It is possible to flash at least one of the lanbon devices, I assume we are talking about the same device as in this thread, where there are links to a review and some alternative firmwares.
Ah yes, exactly, that’s the one. Good to know you can reflash them. Have you tried one of those first hand, and if yes, what are your impressions of it ?
Yeah I’ve read his review from the thread you linked. But he really focuses on the technical aspects. I was more after subjective impressions about its aesthetics. I thought you might have bought one. The manufacturers images are all photoshop-pimped, so it’s hard to see how it would look in a real home. And it doesn’t look that good in some of the actual in-home photos you can find around the net. Especially the screen quality.
Careful with those, they’re using resistive touch instead of capacitive. Typically that means low spatial touch resolution and slow reactions to touch.
Did you ever find something suitable? I have found many promising form factors on Aliexpress, but I’m reluctant to buy anything because I dont know much about Android or if some company’s device based on “Android” or “Linux” would be open enough for me to say delete all their software and UI and get the thing to run Firefox in kiosk mode or run one of those kiosk apps people use with Home Assistant. Or if it would be possible to wipe the device and install a fresh install of Android or a Linux OS.
I believe we are looking for the same thing. We want something that will replace thermostats and switches and can display our web based Lovelace dashboards. The device must look great and be of high quality, and we want various sizes depending on the room it’s being installed in.
Here are my must haves:
High quality display
Tight radius corners / modern rectilinear design
Must have squared off edges so device can be mounted flush with drywall via custom designed / 3D printed mounts
Glass capacitive touchscreen with uniform bezel and bezel should not be excessively large
Must run kiosk app or Kiosk mode web browser, this rules out HASP, Sonoff NS Panel/Nextion, etc.
Must NOT have a camera, many people, including myself want their homes to remain private
Must have a way for backlight control of screen for use in bedrooms. Ideally it would have built in Time of Flight sensor in bezel to accomplish this, but I’ll settle on other non-camera methods
Speaker, Mono is fine, just want for occasional security camera streams
Here’s my list of nice-to-haves:
PoE
Physical buttons/knobs, these can be integrated into the screen physically, but they can be a separate system, if incompatible with Home Assistant, that’s fine, Can solder something into the buttons like ESPHome or something else as a hack
Other sensors, Lux, PIR, Temp, Humidity if they can be integrated into Home Assistant
Would be great if speaker built into unit could be TTS endpoint in Home Assistant
Things I don’t care about:
It doesn’t need to have a built in dimmer or relay switch, There are plenty of options for those, from traditional smart switches hidden away in room closets, Always powered on smart bulbs, and shelly-like devices that fit in light junction boxes
I don’t care about the state of the house’s wiring or whether or not its code to have Ethernet in a box with 120V wires. I’m planning to build a new house and in my existing houses, I am willing to relocate wires, install new boxes, install custom mounts, and I am willing to tear walls open and do drywall work.
Here are the most promising devices I have found. I guess my ask is if anyone has any pointers or firsthand experience or any other info that would help us in getting the desired result listed in the previous post, out of any devices listed below?
I figure if I can’t get that to do what I want, the LifeSmart ones probably won’t either. I think I’d prefer the life smart lineup for the variety in sizes and having some physical buttons I could use as scene or shade controls
