Using RM4 and other Broadlink Cloud API remotes with HA
This post is no longer relevant, new Broadlink remotes are now fully supported in HA
Ok - before I start a few points:
  • This is a kludge. Broadlink have released new RM4 IR remotes and updated RM3 Minis so that they only work with their cloud based API. This set of automations attempts to work around the fact these devices are not supported in Home Assistant by using IFTTT webhooks and the IFTTT Broadlink connector.
  • If I am lucky, someone with more skills than me will see this and hate it so much they rush out and build an integration for the new Broadlink remotes. :laughing:
  • As far as I am concerned, it goes against why I like Home Assistant - for the most part HA encourages and uses local control of devices. I am not a big fan of cloud based solutions.
  • I created it because I wanted control of my air conditioners from HA. I have an older RM3 Mini that works perfectly well with HA using the local API, I bought a new RM3 and a RM4 in the hope that I could use them for 2 more a/cs but they don’t work…
  • I use SmartIR for my original air conditioner, it’s a great custom component that makes setting up the older Broadlink IR remotes a breeze, and includes a library of dozens of supported devices so you don’t have to learn IR codes. The link for SmartIR is below. If you have a supported remote I highly recommend it.
To use SmartIR as the climate control component for this exercise, you still need to set up the Broadlink components.
Start by adding the RM4 or new RM3 to your network and account using the Broadlink app.
Once you have done that, set up the air conditioner you want to control in the broadlink app and make sure all the controls and commands work as expected.
Make a note of the IR remote’s MAC and IP address. Set up your DHCP server so the remote address is reserved, it needs to remain unchanged.
Add the remote to the switch section in configuration.yaml:
switch:
  - platform: broadlink
    host: 192.168.0.171
    mac: '24:df:a7:34:95:6d'
    type: rm_mini
    friendly_name: "Kitchen IR"
Note the type: entered doesn’t matter.
Install the SmartIR custom component if you haven’t already:
Add the new remote to SmartIR:
smartir:
climate:
  - platform: smartir
    device_code: 1282
    controller_data: 192.168.0.171
    temperature_sensor: sensor.kitchen_temperature
    humidity_sensor: sensor.kitchen_humidity
Choose a device code that matches your air conditioner, or at least look through the device files to find one that matches the capabilities of your a/c.
My air conditioner looks like this:
Next you need to configure IFTTT in HA:
Lastly (for HA anyhow) add some new automations to your automations.yaml:
# Automations for unsupported attribute states are for where the SmartIR climate frontend does not match Broadlink IFTTT connector
# They reset the attribute back to the vakue it was before the unsupported atteribute was selected
# Unlike SmartIR, IFTTT Broadlink requires explicit turn on - will only trigger when climate card moves from off to any other state
- alias: 'kitchen_ac_setmode_on'
  - platform: state
    entity_id: climate.kitchen_ac
  - service: ifttt.trigger
    data_template: {"event":"kitchen_mode_on"}
# Unsupported a/c modes
- alias: 'kitchen_ac_setmode_unsupp'
    - platform: state
      to: 'dry'
  - service: climate.set_hvac_mode
    data_template:
      hvac_mode: "{{ trigger.from_state.state  }}"
# Supported a/c modes.
# Note the 2 sec delay is to allow turn on to complete before setting mode on startup
- alias: 'kitchen_ac_setmode'
  - platform: state
    to: 'off'
  - platform: state
    to: 'cool'
  - platform: state
    to: 'heat'
  - platform: state
    to: 'auto'
  condition:
    condition: and
    conditions:
      - condition: template
        value_template: "{{ trigger.from_state.state != trigger.to_state.state }}"
        value_template: "{{ trigger.from_state.state != 'dry' }}"
  - delay: '00:00:02'
    data_template: {"event":"kitchen_mode_{{ states('climate.kitchen_ac')  }}"}
# Unsupported temps (those either not supported by IFTTT or out of my desired range)
- alias: 'kitchen_ac_settemp_unsupp'
  - platform: state
    entity_id: sensor.kitchen_climate_temp
  condition:
    condition: template
    value_template: "{{ state_attr('climate.kitchen_ac','temperature') in [16, 17, 26, 27, 28, 29, 30] }}"
  - service: climate.set_temperature
    data_template:
      temperature: "{{ trigger.from_state.state  }}"
# Supported temperatures
- alias: 'kitchen_ac_settemp'
  - platform: state
  condition:
    condition: template
    value_template: "{{ state_attr('climate.kitchen_ac','temperature') in [18, 19, 20, 21, 22, 23, 24, 25] }}"
    data_template: {"event":"kitchen_temp_{{ state_attr('climate.kitchen_ac','temperature')  }}"}
# Unsupported fan modes / speeds
- alias: 'kitchen_ac_setfan_unsupp'
  - platform: state
    entity_id: sensor.kitchen_climate_fan
    to: 'quiet'
  - service: climate.set_fan_mode
    data_template:
      fan_mode: "{{ trigger.from_state.state  }}"
# Supported fan speeds
- alias: 'kitchen_ac_setfan'
  - platform: state
    to: 'low'
  - platform: state
    to: 'med'
  - platform: state
    to: 'high'
  - platform: state
    to: 'auto'
    data_template: {"event":"kitchen_fan_{{ state_attr('climate.kitchen_ac','fan_mode')  }}"}
These will of course need to be modified for your supported and unsupported modes, temperatures etc.
