I have two questions:
- is this Integration also working with awnings, that has a wms module?
- is this the correct Stick?
Thanks in advance
Ingo
Thanks in advance
Ingo
The awnings will likely have a different component type id, the default of 25 (radio motor) could work, but if not it should be easy to add support with a little bit of help from you.
That looks like the correct stick.
Iām keen to try: I cracked open mine but itās not immediately clear to me by just looking at the PCB where antenna ground and signal are wired up to, any pointers?
I got the Stick Working an my Remote was recognized, with the AdIn from santam, in the other version from gianello I get the same log entries.
I am using a warema awing. I entered the ID, the Key and the Channel from the remote.
The log shows me this:
Connected to MQTT
Warema init completed
Registering 1747856
Adding device 1747856 (type 25)
28 13:57:33.581 I Interval for position update: 30 seconds.
28 13:57:34.094 I wmsRetry blindGetPos 90AB1A "{R0690AB1A801001000005}".
28 13:57:34.606 I wmsRetry blindGetPos 90AB1A "{R0690AB1A801001000005}".
28 13:57:35.118 I wmsRetry blindGetPos 90AB1A "{R0690AB1A801001000005}".
28 13:57:35.630 I wmsRetry blindGetPos 90AB1A "{R0690AB1A801001000005}".
28 13:57:36.141 I wmsRetry blindGetPos 90AB1A "{R0690AB1A801001000005}".
28 13:57:36.654 I wmsRetry blindGetPos 90AB1A "{R0690AB1A801001000005}".
28 13:57:37.165 I wmsTimeout 500 blindGetPos 90AB1A "{R0690AB1A801001000005}".
28 13:58:04.100 I wmsRetry blindGetPos 90AB1A "{R0690AB1A801001000005}".
28 13:58:04.611 I wmsRetry blindGetPos 90AB1A "{R0690AB1A801001000005}".
28 13:58:05.122 I wmsRetry blindGetPos 90AB1A "{R0690AB1A801001000005}".
28 13:58:05.635 I wmsRetry blindGetPos 90AB1A "{R0690AB1A801001000005}".
28 13:58:06.148 I wmsRetry blindGetPos 90AB1A "{R0690AB1A801001000005}".
28 13:58:06.661 I wmsRetry blindGetPos 90AB1A "{R0690AB1A801001000005}".
28 13:58:07.174 I wmsTimeout 500 blindGetPos 90AB1A "{R0690AB1A801001000005}".
28 13:58:13.156 E wmsUtil: blindMoveToPos: ang undefined. Assuming 0.
28 13:58:13.669 I wmsRetry blindMoveToPos 90AB1A "{R0690AB1A707003C87FFFFF}".
28 13:58:14.183 I wmsRetry blindMoveToPos 90AB1A "{R0690AB1A707003C87FFFFF}".
28 13:58:14.317 E wmsUtil: blindMoveToPos: ang undefined. Assuming 0.
28 13:58:14.694 I wmsRetry blindMoveToPos 90AB1A "{R0690AB1A707003C87FFFFF}".
28 13:58:15.205 I wmsRetry blindMoveToPos 90AB1A "{R0690AB1A707003007FFFFF}".
28 13:58:15.717 I wmsRetry blindMoveToPos 90AB1A "{R0690AB1A707003C87FFFFF}".
28 13:58:15.929 I wmsRetry blindStopMove 90AB1A "{R0690AB1A707001FFFFFFFF00}".
28 13:58:16.440 I wmsTimeout 500 blindMoveToPos 90AB1A "{R0690AB1A707003C87FFFFF}".
ERROR: timeout
UNKNOWN MESSAGE: {"topic":"wms-vb-cmd-result-set-position","payload":{"error":"timeout","snr":1747856,"snrHex":"90AB1A","name":"1747856","position":0,"angle":null}}
28 13:58:16.654 I wmsRetry blindStopMove 90AB1A "{R0690AB1A707001FFFFFFFF00}".
28 13:58:16.865 I wmsRetry blindStopMove 90AB1A "{R0690AB1A707001FFFFFFFF00}".
28 13:58:17.076 I wmsRetry blindStopMove 90AB1A "{R0690AB1A707001FFFFFFFF00}".
28 13:58:17.287 I wmsTimeout 200 blindStopMove 90AB1A "{R0690AB1A707001FFFFFFFF00}".
