What is [PATH_TO_YOUR_HOME_ASSSISTANT]/scripts/ in Hassio on top of Raspbian Buster on Pi4?
Disclaimer: This question is a follow up on my other question Which user is running Hassio on top of Raspbian Buster on Pi4?
Like many others, I am trying to set up a bluetooth speaker with my home assistant installation. That is my final goal at least.
My set up is like this: SSD booting Raspbian Buster on Pi4, Hassio on top (Docker) [Rpi 4 installation].
At Github, there is this project, “TTS Bluetooth Speaker for Home Assistant” [https://github.com/pkozul/ha-tts-bluetooth-speaker]. There is also a great tutorial on how to set it up.
One of the steps is to create the file [PATH_TO_YOUR_HOME_ASSSISTANT]/scripts/pair_bluetooth.sh and add content to it. My only problem is that I do not understand where to start looking. Where do I find [PATH_TO_YOUR_HOME_ASSSISTANT]?
This is the output for sudo find / -type d -name "scripts" in a terminal for my Pi (SSH):
What is [PATH_TO_YOUR_HOME_ASSSISTANT] in my case?
That should be the HA config dir, i think.
Take a look in Dev Tools/info
If there’s no script folder, create it.
