I keep getting this:
Error adding entities for domain binary_sensor with platform multimatic
Error adding entities for domain sensor with platform multimatic
ValueError: entity_category must be a valid EntityCategory instance
Yes, i have problems with 2022.4. Not solved with 2022.4.1
Errors in short are:
10:35:07 – (ERROR) Sensor - message first occurred at 10:35:06 and shows up 2 times
10:34:45 – (ERROR) Binary Sensor - message first occurred at 10:34:45 and shows up 2 times
Unable to prepare setup for platform multimatic.fan: Platform not found (cannot import name 'ATTR_SPEED' from 'homeassistant.components.fan' (/usr/src/homeassistant/homeassistant/components/fan/__init__.py)).
10:34:45 – (ERROR) setup.py
Long:
Logger: homeassistant.components.sensor
Source: helpers/entity_registry.py:529
Integration: Sensor (documentation, issues)
First occurred: 10:35:06 (2 occurrences)
Last logged: 10:35:07
Error while setting up multimatic platform for sensor
File "/usr/src/homeassistant/homeassistant/helpers/entity_platform.py", line 382, in async_add_entities
await asyncio.gather(*tasks)
File "/usr/src/homeassistant/homeassistant/helpers/entity_platform.py", line 510, in _async_add_entity
entry = entity_registry.async_get_or_create(
File "/usr/src/homeassistant/homeassistant/helpers/entity_registry.py", line 345, in async_get_or_create
return self.async_update_entity(
File "/usr/src/homeassistant/homeassistant/helpers/entity_registry.py", line 529, in async_update_entity
raise ValueError("entity_category must be a valid EntityCategory instance")
Logger: homeassistant.components.binary_sensor
Integration: Binary Sensor (documentation, issues)
First occurred: 10:34:45 (2 occurrences)
Last logged: 10:34:45
Error while setting up multimatic platform for binary_sensor
Logger: homeassistant.setup
Source: setup.py:298
First occurred: 10:34:45 (1 occurrences)
Hi there,
my situation is as follows:
I have a vaillant heating system with multimatic.
I want to send the “reference room” temperature to multimatic from an external sensor (integrated in HA). Normally the multimatic panel is sending this information - but this mounted in my technic room and not the living room. Is this possible with this integration or do I have other options?
I checked, but there is no way to send a temperature to the API.
But maybe you can set a temperature “correction” with the panel (the API doesn’t allow to set it) ?
It took a whole afternoon to get through the thread, but it seems that right now one has 3 alternatives to integrate Vaillant into HA:
via @tgermain 's solution - which is non local, depends on vaillant’s servers and with the introduction of myVaillant app the future of the solution is questionable (?).
locally via eBus, for which one needs a hardware (eBus - USB) and is discussed here.
locally via EEBUS (as pointed out by @sebakerckhofhere) - which is not yet accessible ( At the moment, the APIs are only accessible to Vaillant´s API business partners) and has already an own thread but the thread is pretty inactive for now.
Hi All,
I’m quite new to home assistant amd I want ask, if there is a working way, how to implement Vaillant multimatic into Home Assistant. I have a Vaillant VRC700/6 and after reading of the post in this forum I’m really lost how to do it.
Thanks for each help
Alex
I have VRC700/6 as well and it is supported by Multimatic integration in HA (as far as I know it works only via cloud through VR920 or VR900 (I have the former) - no local access, but I might be wrong.
You will need to:
install HACS;
install Multimatic integration (via HACS);
add multimatic integration to HA (add integration);
Thank you for your answer. I read some posts there, where is explained communication directly (without VR920) via eBus and eBus daemon - used adapter. But it isn’t clear for me how it work and how to configure.
I am now trying the possibilities and application of HA. I have already managed to achieve small things, but more complicated solutions are still a serious problem for me.
Before I get involved, I would like to know if my Vailant ecoCompact/2 heating and hot water boiler can be integrated into the HA and if so, how?
The Vaillant boiler has a VR70 controller, a Multimatic VR700/6 and VR91 operator, and it has a VR920 Internet WiFi module that can be controlled from a mobile phone with the Vaillant Multimatic application.
Sorry to ask this question if it has already been asked but I can’t find the answer. maybe you or another member can answer me?
I want to recover the data under grafana.
I easily retrieve several of the data in the table:
“statistics_short_term”
but I can’t find or retrieve the information in the database of:
“current temperature” and the “setpoint”
Also, I have no information on “electric” and “gas” consumption, is this a problem with my VR900? multimatic 700?.
FYI, I never got the information in the mobile app.
Maybe this is related to what @Bloug asked. I’d like access historical power consumption data to generate a year-to-year comparison on a monthly basis and to retrieve and display data from the past.
I noticed this is possible using urls.emf_report_device from pymultimatic but I cannot find a service nor an entity related to this in HA. Am I missing something?
