Visonic Powermax and Powermaster Component
Yes i’m sûre at 100% ! I just have 3 sensors : 1 mct 302 magnet and 2 k985 …
New Github release 0.6.8.0, this is also a formal release for HACS users.
This release makes improvements in the handling of:
  • Powermaster 33 panels
  • Powermax sensor model types
As usual, give it a try and report any problems here.
Sometime over the next week or two I plan to close this long thread and create a new thread so new users do not feel as if they have to read all 1700 posts. I think that the integration has matured enough that most of the issues are resolved, it’s now mostly helping users get it set up.
Hi, sorry, but i don’t understant why my sensor is vibrate aned not PIR…you don’t have any idea?
Can you upload a log file to pastebin please, the 0.6.8.0 release should have fixed it :frowning:
First of all, thanks for this awesome work. I’ve tried to set up the componen for my Tyco alarm, however it looks like my provider uses the Rest API 4.0, which doesn’t seem to be supported.
Doing some further research I got to this similar visonicalarm repository: GitHub - bitcanon/visonicalarm: A simple library for the Visonic Alarm API written in Python 3. which does implement version 4.0. After some quick testing I managed to make it work, I could list my devices and see the alarm status.
My question is, did anybody integrate this visonicalarm repository? And if not, is there any option to make GitHub - And3rsL/VisonicAlarm2 work with an API 4.0 version alarm?
Thanks for the help
Answering myself, I managed to make it work by resetting to the patch previous to the migration from API 4.0 to 8.0. In case this is useful to anybody else.
Thanks for the info.
Just in case anyone is wondering, the Visonic Go app can only be used with PowerMaster panels (firmware 19.4 minimum I think) and you must be connected to a powermanage server, you have to sign up with a provider and this incurs a monthly fee. You also need to buy and install the Visonic PowerLink3 hardware. I guess it comes down to personal choice, especially with the monthly fee. My Home Assistant integration uses a simple hardware device (and not the Powerlink3) and does not need a monthly fee. It simply integrates in to Home Assistant.
But like I said, thanks for the info, much appreciated.
I’ve created a new Github release 0.6.8.1 with 2 minor updates
  1. Added MP-902 sensor for PowerMaster users
  2. Create the alarm entity in Home Assistant with the correct visonic model (when available)
:slight_smile:
Thanks very much for the time & effort you have put into the Visonic Component Dave!
I have had a real quick skim through this thread, your Github and Wiki and there is a wealth of information there most of which is going over my head at this moment in time!
Can I just ask what I think is a simple question while hoping it is a simple answer? :grinning:
I have a self-fitted PowerMaster 30 panel fitted with PowerLink module, a bunch of NEXT PG2’s, Siren, Keypad, a couple of keyfobs and use a company to monitor it.
I do have Installer access to my panel via both directly from the panel and also the Tyco Alarm Install app which I have to pre-approve in the Visonic Go app to allow me to log on.
I also have an unused USB programming dongle kicking around somewhere.
Reading your Wiki it states you don’t need to buy a PowerLink but how does your Component work if there is already one fitted as in my case?
Am I able to connect using the existing ethernet connection that goes into my switch or is the panel data locked up in some proprietary format that only the monitoring company can understand?
Or do I need another way to make an ethernet connection to my panel?
Thanks & kind regards,
-=Glyn=-
Hi @GlynH
As far as I know, you cannot have PowerLink AND Home Assistant.
Since you need to plug an rs-232 to Ethernet/wifi/usb adapter in the same port as the PowerLink both cannot coexist.
This component cannot communicate with your panel through the PowerLink module, so you must choose, own monitoring with HA or monitoring company with PowerLink and the monthly fee.
Best regards
Thanks for taking the time to reply rodak although of course its not what I wanted to hear. :face_with_raised_eyebrow:
Seems a little odd to me in this day & age that I cannot tap into the Visonic traffic from the switch it is connected to and read/write data from there unless it is proprietry like the Nest traffic. :confused:
If I had to choose I would prefer to continue with my alarm being monitored than have it appear in HA although of course I would rather have both! :smirk:
To be honest I’m looking at the pages & pages of instructions needed to work through just to have my Nest devices appear in HASS and wondering whether HASS is indeed worth the hassle? :stuck_out_tongue_closed_eyes:
Similar situation with my LightwaveRF gear which basically got me into Home Automation all those years ago. :roll_eyes:
Ah well I’ll plough on regardless and see what transpires as I’m new to HASS and learning as I go…
-=Glyn=-
I’m just catching up with this a little. @rodak is correct in his reply, though I do have 2 further comments:
  • Some panels have 2 RS232 interfaces, I believe that some users have got it to work in combination with the Powerlink Hardware module
  • You might want to look at this, it uses a completely different way of communicating with the alarm panel
And also my reply
But it’s not something that I’ve looked at in any way so please don’t ask in this thread for help. Either create a new forum thread for it or join an existing one if it exists (I haven’t looked).
Best of luck
:slight_smile:
Hi @davesmeghead , is it possible to have remote control ? Like mct 234 ?
I’m not sure what you mean but let me explain how I use my Fobs.
Please remember that for the following description, I have a PowerMax panel.
If you use the MCT-234 then you can remotely arm/disarm your panel and the state is shown in Home Assistant. We use MCT-237 fobs and each has its own ID as defined by the panel e.g. “Fob 01”, “Fob 02” etc so I decode this in HA to show this in the frontend, for example I have “Fob 01”:
Look at the alarm attribute Panel Last Event
The MCT-237 remotes also have “A” and “B” buttons that can be user defined in the panel settings. I have each button turn on (for a few seconds) and then off, a non-existant X-10 device. Both these X-10 devices appear in Home Assistant as switches so I can use them to trigger scenes in my Home Assistant.
Does this help?
Ok thanks for your explanations.
I don’t see my 2 mct234 and one mct237nin Home Assistant…
That is correct, you won’t. They are not sensors and not switches. I cannot get their state or control them in any way from this integration. There are only 2 ways to interact with them, by using the:
  • Arm/disarm buttons that alters the alarm panel state
  • Programmable buttons on the remote as I do to trigger non-existant X-10 devices.
Please arm or disarm your panel using the MCT-237 (or MCT-234) and look at the alarm_control_panel.visonic_alarm Entity in developer tools, find the attribute Panel Last Event. It will say something like “Disarm / Fob 01”. There is also a standard Home Assistant attribute that I set called changed_by and this will be set to something like “Fob 01”.
Now change the state with a different fob and it will say “Fob 02” (if you arm you need to wait until the panel changes state and actually arms the panel).
:slight_smile:
Ok, thanks for explanations ! I’ll try this soon
Thanks for the full & detailed reply Dave.
I’ll pop open the panel as its been a while now and I can’t remember how its configured.
I’m also going to try my best to wade through this thread and see what I might learn from it.
-=Glyn=-
Every night around 03:16 / 03:19 I get this error, and if the alarm is armed it creates an alert in HA. Does anyone have an idea?
Of course nothing special happens at this time on my system…
Given this error
ERROR Connection Lost : disconnected because the Ethernet/USB connection was externally terminated.
This means that the connection between the HA device and the device in your alarm panel has been interrupted i.e. the TCP connection has been broken. Assuming this is Ethernet (and not USB) then your home router is either re-booting itself or it is re-assigning IP addresses i.e. probably renewing the DHCP lease for the devices
Is this a possibility?
If the connection between HA and panel is lost, this will make my integration attempt to reconnect to the panel, it looks like it eventually succeeds but without a log file it’s difficult for me to tell.
Hope this helps
