I just wanna to mention that User and Password cannot be the same. A Samba process will stop. You need to specify a username different then a password.
Hass.io is installed on my synology as docker so i don’t know what to put in
interface: if i specify eth0 or eth1 i got an invalid run with : interpret_interface: Can't find address for eth1 (same with eth0) what is the value i should enter (if i let i got an error too)
thanks
Hello, I managed to copy the snapshots in the snapshot folder after I configured as network address, but for the addon folder it does not work, it shows addon folders inside each other with no end … any tips?
After the latest windows 10 update I can no longer access my Home Assistant with Samba. All my android devices and Chromebooks work correctly. Network path issue in Windows.
Samba log shows
netbios connect: name1=HOMEASSISTANT 0x20 name2=OFFICE 0x0
netbios connect: local=homeassistant remote=office, name type = 0
Regardless of what I put in i get a the same error - "TypeError: Cannot read property ‘value’ of null’. When i press save,under config box under the addon. I’ve stripped it all out to a single line same error any pointers as to what i’m doing wrong on this?
seems to have resolved itself, I pressed save and left the wheel spinning rebooted a while later and the config is saved, Samba share is now working and accessible via windows
I had the issue that I couldn’t access HA from my laptop anymore, no file haring stuff and not even the web interface. Enabled SMB1 but still nogo.
Today I deinstalled Nord VPN, and look and behold, it’s working again…
I had trouble with this until I looked at the log file and one of the comments from about 18 months ago about putting the address into Explorer in Windows with the \\name format.
The log file told me the name it was broadcasting which was “homeassistant”… so after restarting Samba I entered \\homeassistant into Explorer, and was asked for the credentials in the Samba config file - and I was away.
I had been expecting it to come up in Network… but I have now pinned it to Quick Access - I could also map a network drive for the config folder I guess.
