The first one refers to a script, without knowing the contents of the script I cannot tell you the difference
The last one looks okay, but missing the target thou - try switching to UI mode rather than YAML for your services under developer tools.
Thank you again.
Yes, the script is one created by Barmalej’s package. However reading through the config files, I think it is just calling your service and adding attributes.
Thanks for the help
Hi, I’ve got the card not recognized anymore from this morning, someone else have the same problem?
Checked the log, I’ve got this:
Logger: frontend.js.latest.202207070
Source: components/system_log/__init__.py:190
First occurred: 12:33:11 (6 occurrences)
Last logged: 13:29:05
http://xx.xx.xx.xx:8123/local/landroid-card.js:1:19759 Uncaught ReferenceError: regeneratorRuntime is not defined
http://xx.xx.xx.xx:8123/local/landroid-card.js:1:19777 ReferenceError: Can't find variable: regeneratorRuntime
I have no idea…
Please Update landroid-card to 0.1.4 version and clean cache your browser
damned cache!
it work
Current zone will be in 0.1.5
thx
and all setting?
Coming soon. I can’t say yet. Need a bit more time
The other day I have tried to add Italian translation in your project, probably on a bad way… Could you please add it?
Very nice work!
Where can I check which “Status._info.id” belongs to which “description”?
Could you have any information?
Thank you
Hello I have a landroid w147. I have successfully installed landroid cloud and want to set my landroid in party mode when I’m gone. I setup the call service and I keep getting this error when the automation triggers “(Nancy, Service Call) The called service, partymode, is not supported by this device!
(Nancy, Service Call) Supported services for this device: [‘lock’, ‘setzone’, ‘refresh’, ‘restart’, ‘config’]” . My w147 supports party mode within the landroid app itself. Any ideas?
Publish it here. Thanks
Awesome thank you!
0: STATE_IDLE,
1: STATE_DOCKED,
2: STATE_STARTING,
3: STATE_STARTING,
4: STATE_RETURNING,
5: STATE_RETURNING,
6: STATE_RETURNING,
7: STATE_MOWING,
8: STATE_ERROR,
9: STATE_ERROR,
10: STATE_ERROR,
11: STATE_ERROR,
12: STATE_MOWING,
30: STATE_RETURNING,
31: STATE_ZONING,
32: STATE_EDGECUT,
33: STATE_STARTING,
34: STATE_PAUSED,
Thx mate
"status": {
"auto": "Pulizia automatica",
"charging": "In carica",
"cleaning": "Pulizia",
"docked": "In base",
"edge": "Pulizia bordo",
"error": "Errore",
"idle": "Fermo",
"mopping": "Lavaggio",
"offline": "Disconnesso",
"paused": "Pausa",
"returning": "Ritorno in base",
"returning home": "Ritorno in base",
"segment cleaning": "Pulizia settore",
"single_room": "Pulizia stanza",
"spot": "Pulizia angoli",
"stop": "Fermato",
"unknown": "Sconosciuto",
"edgecut": "Taglio bordi",
"initializing": "Inizializzazione",
"mowing": "Taglio",
"rain_delay": "Ritardo pioggia",
"starting": "Avvio",
"zoning": "Ricerca zona"
"attr": {
"current": "Attuale",
"description": "Descrizione",
"id": "ID",
"reset_at": "Reset",
"reset_time": "Tempo di reset",
"accessories": "Accessori",
"battery_level": "Livello batteria",
"battery": "Batteria",
"cycles": "Cicli",
"total": "Totale",
"temperature": "Temperatura",
"temperature_measurement": "°",
"voltage": "Tensione",
"voltage_measurement": "V",
"percent": "Percento",
"percent_measurement": "%",
"charging_value_true": "si",
"charging_value_false": "no",
"partymode_enabled": "Modo festa",
"lock": "Blocco",
"blades": "Lame",
