Like many others, I am trying to set up a bluetooth speaker with my home assistant installation. That is my final goal at least. But for now, I am not even close.
Anyway…
My set up is like this: SSD booting Raspbian Buster on Pi4, Hassio on top of that (https://community.home-assistant.io/t/rpi-4-installation/123514/87). (“On top” are the words used in the guide.)
At Github, there is this project, “TTS Bluetooth Speaker for Home Assistant” [https://github.com/pkozul/ha-tts-bluetooth-speaker]. There is also a great tutorial on how to set it up.
Unfortunately, I believe I am missing something because when I try to follow the instructions, and run a certain command, sudo adduser homeassistant pulse-access, in the Pi terminal (via SSH) I get an unwanted result:
adduser: The user homeassistant’ does not exist.`
I believe that there is something I do not understand here. Which user is running homeassistant on my Pi?
