Xiaomi Sherlock Smartlock
I would like to ask your help! My Sehrlock S2 doesn’t work anymore. And I can’t download the 3.6.7 apk version from the site you mentioned bacause the downloading is suspended there.
Could you please share the apk file with me somehow?
Thank you for your help in advance,
Check this, please
Http://d.7short.com/sherlock
On my Galaxy S10 with android 12 doesn’t work, but someone will try start this
the 3.6.10 (Build 210506001) is from last year, it is also not working in android 12 (on pixel 3 anyway)
BTW
3.6.7 works on android 12 but I updated my sherlock firmware so 3.6.7 don’t work on it :frowning:
where I find version 3.6.7?
It opens in Android 12, but isn’t working with Sherlock original.
I cant download this
Os dejo la versión 1.0.7 de Bluelok para Sherlock S3 funcionando en Android 12.
Bluelok v1.07 working on Android 12!
http://d.maps9.com/bluelok
Download v1.07. It is working on Android 12
I need an application for sherlock S2
Could you please share it again? I can’t download this.
Thank you!
Bluelok v1.07 Android 12
Direct Link:
https://file.io/igeT7k4S6WIQ
Working on android 12
The app Bluelok also works on Wear Os 3.0 (Samsung Galaxy Watch 4) without phone, only with the bluetooth of the watch.
You have to install manually the apk and to register a new user to share your lock (only one user per device)
I have problems with paring app with Sherlock 2, on phone is Android 12, Samsung S10 + device, i dont get any error info just wont pair, can you tell compatibility with devices and share new version of app for sherlock 2 if you have thank you in advance
Sherlock app v3.6.10 is not working with Android 12. When they update the app, it will be available in this link:
http://d.3appstore.com/sherlock
I hope that they update the app, but the project is discontinued. I sold my Sherlock S2 and I bought the Sherlock S3
He conseguido instalar y que funcione la app Sherlok con la cerradura Sherlos S2. Puedo enviar la app, el problema es que reinicie la cerradura pulsando el botón inferior de la misma y ahora no me deja volver a vincular con el código QR. A alguien le ha pasado y sabe con desvincular de la app y volver a hacerlo?
Manda un mensaje al vendedor de aliexpres q t la vendió para q te la borre de la base de datos y puedas volver a emparejarla. Es uno de los grandes problemas del modelo S2.
what is the version that you have working on android 12?
can you share it?
Funciona la 3.6.0 en Android 12, mi problema fue reiniciar la cerradura con el botón inferior. Voy a contactar con el vendedor como dice Gerok a ver si hay suerte…
