Yale Zwave locks
HA only exposes information supplied by OZW and the Z-Wave device. If the information is missing or incorrect, it may be possible to add/modify the XML file to show the correct information. You can check the OZW database to see if your device or a different model is listed. http://www.openzwave.com/device-database You can also ask for the device to be officially added but you will likely need to supply the data. https://groups.google.com/forum/#!forum/openzwave
It must be that OZW mis-identified my lock then. I’ve verified that the type of lock is in the official OZW database, just that it has been mis-identified on my local server.
Where are the OZW files located? Which one would I be looking at to modify?
Everything works good what is type 0 and level 0 that i always keep seeing?
One of the zeros is the master code user. I forget what else rings up as “0”, but you don’t have to account for them with this code.
    sensors:
      yale_lock_status:
        entity_id: lock.assa_abloy_unknown_type0004_idaa00_locked
        value_template: >-
          {% set lock_status = states.lock.assa_abloy_unknown_type0004_idaa00_locked.attributes.lock_status %}
          {% set lock_status = lock_status|replace('user 0', 'Master') %}
          {% set lock_status = lock_status|replace('user 1', 'John') %}
          {% set lock_status = lock_status|replace('user 2', 'Jane') %}
          {% set lock_status = lock_status|replace('user 3', 'Johnny') %}
          {% set lock_status = lock_status|replace('user 4', 'Janette') %}
          {{ lock_status }}
Yea it’s strange i noticed i get that if i reset HASS and thats what the device template picks it up as
This is great but do you know how to only show the latest person who unlocked the door ?
This is unfortunately overwritten by " Auto re-lock" after 1 second.
Does anyone have any good automations using the alarm level, type?
I’m thinking
  • Send notification when battery low
  • Enable/disable user codes, maybe a boolean I can manually toggle or trigger with automations and conditions
  • Displaying the battery percentage
My repo has some automations you may find useful. Yale Touchscreen Lock:
https://github.com/rrubin0/homeassistant-config/blob/master/packages/locks.yaml
Whats the purpose of the node anchors section of your package file? Anywhere I can read up more on this?
Is there a way to force HA to poll the data from the sensor after reboot of HA so that it does not maintain an unknown state after reboot but before first communication received from yale lock?
I am stuck here. I have set up the network key in config.
zwave:
usb_path: /dev/ttyACM0
network_key: “0x22, 0x53, 0x02, 0x31, 0x04, 0x05, 0x08, 0x09, 0x09, 0x0X, 0x0S, 0x0D, 0x0D, 0x0E, 0x0F, 0x10”
(NOT MY REAL KEY)
2019-01-06 16:26:08.605 Detail, Expected callbackId was received
2019-01-06 16:26:17.316 Error, Node010, ERROR: Dropping command, expected response not received after 1 attempt(s)
2019-01-06 16:26:17.317 Detail, Node010, Removing current message
2019-01-06 16:26:17.317 Detail, Node010, Notification: Notification - TimeOut
Anyone have any ideas? I tried factory resetting and re syncing via secured node but cannot get this to work?
If I am reading the log correct is it an issue with with network key?
I am able to see it and see the switch but lock/unlock does not work.
I am just realizing my lock is the YRD226NR619 this showing the YRD446?
I was on discord and @freshcoast helped me today. Just in case it helps someone else. The problem was that I installed zwave AFTER I put in the network key. this caused the key to not show up in the .storage/core.config_entries file. I removed the lock - copy and paste the network key into this file - restarted - and re-pared the lock. This worked like a charm! it is fully functional now. Not sure you will see this but thank you very much @freshcoast!
Is anyone using Keyfree lock with Zwave S2/Plus module (light blue)?
Im struggling to set it up, some of the advanced config options are working all right, but the nodes does not contain any entities.
Hi Derek
I’m struggling on setting up my Yale lock
Can you elaborate on how should be configured?
I did not understand your last comments
Yeah I have the network key set- I did everything as the docs state for a secured node
Basically same issue I have right now
My issue is that I’m not seeing any of the sensor data. I have the lock paired in Vera so I’m not sure if that’s the issue (seems most people here are using a zwave stick instead). Any idea how I can get it to report the alarm values?
Guys, I’ve reading a lot o forums threads about Yale ZWave locks, but i couldn’t find anything precise about the matter: are all yale zwave locks compatible with home assistant?
I run my HA in a raspberry pi. Still don’t have any zwave device (only one zigbee). I’m thinking about buying this stick: https://www.amazon.com/gp/product/B00X0AWA6E/ref=ox_sc_act_title_2?smid=A1O77D5UJY7IVU&psc=1
Will it be OK to use any new Yale Lock (given it is zwave compatible) with my setup?
Thanks in advance!
