Where's the config.txt file
Hello all
I’m trying to enable my RaspBee 2 on a Raspberry 4. I need to add a few lines to the config.txt file. I’ve read many guide where the file is but I can’t find it.
I’m a very recent image from the ofiicial image (Raspberry Pi - Home Assistant) and also use balena to flash.
When I add the sdCard unter my Ubuntu laptop the card is automatically mounted and I see 4 volumes:
  • disk
  • hassos-data
  • hassos-kernel
  • hassos-overlay
The config.txt file should be in the /boot folder. The “disk” volume has all the usual folder: bin, dev, home, lib, root, var… but there’s no boot folder.
Some guides also say, that the config.txt file is in the root folder. But there’s also no config file in any root folder of a volume.
A search for config.txt on all drives didn’t find any drive aswell.
Could anybody tell me where I find this file before my hair turns grey, thank you. :slightly_smiling_face:
Maybe
Thanks. There are really 8 different partitions on the official Home Assistant image…
I found a config file here:
sudo mount -t vfat /dev/sdc1 /mnt/sdcard
sudo vim /mnt/sdcard/config.txt
#make your changes in the file (and exit with wq)
sudo umount /mnt/sdcard
Let’s hope this is the right config file
The post explicitly says it’s the 1st partition, so I suppose it is.
Thanks @koying . You just saved my day and my home assistant project. Thank you and have a good week!
Hi everybody!
I am getting crazy to get this work. Can’t access the config.txt file
Could you please explain step by step how to edit the /mnt/boot/config.txt file? I need this to Enable GPIO bus support in HAos for RaspberryMatic
I can access the Home Assistant command line via ssh on port 22 but I am stuck at
[core-ssh ~]$
Thank you in advance for your help
(I am on macOS)
apparently we have to enable ssh on port 22222 to acess that
I still think its stupid I have to find a blank USB drive around to put
authorized_keys onto to enable it ... still trying to find the fkn import from USB button ...
but then found this
but port 22222 still not active
so in the end needed a blank USD drive formatted as FAT called CONFIG with a authorized_keys file
and /mnt/boot/config.txt has finally been altered they were even nice enough to completely remove #dtoverlay=w1-gpio
I ended up with a bootable USB with Ubuntu and from there I SSH into the SD card and edited the config.txt
just crazy
You have to hard-reboot to make the underlying operating system reload. It works. I tested it today.
@pascal1 @koying thanks a lot. That helped me. Raspbee 2 is working.
I put the sd card in a windows pc and edited the file directly with notepad.
