Seeing this behavior as well. Surprised only a few of us have commented. In my case, I can’t be sure, but I believe the issue started after applying a recorder fix for the icloud3 integration.
Are any of you running that integration and have you applied that fix? If not that fix can’t be the cause and I’ll wait for a core fix.
In my case I can access the Energy Dashboard’s settings. But see errors referencing recorder.
“The recorder has been configured to exclude these configured entities: (Learn more)
sensor.powerwall_site_import
sensor.powerwall_site_export”
That’s why I thought my fix to the icloud3 integration might be relevant since it was to recorder_prefilter.py. Anyone else with the issue seeing messages in the dashboard regarding recorder? Anyone else apply the icloud3 fix for log issues?
Also the energy meter on the P1 meter and also on the enphase envoy meters show a linear line / not changing graph. I see this behavior also on other energy measure plugs.
I have the same problem, but the energy disappeared only after updating to version 7.01, interesting that I also had problems with saving, data recording turns off after a few hours, I returned to the backup to version 6.04 and it’s ok
Same problem here although the issues is not just energy dashboard but also other sensors I have like tuya temperature, humidity etc. I reverted back to 6.4 and every works ok. I also tried version 2024.7.1 but the problem is still there. Can someone confirm that the issue is still present in version 2024.7.1?
same problem here with my installation after updating to 2024.7. 4am, recorder stops, most data gone, apart from a few sensors. Energy dashboard trashed. Just updated to 2024.7.1 and will see if that makes a difference. I really don’t want to have to wake up at 4am to check. Sad face!
Does anyone know if 2024.7.1 has fixed the issues?
Apparently changing the record purge setting to false in the yaml fixes it, but this needs to be changed back when the fix is sorted.
Hello , going from 7.0 to 7.1 and again energy dashboard was gone , i go back to 7.0 but still no energy dashboard.
I take a look at the logbook and see a lot of errors from the integration Places installed with HAC. There was an update for Places special for the 7.0 core. After installing the new Places update and now the energydashboard is working again.
Maybe for you some other integration is not compatible , take a look at the log book for errors from integrations and try to solve them. Please rapport not working integrations so other persons can take advantage of this topic.
