Week number as condition
I need a automation that runs every wednesday but only if the week number is even.
Post the automation you’ve created and we can help you with it.
For example, this provides the week number:
now().isocalendar()[1]
and this provides the weekday:
now().weekday()
This condition checks the week number, if it’s even. Change the U to W if you want your weeks to start on monday. Otherwise with the U they start on sunday.
- condition: template
  value_template: "{{ not now().strftime('%U') | int % 2 }}"
This condition does Wednesday.
- condition: time
  weekday:
    - wed
EDIT, if you want only 1 condition…
  value_template: "{{ now().weekday() == 2 and not now().strftime('%U') | int % 2 }}"
EDIT2: This appears to be 1 week off from now().isocalendar()[1]. So, if you want to check the iso week…
  value_template: "{{ not now().isocalendar()[1] % 2 }}"
The kicker behind this is the % symbol. It means mod. When you mod a number, it returns the remainder if you were to divide the value by the modded number. I.e. if you divide 7 / 2, the remainder is 1. So if you had an even number, the remainder would be 0 and an odd number, the remainder is 1. 1 in jinja means true and 0 in jinja means false. So if we want to find even weeks, we want to look for not 0, as weird as it sounds.
In the spirit of helping others help themselves, don’t overlook to use the forum’s search function to find existing solutions.
For example, searching for “week number” reveals dozens of posts explaining how to calculate it and how to get even/odd weeks.
https://community.home-assistant.io/search?q=week%20number
I’m pretty sure it’s now().weekday(), not now().weeday() :wink:
weeday is always april 20th
I edited the post
really? why?
that was a crappy 420 joke, i try keep up with the memes
So if I need to find uneven/odd weeks I should just remove the not?
yep, thats it
But this gets never activated
- id: '57301120985673214'
  alias: DALS change evening tuesdays uneven weeks
  - at: '17:45'
    platform: time
  condition:
  - condition: state
    entity_id: device_tracker.google_maps_107871620809366577942
    state: home
    value_template: "{{ now().isocalendar()[1] % 2 }}"
  - condition: time
    weekday:
    - tue
  - service: tts.google_say
    entity_id:
    - media_player.googlehome7596
      message: Det är skiftbyte snart, jag låser upp
      language: sv
      entity_id: input_boolean.dals_change_period
  - service: lock.unlock
      entity_id: lock.polycontrol_danalock_v2_btze_locked_2
  - service: input_boolean.turn_off
      entity_id: input_boolean.dals_daytime_tasks
      entity_id: input_boolean.dals_nighttime_tasks
how could you have tested that already? You added this yesterday, which was thrusday and this week is the odd week. You have to wait 2 weeks if you keep the tuesday condition.
I asked yesterday because I noticed that it wasn’t working in Thursday.
It’ll only work Tuesday because of your condition. It will not work Thursday.
Hey hoping I can add to this thread and get some help. Im trying to have my lights turn on at different times on alternating weeks. At the moment I have two automations with different conditions. It could probably be done in one but in any case this simple addition of the template condition causes the automations to fail to trigger. The script was working fine before splitting in two and addidng the template condition. Any suggestions?
- id: weekday_bedroom_light_1
  alias: Weekday Light Before Sunrise 1
  - at: 05:50:00
    platform: time
  condition:
  - before: sunrise
    before_offset: -00:30:00
    condition: sun
  - condition: state
    entity_id: binary_sensor.workday_sensor
    state: 'on'
    value_template: {{(now().strftime('%U') | int % 2) == 1}}
  - service: script.morning_routine
- id: weekday_bedroom_light_2
  alias: Weekday Light Before Sunrise 2
  - at: 05:20:00
    platform: time
  condition:
  - before: sunrise
    condition: sun
  - condition: state
    state: 'on'
    value_template: {{(now().strftime('%U') | int % 2) == 0}}
The automation is triggered at a specific time (05:50:00) then the first condition checks if the current time is a specific offset of sunrise. Unless that also happens to be 05:50:00 the first condition evaluates to false and the action isn’t executed.
tl;dr
You’ve created a nearly impossible combination of trigger and (first) condition.
Thanks for your reply but its only the template condition that has broken this. Its been working for years otherwise. The “before” condition is true if the current time is at least 30 mins before sunrise.
Where I live, sunrise is currently at 06:15. Thirty minutes before sunrise is 05:45. When the automation triggers at 05:50, that’s 5 minutes too late to satisfy the first condition.
Anyway, your template condition requires outer quotes. Like this:
value_template: "{{(now().strftime('%U') | int % 2) == 1}}"
Hi Gues.
I am hoping to be able to use the week number in a slightly different way, than all the above and I can not see how to derive the right solution from the above.
I wan tto use the week number as a condition, like this:
- id: '1601361501256'
  alias: Lys_Laura - arbejdsdag 0700 - tænd planterne
  description: ''
  - platform: time
    at: 07:00:00
  condition:
  - condition: state
    state: 'on'
### AND only if WEEK_NUMBER is not (7,26-30,42) ###
  - service: light.turn_on
    data: {}
    entity_id: light.planterne
  mode: single
I believe something like this:
{{ now().isocalendar()[1] not in [7,26,27,28,29,30,42] }}
This returns false now since it’s week 42.
And that should make the condition false and thus not trigger.
