I’m not very code savvy … can one of these fit?
mmh - I can’t find an integration that actually uses them as a base class:
or use the domain e.g. for InputNumber anywhere other than the tests:
but i’ll give it a try.
Hi, I installed this integration and added the lines in configuration.yaml but I get this error what should I do?
Please have a look at your home-assistant.log file and see if can see anything regarding the vimar_platform.
Seems to be the same problem as Slavo0891 - please download the file listed in your logs:
https://192.168.178.110/vimarbyweb/modules/vimar-byme/script/rootCA.VIMAR.crt
directly from your browser and save it in the directory where your configuration.yaml is located.
in which directory should I put it? Thanks
Please put it there ![]()
Mmh still the same error?
Please add the following line to your configuration.yaml: certificate: rootCA.VIMAR.crt
It should be right below host, username and password (same indent) for the vimar_platform.
I have inserted this
Ciao. Ricki controlla le maiuscole. Vedi se nel web server la user “amministratore” è scritto con la A maiuscola. Home Assistant è sensibile.
ora provo a vedere grazie.
I tried reinstalling it and now everything works, nice project. Thanks
i have installed the repository and it works really well. Good job.
may I ask you if it is possible to use the temperature value read by the thermostat to make automations for example, or simply use it in a graph?
Hello and welcome on board.
usually all thermostats should be shown automatically in the home-assistants overview like in this post above: Vimar integration - WIP
an automation can be added in the settings under Automations like this:
Select a trigger e.g. “numeric state” and select your thermostat/climate device:
(in this case it should trigger if the temperature falls under 20°C for at least 2 minutes)
after that select to run a service under the action section:
(here it will just turn on a light - which does not make much sense, but you get the idea)
hope that will help you further.
Ok, thanks a lot.
but if i want to use this graph to track the temperature, for example
it’s no possibile because climate.xxxxx is not a entity sensor.
there are other way?
there are two ways:
- you can just create a new sensor using configuration.yaml
sensors:
climate_erdgeschoss_wohnzimmer_3:
value_template: "{{ state_attr('climate.your_climate_entitiy', 'current_temperature') }}"
- or add a history graph like this:
thanks, it’s perfect