"total_on": "Totale on",
"current_on": "Corrente on",
"error": "Errore",
"firmware": "Firmware",
"auto_upgrade": "Auto upgrade",
"version": "Versione",
"locked": "Bloccato",
"mac_address": "MAC Address",
"model": "Modello",
"online": "Online",
"orientation": "Orientamento",
"pitch": "Beccheggio",
"roll": "Rollio",
"yaw": "Imbardata",
"rain_sensor": "Sensore pioggia",
"delay": "Ritardo",
"triggered": "Attivo",
"remaining": "Rimanente",
"schedule": "Programma",
"time_extension": "Estensione tempo",
"active": "Attivo",
"auto_schedule": "Programma auto",
"settings": "Parametri",
"enabled": "Attivato",
"primary": "Primario",
"secondary": "Secondario",
"start": "Avvio",
"end": "Fine",
"duration": "Tempo",
"boundary": "Confine",
"monday": "Lunedì",
"tuesday": "Martedì",
"wednesday": "Mercoledì",
"thursday": "Giovedì",
"friday": "Venerdì",
"saturday": "Sabato",
"sunday": "Domenica",
"serial_number": "Numero di Serie",
"status_info": "Info stato",
"time_zone": "Fuso orario",
"zone": "Zona",
"index": "Indice",
"indicies": "Indici",
"starting_point": "Punto di partenza",
"capabilities": "Capacità",
"One-Time-Schedule": "Programma unico",
"Party Mode": "Modo festa",
"Motor Torque": "Coppia motore ",
"mqtt_connected": "MQTT Connesso",
"supported_landroid_features": "Funzioni Landroid supportate",
"party_mode_enabled": "Modo festa attivato",
"rssi": "Qualità WiFi",
"statistics": "Statistiche",
"worktime_blades_on": "Tempo di lavoro con le lame",
"distance": "Distanza",
"worktime_total": "Tempo di lavoro totale",
"torque": "Coppia",
"state_updated_at": "ultimo aggiornamento a",
"device_class": "Classe dispositivo",
"friendly_name": "Friendly name",
"supported_features": "Funzioni supportate"
"source": {
"gentle": "Delicato",
"silent": "Silenzioso",
"standard": "Standard",
"medium": "Medio",
"turbo": "Turbo",
"normal": "Normale",
"high": "Alto",
"strong": "Forte",
"quiet": "Silenzioso",
"max": "Max",
"max+": "Max+"
"common": {
"name": "Landroid Card",
"description": "Landroid card vi permette di controllare il vostro robot tagliaerba.",
"start": "Avvio",
"continue": "Continua",
"pause": "Pausa",
"stop": "Stop",
"return_to_base": "ritorno in base",
"locate": "Localizza",
"not_available": "Non disponibile",
"error": {
"missing_entity": "Entità mancante!"
"warning": {
"actions_array": "ATTENZIONE: 'azioni' è riservato alla modifica delle azioni predefinite per i pulsanti esistenti. Se vuoi aggiungere azioni, usa invece l'opzione "scorciatoie"."
"editor": {
"entity": "Entità (Richiesto)",
"camera": "Camera (Opzionale)",
"image": "Immagine (Opzionale)",
"compact_view": "Vista compatta",
"compact_view_aria_label_on": "Attiva vista compatta",
"compact_view_aria_label_off": "Disattiva vista compatta",
"show_name": "Mostra nome",
"show_name_aria_label_on": "Attiva mostra nome",
"show_name_aria_label_off": "Disatttiva mostra nome",
"show_status": "Mostra stato",
"show_status_aria_label_on": "Attiva mostra stato",
"show_status_aria_label_off": "Disattiva mostra stato",
"show_toolbar": "Mostra toolbar",
"show_toolbar_aria_label_on": "Attiva mostra toolbar",
"show_toolbar_aria_label_off": "Disaattiva mostra toolbar",
"code_only_note": "Nota: rendere disponibili le opzioni di azioni e statistiche solo tramite l'editor di codice."
"units": {
"days": "giorni",
"hours": "ore",
"minutes": "minuti",
"d": "j.",
"h": "h.",
"min": "min."
map
to camera
Thank you!
update at 1.5 clear cache but the card is blank
