What Dark Sky weather sensors do you have defined? You need an apparent temperature and a summary sensor or Firefox will complain. The install instructions only list the summary sensor as being required but they both are. See the first part of my post here:
Tom
Thank you, disabled weather, in alarm.yaml and no more error, and panel displays in Firefox
Will now add temperature sensor, and test, once again thanks for the assistance.
Update: All working now, thanks for the assistance
thanks to all, now working also for me.
OK,
Iām proposing changing the alarm.yaml config so that each state must configure its own groups. Times can still be inherited for example:
armed_home: #Either home/away with perimeter as optional
pending_time: 10
trigger_time: 600
immediate: #[OPTIONAL however either an immediate or delayed group must exist]
- binary_sensor.whatever
delayed: #[OPTIONAL]
override: #[OPTIONAL]
This would drop the current homemodeignore group too so not backwards compatible with current release
Also how about splitting pending time so that there is a pending time for arming the alarm and a separate warning time for when a device is tripped?
If someone wants to share a mockup of a super clean (mobile/reduced feature set) panel too Iāll code it up
That would be awesome! Iām using HADashboard with an iframe to show the alarm panel and only part of it shows without scrollingā¦
Hi guys, Iām setting up my alarm system and currently have a simple problem.
My siren goes off when the alarm is triggered in Away mode because I have alarm_triggered rule in automations.yaml.
However, when trigger_time elapses, the alarm system automatically falls back to Away mode but does not switch the siren off.
I tried to add service call switch.turn_off to the alarm_arming_away automation rule, but it didnāt work.
I ended up calling switch.turn_off for my siren from alarm_armed_away and it works, but I donāt feel thatās kind of the right choice.
How it supposed to be configured properly?
And also, having read HA documentation on templating and noticing several complaints in this thread regarding automation not working, I believe there should be data_template:
instead of data:
in every alarm_xxx automationās action.
I think that would be a more intuitive aproach to understand the configuration.
Also, it would give more flexibility to have a pending time to armed state and a different one to trigger.
hi, thanks for this great project! I updated all the files from github with latest files, running hassio 0.65.4 on a raspberry pi, for browsing I use safari on a mac, I get this on my log when visiting the alarm panel XXX.XXXX.XXX/local/alarm/alarm_scripts.js:38:20 TypeError: null is not an object (evaluating āmain.leftā) any help ?
Ahh, I have not yet tested with the latest HA.
Please leave it with me
can confirm that there is nothing like that on 0.64.3
Any entity, automation or group (groups can include automations) defined under alarm within your alarm.yaml:
alarm:
Will switch on when the alarm is triggered.
You could define your automation and add your sirens to a group then set in your config above, when the alarm resets back to armed state after the allotted time the group will switch off.
You are better off using an automation however than groups to keep things simple.
For example you could use an automation to monitor the state of alarm_control_panel which only looks at the āfrom_stateā attribute ātriggeredā then switches off your siren. For examlple:
alias: '[Alarm] Resetting'
- platform: state
entity_id: alarm_control_panel.house
- service: switch.turn_off
entity_id: switch.siren_ground_floor_switch #Or alternatively define a group for multiple sirens
entity_id: switch.siren_1st_floor_switch
entity_id: switch.siren_2nd_floor_switch
Currently itās alarm: automation.alarm_triggered
So I was right when added switch.turn_on
of the siren in action section of that automation.
I think itās a good idea to add a comment about it in alarm.yaml
The idea of monitoring the state of alarm_control_pane is good as well. Iād rather do it like that
alias: ā[Alarm] Resettingā
- platform: state
action: - service: switch.turn_off
entity_id:- switch.siren_ground_floor_switch
- switch.siren_1st_floor_switch
- switch.siren_2nd_floor_switch
or use a group of sirens.
Thanks for the explanation!
Hi All
Trying to get the following automation to work, but getting an error when validateing the config file, can any throw some light on this for me.
- alias: '[Alarm] Panic Mode'
- platform: state
value_template: "{{ states.alarm_control_panel.house.attributes.panic_mode | upper }}"
to: "ACTIVE"
service: notify.kp
data_template:
message: '!! Panic Alarm Set !!'
I am getting the following error
automation: - Invalid config for [automation]: [value_template] is an invalid option for [automation]. Check: automation->trigger->0->value_template. (See /config/configuration.yaml, line 88). Please check the docs at Automation - Home Assistant
The platform has to be ātemplateā
Use this:
- action:
- data:
service: notify.kp
data_template:
condition: []
value_template: '{{states.alarm_control_panel.jarvis_alarm_system.attributes.panic_mode=="ACTIVE"}}'
Hi guys,
Spotted another issue, I have clock: true, in the alarm.yaml, yet the clock does not get displayed, anyone help here.
itās a known feature. I found the answer earlier in this thread.
Display the clock : You also need the following in your configuration.yaml
- platform: time_date
display_options:- ātimeā
@AhmadK
I did go through the whole thread, and just knew was missing a sensor, but this thread now is so long, I just missed it, anyway thank you.
