Hi all!
I would appreciate some help with debugging the Visual Studio Code addon. When I tried to start the addon I get this log output:
Add-on: Studio Code Server
Fully featured Visual Studio Code (VSCode) experience integrated in the Home Assistant frontend.
Add-on version: 5.3.0
You are running the latest version of this add-on.
System: Home Assistant OS 8.5 (amd64 / qemux86-64)
Home Assistant Core: 2022.8.7
Home Assistant Supervisor: 2022.08.6
Please, share the above information when looking for help
or support in, e.g., GitHub, forums or the Discord chat.
cont-init: info: /etc/cont-init.d/00-banner.sh exited 0
cont-init: info: running /etc/cont-init.d/01-log-level.sh
cont-init: info: /etc/cont-init.d/01-log-level.sh exited 0
cont-init: info: running /etc/cont-init.d/02-set-timezone.sh
[10:54:19] INFO: Configuring timezone
cont-init: info: /etc/cont-init.d/02-set-timezone.sh exited 0
cont-init: info: running /etc/cont-init.d/code-server.sh
cont-init: info: /etc/cont-init.d/code-server.sh exited 0
cont-init: info: running /etc/cont-init.d/mosquitto.sh
cont-init: info: /etc/cont-init.d/mosquitto.sh exited 0
cont-init: info: running /etc/cont-init.d/mysql.sh
cont-init: info: /etc/cont-init.d/mysql.sh exited 0
cont-init: info: running /etc/cont-init.d/user.sh
cont-init: info: /etc/cont-init.d/user.sh exited 0
s6-rc: info: service legacy-cont-init successfully started
s6-rc: info: service legacy-services: starting
services-up: info: copying legacy longrun code (no readiness notification)
s6-rc: info: service legacy-services successfully started
[10:54:21] INFO: Starting the code server...
[2022-09-11T08:54:21.657Z] info Wrote default config file to ~/.config/code-server/config.yaml
[2022-09-11T08:54:22.195Z] info code-server 4.6.0 6d3f9ca6a6df30a1bfad6f073f6fa33c0e63abdb
[2022-09-11T08:54:22.198Z] info Using user-data-dir /data/vscode
[2022-09-11T08:54:22.238Z] info Using config file ~/.config/code-server/config.yaml
[2022-09-11T08:54:22.239Z] info HTTP server listening on http://0.0.0.0:1337/
[2022-09-11T08:54:22.239Z] info - Authentication is disabled
[2022-09-11T08:54:22.240Z] info - Not serving HTTPS
Can anyone help with it? How can I get this addon working?
I had this problem too after restoring a Home Assistant core backup to fix a different problem. I found that I could not start File Editor either, so I am wondering if something in the file system is corrupted?
[2023-03-09T10:49:00.809Z] info Using user-data-dir /data/vscode
[2023-03-09T10:49:00.824Z] info Using config file ~/.config/code-server/config.yaml
[2023-03-09T10:49:00.824Z] info HTTP server listening on http://0.0.0.0:1337/
[2023-03-09T10:49:00.824Z] info - Authentication is disabled
[2023-03-09T10:49:00.825Z] info - Not serving HTTPS
[13:49:06]
[13:49:06] Extension host agent started.
[2023-03-09T10:49:07.299Z] error Forbidden HttpError: Forbidden
at ensureOrigin (/usr/local/lib/code-server/out/node/http.js:288:15)
at wrapped (/usr/local/lib/code-server/out/node/wsRouter.js:64:24)
This exact same issue is happening to me after a power outage at home and the Home Assistant server going down. Now I cannot start the add-on and it’s critical.
Any idea how to fix this?
Thanks in advance.
Same here. It was working this morning, no reboot or power outage and suddenly the add-on stopped and I can’t get it to start again.
add-on log
Add-on version: 5.8.0
System: Home Assistant OS 10.3 (amd64 / generic-x86-64)
Home Assistant Core: 2023.6.3
Home Assistant Supervisor: 2023.06.4
s6-rc: info: service base-addon-banner successfully started
s6-rc: info: service fix-attrs: starting
s6-rc: info: service base-addon-timezone: starting
s6-rc: info: service base-addon-log-level: starting
s6-rc: info: service fix-attrs successfully started
[12:00:51] INFO: Configuring timezone (Australia/Perth)...