By unsupported, I mean things your a/c can do, that SmartIR knows about, that the Broadlink IFTTT connector can’t do. For instance my a/c has a fan mode called “quiet”. SmartIR adds this to the thermostat card, but IFTT can’t use it, so if the “quiet” mode is selected an automation will reject that and revert to the previous selected mode, or temperature, or whatever…
Lastly, once you have tested IFTTT and webhooks with some of the examples, you need to do the tedious exercise of adding all the events generated by the automations to IFTTT. The Broadlink connector doesn’t have templating or variables, so one IFTTT Applet is required for every possible command.
Here are mine, you should be able to work out what each of them do:
Al this took a couple of days to get working, along with testing and trying to allow for all events and use cases, but it now works seamlessly.
My RM4 works identically from HA to the SmartIR controlled RM3 Mini. When you are using the cards, the behaviour is the same, with the exception of the values reverting if you select unsupported options.
I really just did this to see if I could - but I am pleased with the result.
I have a handful of RM mini 3s and they are perfect for the job. I also hope someone is able to nullify the efforts to use a cloud. Maybe am wrong, but I wish manufacturers would wake up to the enthusiast side of things.
Hey there. I might have a solution for you that doesn’t involve automations.
I have a new RM Mini 3 (black bean), tested it and it worked.
  1. Remove the device from the Broadlink app. It shoud blink fast.
  2. Start the process of adding the device, but once it is connected to your network, quit the app (don’t add it to a house/room).
  3. Configure it in HA as you would. Restart HA.
Edit here: this stops the device before it connecs to Broadlink cloud services, thus working on LAN
Mine works now perfectly. The broadlink.send and learn services are working. I could use SmartIR with the base code for my AC that’s already in the component. As far as I know, it should work on the RM4 too. Give it a try.
Just a side note, mine still didn’t work with Broadlink Manager even after doing that.
Confirming @Bruno_Dantas’ approach worked for me on an RM4 mini. Thanks for the tip!
Yeah this topic is way out of date - new RM compatability was in .109 I think…
finally Brodlink RM4 Pro works with HA
Hi @Bruno_Dantas I’ve followed your instructions, restarted HA
HA now has remote.broadlink, sensor.broadlink_humidity, sensor.broadlink_temperature
event the 2 services broadlink.send and broadlink.learn
only the Switch entity can’t be found in Developer Tools->States
but I see an info in the log but no errors.
INFO (MainThread) [homeassistant.components.switch] Setting up switch.broadlink
I have the RM4 Pro.
this is my switch setup in configuration.yaml,
    host: 192.168.2.28
    mac: '24:DF:A7:E4:7C:6D'
    type: rm4_pro
    timeout: 15
my next step is try to use the broadlink.learn and add the device I learned earlier through the broadlink app, maybe then the switch might appear?
That is correct, the switch won’t appear;
I use my RM3 and RM4 with SmartIR, they are defined thus:
switch:
    host: 192.168.0.111
    mac: '34:ea:34:e4:b0:d2'
    type: sp3
    friendly_name: "Pergola Light"
    host: 192.168.0.103
    mac: '34:ea:34:e4:b9:0a'
    type: sp3
    friendly_name: "Garage Light 2"
    host: 192.168.0.136
    mac: '34:ea:34:e3:ad:52'
    type: rm_mini
    friendly_name: "Hall IR"
    host: 192.168.0.171
    type: rm4_mini
    friendly_name: "Sunroom IR"
    host: 192.168.0.188
    mac: '24:df:a7:7a:63:07'
    type: rm_mini3_newblackbean
If you look in states you can see the SP3 smart plugs, but not the IR:
This does not prevent them working…
Thanks,
passing on info to others even after getting RM4 Pro working with HA locally no cloud,
the windows app “Broadlink Manager” still won’t work with RM4 Pro
if finds my device as unknown.
Looking for devices…
Found device : Unknown [192.168.2.28]
Writing compatible device not detected!
So got to use only HA broadlink.learn , luckily DrZzs video shows how it can be done.
@Bruno_Dantas this worked for me too with my RM4 Pro. I have already configured my RM Mini 3.
And now they are working like a charm.
This is my configuration.yaml
switch:
#Broadlink
    host: 192.168.0.188
    mac: '34:EA:34:41:38:41'
    host: 192.168.0.187
    mac: '24:DF:A7:F1:0D:78'
    type: rm4_pro
The broadlink.learn and broadlink.send are working on HA too. But i didn’t test yet the learn with RF controllers. When I buy my new automated blinds, I will try the learn with RF.
Would you please tell me again the correct step of getting RM4pro and RM4mini into HA?
Platform broadlink not ready yet. Retrying in 60 seconds.
9:22:11 PM – Switch (WARNING) - message first occurred at 8:58:51 PM and shows up 11 times
This error poping is like tearing my hair off.
People have had success following the instructions in this post:
