Adding a Lovelace card that acts like a true popup window would be very helpful. Having 4 states (general - no icon, Info - w Info icon, Warning - w Warning icon and Critical - w Critical icon) and two or three configurable buttons ( OK, CANCEL) as a basic minimum.
This would differ from Persistent notification in that the window would pop up on top of the current active window. Some users have asked for a configurable More Info window. This proposal could cover that scenario as well as uses where the user needs to act immediately.
May I respectfully disagree with WTH?! No custom pop-up out of the box? being marked a duplicate of this?
I think that other WTH is about creating modal dialogs, filled with cards. While this one is very specifically talking about confirmation dialogs with one icon and a set of buttons.
I think both are reasonable suggestions (even though Iâm personally only interested in the other), but they arenât the same to me.
@hheimbuerger
I believe he may be referring to this WTH post, with yours being a duplicate of that post, not mine. Just my thought.
https://community.home-assistant.io/t/wth-cant-i-use-a-card-as-more-info-popup/802493/14
Neither of them is my post, but thatâs besides the point. ![]()
I think youâre right, and I can see how No custom pop-up out of the box has some duplication with whatâs being discussed on WTH canât I use a card as more-info popup (even though the title is quite off).
But the fact is that this here topic is what itâs flagged as a duplicate of. And I think they are quite different.
I also think your topic is a separate request.
Sure, and thank you for asking. My primary goal was t have a card that would pop up on top of whatever task the user is currently doing, so that they can respond quickly to the event that triggered the popup. Typically that event would be something that is important to respond to right away. In my home I monitor my circuit breaker panel via the devices connected to each circuit. One circuit s particularly sensitive and trips often. Having a (silent) popup alert avoids other, more intrusive actions such as blinking lights, a sound or voice alert or other actions.
Of course there are other uses such as perimeter access doors, alarm systems, air quality or smoke/fire/water sensors that could benefit. Beyond the critical alerting realm, the card could also be used as a âare you sureâ type of last check, especially with configurable option buttons, such as OK, CANCEL, YES, NO, CONTINUE, etc. I do know that Buttons can be configured with a confirmation, but I donât think it can be configured to act as I described above in the case of a tripped breaker.
Although I make no claims to understand the underlying operation of Home Assistant, I believe this card would operate in much the same manner as a More Info popup works. I also believe that if this idea is implemented as a standard feature of HA, users will find even more ways to use the feature.
I hope this helps you understand my desire to have a configurable true pop up window that can be called from automations, scripts, events or other methods that I have not considered.
Please feel free to ask if you have any other questions. Thank you.
Art
aka kartcon
For me, I want to be able to have the camera popup when I click a mobile notification. Currently, there is no native way of doing this, as there is no direct link to the camera pop-up.
Also, I simply donât understand, why we still donât have more configurable buttons other than âscreenshotsâ for the popup window?
I have a use case for such a simple pop-up message.
I have a sleep state of my house. It is activated by KNX or dashboard button. If this action/scene is triggered and the house is not locked (binary sensor) I would like to bring up a message on my dashboards (wallmounted tablets) to show the user that the house needs to be locked or (another case) the EV needs to be connected to get charged over night.
