Venetian blind card?
Hi
I have started to migrate my homeautomation system to work with the HA frontend resp. lovelace. For most components of my system (mostly pretty old hardware controlled by self developed controller hardware which can work with MQTT) this was trivial.
What I didnt find so far is a suitable card to control the venetian blind in my home. I have found the hass-blind-card, but it only seems to support setting the position of the blinds instead of püosition and title angle.
Is there a card that allows to set both - position and title angle (or do I have to hack something myself)?
Thanks!
If your cover entity supports tilt and position control you can use a Mushroom cover card with both of them enabled or a Tile card with these features.
Check out this guide…
