What’s the best weather integration people are using?
I’d like weather forecasts (3-6 days if available)
I’d prefer a core one if possible.
This custom component:
I believe the plan is to integrate it into the core components eventually but it does not look like the developer has had time to work on it lately. Still, it works very well, especially when combined with this card:
Thanks. Yeah I think that one seems the top contender from my research.
I’ve gone a bit off custom components which is why I was hoping for a core one.
Fingers crossed this one becomes core soon.
The core BoM integration was removed because it used web scraping to gather data.
Bram developed the custom integration in response.
Beginner here. Is it possible for me to play alert notification on google home based on certain parameters like at 7AM it will broadcast to my google home speakers if its going to rain (% chance of rain) ?
Sure that is possible with an automation. Please start your own topic about it as it is not within the scope of this year old topic. How to help us help you - or How to ask a good question
Is this integration going to keep working after 14 March 2023? Github says “ This grabs data from an undocumented API that is used to provide data to https://weather.bom.gov.au/“ and that page says “ This page will be retired on 14 March 2023”
Not sure if is just the web page that is going to be retired or the undocumented API too.
Good point
We’ll find out on the 14th March.
The BoM app uses the same API as the web page, so the integration should continue to work. It’s only the website that is being retired.
thanks for confirming.
Can I confirm if the BOM integration is still working, the page for the Integration says it’s no longer maintained. Mine doesn’t seem to be updating unless I reload Integration. I am on 1.2.0 I tried upgrading to 1.3.2 but the Integration page still shows I’m running 1.2.0?
Any feedback welcome, I’m not sure what is going on here.
Don’t believe the badge. It’s broken. There was a release only a week ago:
Working fine here.
HACS ('Im using the experimental interface):
Do you have a custom repository set for this integration?
You shouldn’t. It is a default HACS repository.
You’re on the latest version (1.3.2).
Looks like they forgot to update the version number somewhere. I see 1.2.0 on the Device page too.
Sweet, thanks for confirming.
I am using @mlamberts78 Weather Chart Card to display my weather in Tasmania.
I use a combination of the out of the box Meteorologisk institutt (Met.no) & HACS installed BOM Weather once downloaded you install from the Devices and Services Page.
You can see that the Condition is not updated as often with the BOM Weather. BOM seems to follow what the weather condition will be over all for the day, rather than hour by hour.
In the below image the top chart displays my hourly data. I use Meteorologisk institutt (Met.no) as the weather condition updates more regularly inline with the weather. Also gives a better per hour rain.
The bottom chart is data from BOM, I use this for my long term forecast, ideal because it give chance of rain and the amount.
Large Screen Conditional Card Code for the above cards. (A fair few configuration customization have been made to make these look like they do.
# THIS IS THE TOP CARD
- type: conditional
conditions:
- condition: screen
media_query: '(min-width: 768px)'
card:
type: custom:weather-chart-card
entity: weather.home
show_main: true
show_temperature: true
show_current_condition: false
show_attributes: false
show_time: true
show_day: true
show_date: true
show_humidity: false
show_pressure: false
show_wind_direction: false
show_wind_speed: false
show_sun: false
show_feels_like: true
use_12hour_format: false
icons_size: '60'
animated_icons: true
icon_style: style1
forecast:
precipitation_type: rainfall
labels_font_size: '18.5'
precip_bar_size: '70'
precipitation_color: darkslateblue
style: style2
show_wind_forecast: true
condition_icons: true
round_temp: false
type: hourly
chart_height: '178'
chart_text_color: white
show_probability: true
disable_animation: false
units:
pressure: hPa
speed: km/h
current_temp_size: '140'
temp: sensor.netatmo_devonport_tas_indoor_outdoor_temperature
title: ''
winddir: sensor.devonport_airport_wind_direction
windspeed: sensor.devonport_airport_gust_speed_kilometre
humid: sensor.netatmo_devonport_tas_indoor_outdoor_humidity
press: sensor.netatmo_devonport_tas_indoor_pressure
feels_like: sensor.outside_feels_like_temperature
show_time_seconds: false
time_size: '80'
day_date_size: '40'
uv: null
dew_point: sensor.dewpoint_outside
wind_gust_speed: sensor.netatmo_devonport_tas_indoor_wind_gust_strength
show_dew_point: false
show_wind_gust_speed: false
show_last_changed: false
# THIS IS THE BOTTOM CARD
- type: conditional
conditions:
- condition: screen
card:
entity: weather.devonport
show_main: false
show_temperature: false
show_time: true
show_day: true
show_date: true
show_sun: false
icons_size: '40'
icon_style: style1
forecast:
precip_bar_size: '80'
style: style2
show_wind_forecast: false
round_temp: false
type: daily
chart_height: '200'
temperature2_color: deepskyblue
units:
pressure: hPa
speed: km/h
current_temp_size: '40'
show_dew_point: true
- type: conditional
conditions:
- condition: screen
media_query: '(min-width: 0px) and (max-width: 767px)'
card:
show_main: false
show_time: false
show_day: true
show_date: true
show_sun: false
show_feels_like: false
icons_size: '40'
icon_style: style1
forecast:
labels_font_size: '11'
style: style2
round_temp: false
type: daily
chart_height: '100'
units:
pressure: hPa
speed: km/h
Small Screen Conditional Card Code for the above cards.
#TOP CARD
- type: conditional
conditions:
- condition: screen
card:
show_main: true
show_time: true
show_day: true
show_date: true
show_sun: false
icons_size: '30'
icon_style: style1
forecast:
labels_font_size: '13'
style: style2
round_temp: false
type: hourly
chart_height: '100'
units:
pressure: hPa
speed: km/h
current_temp_size: '30'
title: ''
time_size: '30'
day_date_size: '10'
uv: null
# BOTTOM CARD
- type: conditional
conditions:
- condition: screen
card:
show_main: false
show_time: false
show_day: true
show_date: true
show_sun: false
icons_size: '40'
icon_style: style1
forecast:
style: style2
round_temp: false
type: daily
chart_height: '100'
units:
pressure: hPa
speed: km/h
BOM Provides a heap of other sensors that you can drive automations with and extract data.
This post gives a guide to what BOM Provides.
Sorry to revisit this, Does your current temp update regularly? Mine is now 2 days out of date. I installed Tommor.io integration to test and it updates every couple of hours. I’m sure the BOM data used to update but it appears to have stopped recently. Any thoughts?
