I’d like to get a video doorbell, but I’d strongly prefer one that doesn’t require cloud access, but, rather, runs everything locally. Motion detection ability would also be nice.
I don’t have an existing doorbell, so tying into that is a non-issue.
Someone on another group mentioned Skybell and Doorbird.
Looking around, is Skybell really cloud-less? It seems like you have to go through their cloud. Am I missing something there? I’m also seeing lots of issues with it. Anyone have good results with this device?
The Doorbird one seems to do the trick, but it also seems very industrial and expensive…
Ideally, I’d like video feed, button, and motion sensor events, that I can then tie into automations. But they need to be fast - even a few seconds delay seems too long.
you can buy cheap weatherproof enclosures from China via sites like Aliexpress. Fit the Rpi into it, add some IR LED’s for night vision (some even have these already built in
You can link to your server via motioneye (which is what I have) or any other camera package; even directly to hass and it works perfectly.
Store videos and pictures locally etc.
They obviously offer a cloud service, but you don’t need it at all.
I used ring and got rid of it a month later.
You can get this from ali express, if you do get it make sure you order it with the power supply as it uses 24VAC and they’re not that easy to find in some places.
You need the app to set it up, but after that you can use the url to configure with motioneye, zoneminder etc. I’ve used with motioneye and zoneminder and works well with both. I just prefer motioneye. the url is this
rtsp://cameraip:554/Streaming/Channels/101
I record in my own server.
