Water heater card to match the more info dialog
The thermostat card was recently redesigned in https://github.com/home-assistant/frontend/pull/18709 to match the design of the climate more info dialog. The water heater more info dialog has a similar design, and it would be great to have this as a dashboard card as well.
Related:
i agree! should be a quick fix!
And it should be higher up on priority as it is very generic to all water heaters, it’s not brand specific
Gets my vote too !
Yes needed!
I am in with the request. I recently bought a thermos compatible with HA and I presumed that it was compatible with the Weather card.
It would be very much appreciated…
Ireally want this. Why the water heater thermostat card doesn’t work like the climate control card is baffling. The functionality is there. We just can’t see it on the dashboard without going into more info.
I want this too. Actually surprised they are two different domains
Me to :smiley: ++
+1 - I don’t have the skills but this can’t be that hard?
HA 2025.6.0 changed some things in SmartThings. Now my heaters in my heat pump are shown as water_heater. If I click on it, it shows a dialog similar to the thermostat card. So the UI for water heater is available. Why can’t we use it in Lovelace then?
I have to bump this!
I would love this too for a my Pool Heater…
+1 – I was looking for it, thinking I was a beginner and could not find a way to make it.
Thermostat card will be gaining water_heater support in 2025.10.
