I’m using Z2M with Sonoff Dongle-P as the coordinator.
Which and where should I download a firmware and flashing tool for Sonoff Dongle-E variant that will be used as a router?
Thanks!
Thanks!
Do not confuse “Sonoff ZBDongle-P” with “Sonoff ZBDongle-E”! They are based of radio SoC(s)/MCU(s) from different manufacturers so you can not use the same firmware or flashing tools! If you want to flash a “Sonoff ZBDongle-P” then use firmware and tools for it, and the same goes for “Sonoff ZBDongle-E”. It does not matter what other devices you have, it is only the device that will be flashed that matters. So if you want to flash “Sonoff ZBDongle-E” as a Zigbee Router then you only need to concern yourself with it, regardless which Zigbee Coordinator you have. See these threads which have links to firmware (including link to Zigbee Router firmware for “Sonoff ZBDongle-E”) and if you have any further questions about flashing then post in the questions in those respective threads:
I read this post and I used the official router firmware for Dongle E with SecureCRT flash unitlity.
Flashing was successfull.
However, once I plug the dongle to a power source, it is not getting picked up by Z2M.
https://www.zigbee2mqtt.io/devices/ZBDongle-E.html
if not, press one of the buttons to set it into pairing mode
“Finally, the dongle LED blinks green, inidicating it is in paring mode. Pair as usual with Z2M”
This is in green color and still doesn’t show in Z2M
Is your Z2M in pairing mode ?
Else:
Z2M is set to Permit Join All.
As I said, if it still don’t want to pair, restart Z2M and bring the router closer to the coordinator. Also try another power supply.
I have removed a zigbee led I have, and it rejoined automatically.
so I know that Z2M can pair.
I placed the router very close to my coordinator to no avail
I am having the exact same issue. I flagged with.gbl file and for some reason the stick doesn’t go into pairing mode. As in the green led stays on. I’ve flashed several times but still the same outcome. I’ve tried pressing reset but still it can’t get picked up on z2m from coordinator or “join all”.
Did you figure this out?
got it working @abulhr. The missing step is.
to put the dongle in pairing mode. Press and hold the boot button for 5 seconds. The green light will flash.
You’re a God-send!
Thank you very much
For Mac users there is a super simple way based on https://www.unixfu.ch/upload-firmware-to-a-switch-with-xmodem-from-a-mac/.
ls /dev and find your dongle path, something like /dev/tty.usbserial-11111111:exec !! lsx -b -X /path/to/gbl/filescreen /dev/tty.usbserial-11111111 115200 8 1hi there
where is everyone getting this latest firmware for E dongle router mode from?
This is firmware for the zigbee Dongle E as coördinator.
I have used this official Sonoff web online flasher twice and it works like a charm: SONOFF Dongle Quick Flasher | SONOFF Official
How do i put the Sonoff zdongle in paring mode?
After flashing the Router firmware, holding the Boot button for more than 8 seconds can trigger the device to enter pairing mode.
Alternatively, a simpler method is to re-flash the Router firmware using SONOFF Dongle Flasher.
Nice. I tryed the boot button but i did not work. Doing reflash with my labtop at the place it wil be used worked ![]()
