I have 2 sensors as well. I want to put one under me mattress or pillow and detect when I go to bed so that I run some night-time automations. It would be nice to have those sensors officially supported.
Hi @Cobi I have been trying to find a place to buy the eigenstone relay controller for months, so far impossible to find a place to get it. I see that you managed to buy 4
So the question is… Could you please give me some advice on where to buy them?
all my devices are Aqara/Xiomi and I think it would be the easiest way to integrate third party devices.
it is a sad surprise that the product has been discontinued, for me, it seemed to be the easiest way to integrate xiaomi sensors with third-party products at least in my case. And I still see it in MiHome App??.. I thought I could create rules to, for instance, extend the awning when the temperature is above o below something…
If it is still possible to buy one I would give it a try in any case.
Do you guys suggest any other way to do such integration in an easy way??
I’ve managed a supplier in alibaba. Never the less as I said I’m unable to add to Xiaomi gateway. The relay itself looks to be added to the network (wen I add it the light stops blinking) indicating that it has been added but the gateway does not add it and also does not expose it.
I’ve been able to add dual channel relay to xiaomi gateway. Does any one know how I can check if it’s being exposed or not. In home assistant I can’t detect it.
The device with sid 158d0001b765a3 isn’t supported of the used gateway firmware. Please update the gateway firmware if possible! This is the only way the issue can be solved.
I’ve had this for some months now, but up until know I was not able to pair it with the gateway. Today I’ve updated the firmware and I was able to pair it. I bought this in alibaba and besides Lumi site I haven’t found it anywhere else. You can see the pictures below:
