Using action inputs in automations
I am feeling a bit dumb: I am trying to create an automation blueprint which has an action input and this input should be run later.
However it fails with: Message malformed: Unable to determine action @ data['action'][0]
What is the problem? Any help is kindly appreciated.
I have created following demo script which triggers this issue:
blueprint:
  name: POC Blueprint
  description: Automation blue print to test things
  domain: automation
  input:
    triggered_action:
      description: Actions that should be executed at sunrise
      selector:
  - platform: sun
    event: sunrise
  -sequence: !input triggered_action
space after the - in -sequence?
Unfortunately not. also with - sequence: !input triggered_action it does not work.
sequence prob isn’t the right thing anyways. in a normal construct, you wouldn’t do
- sequence: action
i presume you’re trying to let the user choose an action and invoke it.
look at this:
If the input will be providing all of the actions, you can use:
action: !input triggered_action
Otherwise, you need to use one of the methods described in the link in @armedad’s post above.
Thanks @Didgeridrew for your answer. It works! Thanks @armedad for your further tips!
Also there was no default in the input meaning if you don’t put a valid action in there, it might error like that.
Thanks @Sir_Goodenough for this helpful aspect.
