented more than number. Number should be indented two spaces after the groups declaration and the group declaration indented two spaces more than host which is two spaces in from platform, and platform two spaces more than light.
# Example configuration.yaml entry
light:
bridges:
- host: 192.168.1.10
groups:
- number: 1
- number: 2
type: rgbw
- host: 192.168.1.11
groups:
- number: 1
name: Living Room & Hall
- number: 1
type: bridge-led
To upload your yaml correctly formatted in the forums add four extra spaces to the beginning of each line of your post that contains yaml
changed the indentation
log:
The following errors have been logged this session:
2017-06-06 07:21:37 WARNING (Thread-11) [homeassistant.components.emulated_hue] When targetting Google Home, listening port has to be port 80
2017-06-06 07:21:37 ERROR (MainThread) [homeassistant.components.light] Error while setting up platform limitlessled
return fut.result()
2017-06-06 07:23:51 WARNING (MainThread) [aiohttp.websocket] Client protocols [‘undefined’] don’t overlap server-known ones ()
other tips?
Problem solved: Bridge Version is V.4 NOT V.5
light:
bridges:
- host: 192.168.1.8
version: 4
port: 8899
groups:
- number: 1
- number: 2
- number: 3
works fine !
Haha. Glad you got it sorted.
Hello! Im new here.
I was wondering why do you want to control your mi light bulbs with hass if you can’t even change the color?
I also have milight bulbs and iBox.
Thanks!
The question is based on a wrong assumption. Of course you can control the colour of your bulb.
Once the light is on, click on the name of the lamp to open the control the control panel.
There you can control the colour, brightness, …
I also built the emulated bridge and I have a question for you.
Mine work perfectly if controlling one at a time
But with scenes maybe half the lights will get the correct command. I am wondering if you have had any issues with yours. The milight hub worked perfect.
I have mine paired to two emulated ports (4 groups x 2 servers). I wonder if I should repair everything so they each have their own emulated server/port
Hoping someone can help me get this working.
I have established a working emulated bridge, and am able to pair lights and adjust them as desired through the Milight Hub user interface.
My issue is that I cannot sort out how to control any emulated bridge paired lights through Home Assistant.
I have tried it through the Limitless component and with MQTT and mosquitto, but the HA UI buttons never change the light.
The only lights I have are the dual white lights that you can control brightness and temp.
- platform: mqtt
name: "Office Test Overhead"
command_topic: "Milight_gw/0x1001/cct/1"
- platform: limitlessled
bridges:
- host: IP of the emulated bridge node
port: 8900
groups:
- number: 1
type: white
In the hub UI,
I have kept the default format of the MQTT topic pattern
Included the user and password for MQTT
Included the port with the IP of the MQTT server.
Current setup for the lights.
For mqtt you need to use the mqtt json component:
The component you’re using just send 0 and 1 to the command topic ^^
Concerning the limitlessled component, I’m not sure it support the dual white bulb…
I have a few CCT bulbs but I never used them, I will give it a try later today and see if @touliloup is right about the support or not.
I use the emulated bridge with HA for some time now and used the LimitlessLight component for awhile but switched to MQTT because I can keep track of the state with the remotes and the lights don’t turn all out when HA is restarted.
My Limitless component config were like:
This was my physical iBox1 bridge:
bridges:
- host: 192.168.1.115
groups:
- number: 1
type: bridge-led
- number: 1
- number: 2
- number: 3
- number: 1
type: rgbww
And this was from a emulated bridge:
- host: 192.168.1.112
version: 6
port: 8899
groups:
- number: 1
type: rgbww
For MQTT heres a example of a working config for me:
# RGB
- platform: mqtt_json
state_topic: "milight/updates/0x354A/rgbw/1"
command_topic: "milight/commands/0x354A/rgbw/1"
brightness: true
flash: true
rgb: true
optimistic: false
qos: 0
# RGB-CCT
state_topic: "milight/updates/0x1/rgb_cct/1"
command_topic: "milight/commands/0x1/rgb_cct/1"
optimistic: false
qos: 0
Hope it helps
Couldn’t be in doubt for much longer so I went and grab one of my white bulbs and connected it.
I don’t have any physical bridge with me atm and only emulated bridge.
I couldn’t managed to PAIR my white bulb with the emulated bridge set at CCT but they successfully PAIRED as RGB+CCT.
Couldn’t use the LimitlessLed component as “type: white” but worked as “type: rgbww”
bridges:
- host: 192.168.0.258
version: 6
port: 8899
groups:
- number: 1
type: rgbww
Thanks for the assistance.
I think I understand the concepts a bit better, but i’m still not having any luck getting it to work.
I am unable to control the light and im unable to get state info from the hub
state_topic: "milight/updates/0x1001/rgb_cct/1"
command_topic: "milight/commands/0x1001/rgb_cct/1"
optimistic: false
qos: 0
I understand for the light to receive state information I need to configure an update topic pattern on the hub, yet I cannot seem to save one. The below will not save on the emulated bridge UI.
milight/updates/:device_id/:device_type/:group_id
It seems that for the MQTT JSON platform, I need to include the command topic.
Does this need to match just the mqtt_topic_pattern set in the bridge UI or does this need to be established elsewhere?
Is command_topic in HA = MQTT_topic_pattern?