Log level is set to INFO
s6-rc: info: service base-addon-log-level successfully started
s6-rc: info: service base-addon-timezone successfully started
s6-rc: info: service legacy-cont-init: starting
s6-rc: info: service init-user: starting
s6-rc: info: service init-mysql: starting
s6-rc: info: service init-mosquitto: starting
s6-rc: info: service init-code-server: starting
s6-rc: info: service init-code-server successfully started
total 28
drwxr-xr-x 5 root root 4096 Jun 30 12:00 .
drwxr-xr-x 5 root root 4096 Jun 30 12:00 ..
drwxr-xr-x 3 root root 4096 Jun 30 12:00 data
drwx-ws--T 2 root root 4096 Jun 30 12:00 event
-rw-r--r-- 1 root root 2 Jun 30 12:00 notification-fd
-rwxr-xr-x 1 root root 419 Jun 30 12:00 run
srwxrwxrwx 1 root root 0 Jun 30 12:00 s
-rw------- 1 root root 0 Jun 30 12:00 s.lock
drwx------ 2 root root 4096 Jun 30 12:00 supervise
s6-rc: info: service init-user successfully started
s6-rc: info: service code-server: starting
s6-rc: info: service code-server successfully started
[12:00:53] INFO: Starting code-server...
s6-rc: info: service init-mosquitto successfully started
s6-rc: info: service init-mysql successfully started
[2023-06-30T04:00:54.182Z] info Wrote default config file to ~/.config/code-server/config.yaml
[2023-06-30T04:00:54.973Z] info code-server 4.14.1 5c199629305a0b935b4388b7db549f77eae82b5a
[2023-06-30T04:00:54.974Z] info Using user-data-dir /data/vscode
[2023-06-30T04:00:54.995Z] info Using config file ~/.config/code-server/config.yaml
[2023-06-30T04:00:54.995Z] info HTTP server listening on http://0.0.0.0:1337/
[2023-06-30T04:00:54.996Z] info - Authentication is disabled
[2023-06-30T04:00:54.996Z] info - Not serving HTTPS
[2023-06-30T04:00:54.996Z] info Session server listening on /data/vscode/code-server-ipc.sock
Supervisor log
23-06-30 11:47:56 WARNING (MainThread) [supervisor.addons.addon] Watchdog found addon Studio Code Server is unhealthy, restarting...
23-06-30 11:47:56 INFO (SyncWorker_0) [supervisor.docker.interface] Stopping addon_a0d7b954_vscode application
23-06-30 11:48:00 INFO (SyncWorker_0) [supervisor.docker.interface] Cleaning addon_a0d7b954_vscode application
23-06-30 11:48:01 INFO (SyncWorker_9) [supervisor.docker.addon] Starting Docker add-on ghcr.io/hassio-addons/vscode/amd64 with version 5.8.0
23-06-30 11:48:11 WARNING (MainThread) [supervisor.addons.addon] a0d7b954_vscode is already running!
EDIT: after multiple attempts to restart it seems to be ok… will see if it stays this way.
[15:26:05] INFO: Configuring timezone (America/Santiago)…
[15:26:06] INFO: Starting code-server…
[2023-06-30T19:26:06.723Z] info Wrote default config file to ~/.config/code-server/config.yaml
[2023-06-30T19:26:07.052Z] info code-server 4.14.1 5c199629305a0b935b4388b7db549f77eae82b5a
[2023-06-30T19:26:07.053Z] info Using user-data-dir /data/vscode
[2023-06-30T19:26:07.063Z] info Using config file ~/.config/code-server/config.yaml
[2023-06-30T19:26:07.064Z] info HTTP server listening on http://0.0.0.0:1337/
[2023-06-30T19:26:07.064Z] info - Authentication is disabled
[2023-06-30T19:26:07.064Z] info - Not serving HTTPS
[2023-06-30T19:26:07.064Z] info Session server listening on /data/vscode/code-server-ipc.sock
