I have done this and re run the command but again the alarm still stays un armed
If i subscribe to home/alarm/set and then run the command from another terminal I can see the ARM_HOME command in that topic so its getting through MQTT fine.
Nope. It not 0000. Both my code are different and none of number repeat. The only reason is because there isn’t any error showing up logs. Do you need to enable debugging?
where could i change the weather font and weather icon color?? i already tried removing line 242 (lobster) and editing line 227 to “color: white;” for icon color but nothing changed so i assume its somewhere else??
edit: above was preformed in the /config/www/alarm,css
Unfortunately the icon isn’t easily changed as this is auto generated by HA as a svg file which due to polymer isn’t easily changed. I do want to correct this however at some point.
And a screenshot of me issuing the command on the left hand side, and on the right hand side im subscribed to the topic so you can see the payload comes in. I know MQTT is working with home assistant as I use it for loads of other things so I know its not a communication issue between HA and MQTT
Thanks for that, this seem to solve the issue for disarming the alarm. The Alarm Panel is still glitched.
How does the TTS work, right now I was able to set alarm sound for most of speaker in my homes but still having trouble setting up TTS. Do need to hook up a speaker onto the raspberry pi for TTS to work? I able to do set custom voice/sound track into my xiaomi gateway but that kinda too much trouble.
The alarm page loads on my some devices/browers. I still trying to find what causing the issue.
Edit:
Pretty sure it not my adons as even in ingnoite mode Firefox 57 doesn’t load.
service: tts.google_say
entity_id: media_player.floor <-- your media player
message: 'May the Force be with you.' <--- what you want google to say.
I presume it only works with google audio and chromecast devices? Would it work if plug a speaker into my raspberry pi? I presume the media_player will be replaced with local one?
if you already have media player in your ha. you can use tts google platform to say out to any of your media players in ha by automation.
From this post. Mr.gazocascalvertos has made the automation to notify the status arm, disarmed you can put in such service inside his automation to also say out.
I have chromecast right now, but it not on 24/7. I was hoping to grab a chromecast audio next week, in meantime i will check media player page on home assistant and see if any existing device is supported. Thanks!
my motion sensors default state is “standby” and when motion is detected its state changes to “motion detected”. Do I need the motion sensor to report certain states for the alam to trigger or will what I have setup already work?
I set the sensor in alarm.yaml under immediate sensors and then put the alarm in home mode. I purposely wave my hand in front of the sensor but the alarm doesn’t change red or change its state to triggered. The sensor picks up the motion however.
Is Home Assistant version 0.61.1 compatible with YET?
Alarm panel did not work as expected with my Android tablet and it was because i just removed the # for MQTT.
In the next release please change this in alarm.yaml. It caused a lot of troubleshooting for me.
#command_topic: home/alarm/set [OPTIONAL] The MQTT topic HA will subscribe to, to receive commands from a remote device to change the alarm state.
to
#command_topic: home/alarm/set # [OPTIONAL] The MQTT topic HA will subscribe to, to receive commands from a remote device to change the alarm state.
I made a quick test and added a motion sensor to the immediate: group.
An alert message was shown on the tablet and I had to use the code.
It seems to work but I am new to this and the alarm is not in use here just for testing.