ERROR: timeout
UNKNOWN MESSAGE: {"topic":"wms-vb-cmd-result-stop","payload":{"error":"timeout","snr":1747856,"snrHex":"90AB1A","name":"1747856"}}
28 13:58:29.364 I wmsRetry blindStopMove 90AB1A "{R0690AB1A707001FFFFFFFF00}".
28 13:58:29.576 I wmsRetry blindStopMove 90AB1A "{R0690AB1A707001FFFFFFFF00}".
28 13:58:29.788 I wmsRetry blindStopMove 90AB1A "{R0690AB1A707001FFFFFFFF00}".
28 13:58:30.000 I wmsRetry blindStopMove 90AB1A "{R0690AB1A707001FFFFFFFF00}".
28 13:58:30.212 I wmsTimeout 200 blindStopMove 90AB1A "{R0690AB1A707001FFFFFFFF00}".
ERROR: timeout
What can I do? The Server is approximately 5 Meters away from the awing.
Thanks in advance
Ingo
I am curious, I have Warema Raff Stores and Home asistant running. What is not clear to me, is it possible to control the WMS with Home Assistant without further hardware?
and if not, would the WMS stick do this?
thanks! (I have the basic wireless sender without channel selection)
Not with this extension, it needs the WMS stick. Thereās another one with which you can achieve that if you own the WebControl unit: Custom template cover for WAREMA blinds
Thanks in advance
Ingo
USB 3 ports create lots of interference, try using a usb extension cable to avoid that. In general, the range of the stick is quite bad, and even thin walls can completely prevent it to work properly.
no major progress yet - Iām actually almost finished, but as usual the last 20% of the work takes 80% of the time
It still doesnāt. work, no chance even if I am directly under the awing.
Where can I find the Add In Code in my Home Assistant? I want to āinvestigateā the code.
Or is the only way to make a GiHub Copy of the code and import it in the HA?
Ingo
Hey there,
thank you all for your work, it looks amazing. We are a little hackspace located in Germany. Our landlord installed many Warema WMS actors a few of them are motors to control the sun-blinds. We already have quite a big home-assistant setup running with many sensors.
Now our plan is to integrate the WMS sensors into home-assistant, as far as i can understand this thread, we would need a WMS-Stick for that. I can see its around 60ā¬ here so that should be no problem.
My only problem is that the only remotes available are the build-in WAREMA 1002881 remotes. Is it possible to use this addon with only this wall-mounted remote, especially for the setup of the stick?
Thanks already
Luca
Can anybody tell me , where I can buy the stickā¦an if the weather stations are running with this add-on?
Is this topic still alive?
I used the basic remote and it worked so I guess it should work with the wall mounted remotes as well.
I bought the stick online there are multiple dealers offering them for about 50-60 Euro.
Although the addon works it always looses connection to the warema awning. After a couple of restarts of the addon/HA it starts working again. I hope that the updated version will be released soon.
Hello everyone,
I now also have some devices in it.
But unfortunately not all.
Markis works.
Weather Eco only Lux. Wind strength and battery are missing. I still have two Warema adapter plugsā¦they are also missing.
Does anyone here have any idea what I have to do?
@giannello Great work !!! THX a lot!!!
Maybe you can help me a little bitā¦
I have posted logs aboveā¦ What is not detected correctly for me , is the weather ecoā¦
Here the WIND, twilight etc is missing.
Also my warema sockets do not appear in ha.
The shading can be controlled perfectly.
It would be great if that could somehow be integrated.
Oh yes, should I not also be able to control the shading with the handheld transmitter, or should also appear for the handheld transmitter an entity!
weather stations are not supported - donāt have them, canāt test them. same for sockets.
The transmitters do NOT appear as an entity
for the new versionā¦patience is key, not enough time
Thanks for the feedback !!
If I can do something to read something outā¦please let me know. When I enter the serial number of plugs as a force device, they appear as a blinds. Up down arrow switches the plugs. on off.
@Santam what does your modified version look likeā¦ canāt I install it via the addonStore?
I have a weather station, it reads wind and light broadcasts ok-ish, not sure about the accuracy. No need to add the weather station among the devices. Temperature is not working well but canāt figure out the protocol. Plugs are not working with the extension at the moment. I donāt use HomeAssistantOS so I am not sure how the addonStore works sorry.
Thx for reply!
What kind of weather station do you have?
Iāve got the Warema ecoā¦. It only shows lumā¦. No wind.
Maybe @giannello can integrate this in his versionā¦.
Can someone tell me how I can automatically get the status from the awning after a restart of ha?
Until I move the awning, it says unknownā¦and is of course stupid if I have an condition with close or open in an automationā¦
