Seems to still work for me going from 96.x
Great news. Please can You share Your configuration, thermostat model and vendor? Whatās Your impression after using it for a while? Does it work offline (w/o internet)?
Iām choosing between Z-Wave thermostats (very expansive) and WiFi (most of them works over internet).
Thanks for any information.
Mine was an eBay one, I did list and take loads of pics ain a forum post on here.
Iāll pull my config tomorrow as SSH access on my phone is a pain.
- platform: floureon
host: 192.168.1.148
mac: 78:0f:77:d4:29:0f
check_interval: 120
and here is the link to the post I made with Pics
https://community.home-assistant.io/t/cheap-ebay-wifi-heating-controller/76663
Excellent!
Please confirm this:
- Youāre using this component https://github.com/algirdasc/hass-components/tree/master/floureon
- Your thermostat doesnāt have internet access and You can control it over Home Assistant
If yes on both questions I will buy a similar thermostat.
Yes to both.
Iāve blocked all internet access fro. my firewall for this device. Tho I do believe you need internet when you first setup the device, and I seem to remember reading that the app sent the WiFi password in plain text to the thermostat (tho I canāt find where I read that)
Hi all. Iām totally new in HA, iām reading forum and sites to learn it. I own a Floureon thermostat and want to use it in HA. I have some question:
- Which is the component to use? Clemental or Algirdasc?
- Is the Clemental component integrated in HA (iām still waiting my Raspberry to install HA for the first time) and working on latest HA?
- On Algirdasc component how schedule works? I have seen an optional parameter related to, but how it should be used?
Thank you.
- Sorry, i canāt understandā¦ Pid support is now working well or not? I read in the past that you wanted to
remove itā¦ - What do you mean for āECO presetā?
PID is not working well and Iām planning on removing this feature as it is not proven itself and it is too complex. If you need PID feature it could be achieved by external tools or automation (such as NodeRED). Iām planning update component when heating season comes, somewhere around begining of October
Hi there!! Iām totally new with home assistant. Actually i am not able to communicate with my beko thermostat. I have tried all the configurations posted here and nothing worksā¦ could anyone post his configuration? Folders, files inside and configurationfile please?
Thanks a lot!!
Few posts up someone has done just that.
FrankieFourFinger on the 28th of Jul
Hi algirdasc. Iām using your component now with my Floureon thermostat. It is working but i think there is a bug:
- My setting inside Floureon is 19Ā°C target temp and 16Ā°C min temp (away temperature).
- Timer setting for only to work from 18:00PM to 22:00PM 7 days/week.
Problem is that if i click on AUTO toggle on thermostat HA panel, temperature is always set to 19Ā°C even if the time is out of work period. This is a wrong behavior because if i activate AUTO mode outside of the working time, set temperature must remain to 16Ā°C (away temp).
To have back thermostat temp in right setting i have to open standard thermostat APP and click AUTO there.
Thanks, iāll give it a try!
Actually it did not workā¦
Here it is my configuration:
/home/homeassistant/.homeassistant/configuration.yaml
# Configure a default setup of Home Assistant (frontend, api, etc)
default_config:
# Uncomment this if you are using SSL/TLS, running in Docker container, etc.
# http:
# base_url: example.duckdns.org:8123
# Text to speech
tts:
- platform: google_translate
group: !include groups.yaml
script: !include scripts.yaml
climate:
mac: "78:0F:77:EB:DB:1E"
host: 192.168.0.12
check_interval:
seconds: 30
scan_interval:
seconds: 15
Then, the content of my folder /home/homeassistant/.homeassistant/custom_components/floureon:
climate.py
manifest.json
__init__py
Is everything all right?
I have the following error:
Platform error climate.floureon - Integration floureon not found.
Thanks a lot.
Iāve not got the init.py file, but i do have a pid_controller.py
Did you get those files from right link (there are bout 3 different links to different projects in the threadā¦)
Thanks, Iāll look in to this situation.
Same error with algirdasc filesā¦ Iām doing something wrong but I donāt know what is itā¦
@Layer3
The right name of the file is __init__
.py
You see the ādotā in it?
@cooljimy84
It is obligatory to have a file __init__.py
in custom components. Donāt remember from which version of HA exactly.
Hello once again.
I have received a thermostat. Will be at installation location only on weekend. Now test it. Found one caveat. After power disconnect it remember temperature, mode and scheduling. But doesbāt remember time and day od week.
Did You try to power it down? If it is forbidden to access internet for this device how can it take a time (NTP for example)?
Time will be set by floereon component.
