There is an update for multimatic to 1.12.4
see https://github.com/thomasgermain/vaillant-component
It works now.
Frank
It works now.
Frank
Is there a way to control the temperature in the buffer (not the boiler)?
I know sma sunny home manager can control it and there are some settings on the thermostat
I added a link on the github project: GitHub - thomasgermain/vaillant-component: Multimatic integration for Home Assistant (NOT compatible with sensoAPP)
Hi there,
my situation is as follows:
I have a vaillant heating system with multimatic.
I want to send the “reference room” temperature to multimatic from an external sensor (integrated in HA). Normally the multimatic panel is sending this information - but this mounted in my technic room and not the living room. Is this possible with this integration or do I have other options?
Thanks in advance,
Lukas
I checked, but there is no way to send a temperature to the API.
But maybe you can set a temperature “correction” with the panel (the API doesn’t allow to set it) ?
It took a whole afternoon to get through the thread, but it seems that right now one has 3 alternatives to integrate Vaillant into HA:
via @tgermain 's solution - which is non local, depends on vaillant’s servers and with the introduction of myVaillant app the future of the solution is questionable (?).
locally via eBus, for which one needs a hardware (eBus - USB) and is discussed here.
locally via EEBUS (as pointed out by @sebakerckhof here) - which is not yet accessible ( At the moment, the APIs are only accessible to Vaillant´s API business partners) and has already an own thread but the thread is pretty inactive for now.
… so what is the best option?
Good day,
Has anyone made any progress on the readings?
We have the following problems:
Does anyone have any more information?
Hi All,
I’m quite new to home assistant amd I want ask, if there is a working way, how to implement Vaillant multimatic into Home Assistant. I have a Vaillant VRC700/6 and after reading of the post in this forum I’m really lost how to do it.
Thanks for each help
Alex
Hi Alex,
I have VRC700/6 as well and it is supported by Multimatic integration in HA (as far as I know it works only via cloud through VR920 or VR900 (I have the former) - no local access, but I might be wrong.
You will need to:
I have no related entries in configuration.yaml.
Good luck,
Boštjan
Thank you for your answer. I read some posts there, where is explained communication directly (without VR920) via eBus and eBus daemon - used adapter. But it isn’t clear for me how it work and how to configure.
I am now trying the possibilities and application of HA. I have already managed to achieve small things, but more complicated solutions are still a serious problem for me.
Before I get involved, I would like to know if my Vailant ecoCompact/2 heating and hot water boiler can be integrated into the HA and if so, how?
The Vaillant boiler has a VR70 controller, a Multimatic VR700/6 and VR91 operator, and it has a VR920 Internet WiFi module that can be controlled from a mobile phone with the Vaillant Multimatic application.
Thanks and Regards
Many thanks for your development.
Sorry to ask this question if it has already been asked but I can’t find the answer. maybe you or another member can answer me?
I want to recover the data under grafana.
I easily retrieve several of the data in the table:
“statistics_short_term”
but I can’t find or retrieve the information in the database of:
“current temperature” and the “setpoint”
Also, I have no information on “electric” and “gas” consumption, is this a problem with my VR900? multimatic 700?.
FYI, I never got the information in the mobile app.
Many thanks in advance
you have to create a “virtual sensor” via YAML to make it available for grafana. eg:
- sensor:
#Current temperature SDB
#climate.bain_serialnr
- name: "SDB_temp"
unique_id: SDB_tempVaillant
state: "{{state_attr('climate.bain_serialnr', 'current_temperature')}}"
unit_of_measurement: '°C'
state_class: 'measurement'
then you can use it as you want.
regards
Thank you very very much for your help !
Any idea for my gas consumption data ?
EcoCompact VSC 266/4-5 + Vr900 + multimatic 700
@tgermain & @pepeEL broached the subject , maybe some good news ?
Maybe this is related to what @Bloug asked. I’d like access historical power consumption data to generate a year-to-year comparison on a monthly basis and to retrieve and display data from the past.
I noticed this is possible using urls.emf_report_device from pymultimatic but I cannot find a service nor an entity related to this in HA. Am I missing something?
Thanks!
Yes same request
I got an update from the VR900 recently, since the connection to the app is really much faster !!
Are there any other non-visible changes in preparation for the new myvaillant app? (like consumption :D?)
How did you update the VR900? I’m on firmware V 0331.26.02. What’s your firmware?
(Settings → Network access)
Mine still seems slow…
I have the same number.
the update started on its own, I only had to restart vr900
The synchronization time is much faster : 2sec against 30 to 40sec.
" The heating phase for hot water is displayed wrong "
Hi @SaxnPaule did you find a solution? for the time difference?
Could submit an issue to GitHub ? I will have a look
