Yes, you are right. If thermostat is not appearing - check your home-assistant.log, there might be written the cause. But at the moment, I see that your MAC lacks last couple of digits.
Flouren component uses probe temperature senor by default. Do you have it connected? Also, does your climate device show up in âStatesâ page? Could you try installing broadlink python module manually:
Works now - many thanks @algirdasc
Don´t you know if it is possible to change history temperature scale inside thermostat card? I found a post about changing graph scale but this is about standalone card.
I mean this: - to have scale from 15 to 30.
@algirdasc Thank you for sharing with us this component. Is there a way to make a modified version where there is only heat/off option and also without present (none/away).
Hi
Looking for help. Cannot connect Beok wifi or Floureon wifi to Iphone. After updated iphone IOS cannot see device on app.
Can anyone help to sorted issue.
Hi guys, hi @clementTal, hi @Emmanuel,
iâm trying to add the BroadlinkWifiThermostat âBEOK BOT-313WiFiâ following the instructions and coding found on Hassio forum and Github repositories.
These thermostats has two temperature sensors - external NTC sensor (external_temp. I donât know if all has it, but at least floor heating thermostats do) and inner temperature sensor (room_temp). Also, Iâm currently working on switch/sensor component to implement own thermostat logic. Iâll keep you informed.
Iâve decided to start a new topic for this component as information here a mixed with other component. For my component, please look here: Floureon / Beok based thermostat component
